Question about Garden
Homelite 2 stroke water pump 166 gpm
Model # 3552-1R color green with 2 inch intake and exaust both on top with removable pull rope
5 Suggested Answers
  • 246 Answers
SOURCE: r\r the pull rope spring assy
Hello:
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
The Following is a "General" "Chainsaw Clutch Removal" File. **To Hold the Crankshaft for Removal of the Clutch; Purchase a Bolt that is 3" to 4" Long and has the Same Diameter and Threads as the Spark Plug. Carefully Insert the Bolt Into the Engine Until it Contacts the Piston. If the Bolt is too Short, then Slowly Turn the Engine in the Same Direction you are Going to be Turning the Clutch Until the Piston Contacts the Bolt. Now to Remove the Clutch. If you do Not have the Clutch Tool for an Impact Wrench and are Doing this By Hand (no air compressor and/or not the correct socket), then Use a 2" Wide, Flat Chisel and a Shop Hammer or a 22oz Hammer and Hit the Outer Part of the Thick Ear in the Same Direction that the Engine Turns During Operation.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
  • 6 Answers
SOURCE: how do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Posted on Jun 17, 2009
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
rycgl
  • 1545 Answers
SOURCE: Homelite Gas powered Trimmer will
The body of the spark plug has to be "grounded" to the metal on the engine when you remove it and test it. If you did it that way, OK. If there is no spark then (and it should be a nice blue color, not orange or yellow), the the "air-gap" between the ignition coil and the flywheel needs to be checked. Some disassembly is required to get to it as these parts are under the front engine cover. The air gap should be around .010" (or about the thickness of a standard business card). If the gap is too wide, the spark will be weak. If the gap is too close, the legs of the ignition coil may slightly rub on the flywheel. If you indeed have no spark, after properly testing, then check the air-gap.
If this is a fuel related issue, post back and we will address that as well.
Posted on May 15, 2011
Installing a starter rope
Remove the 3 or so screws that secure the pull rope housing to the top of the motor. Flip it upside down and it should be pretty obvious as to how to remove the spine loaded piece that the rope goes on. Thread the new rope thru the housing and wind it up on the spindle. Make sure before you put it on that the rope pulls out and retracts like it should.
Jul 30, 2016 | Homelite 6796881 308451006 Hilmore Husky...
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Engine on but do not pump water
Be sure the inlet and outlet lines are clear. This has a limited suction lift 23' max, be sure you are not exceeding that or the maximum head. each foot is 0.433 Psig so 98 * .433 = 42.43 PSIG.
Specifications Type Self-priming/Centrifugal Caliber 2 in. Maximum Capacity 160 gal / min Total Head Suction Head Self Priming Time 120 sec / 16 ft Engine Type Air-Cooled, Four-Stroke Rated Horsepower 4.0 @ 4,000 rpm Bore x Stroke 56 x 50mm Displacement 123cc Cooling Forced Air Lubrication Splash Oil Capacity Starting Method Recoil Ignition System Transistor Controlled Dimensions Fuel Tank Capacity 1.2 gal. Recommended Fuel Unleaded Regular Dimensions (LxWxH) Dry Weight A-20070116-1378-130-E
Dec 08, 2013 | Yamaha YP20G Water Pump 2-Inch, 160 GPM...
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    I cannot locate my owners manual and have not used the Homelite Ranger 16 inch in quite some time --- What is the fuel and oil requirement??
    most 2 stroke Homelite chainsaws run on a fuel/oil mix of 50:1 --- But on some older model saws they say to use 40:1 mix.
    I own several 2 stroke machines and I use 50:1 on everything and they all run fine ( even when they say 40:1 ).
    c...
    Jan 19, 2011 | Homelite ZR10926 16 Chain Saw
    Have a homelite AP-125 - UTO1709 F, want to know how far it can pump water uphill
    Your best bet is to ask Homelite directly for the pump curve. Since Homelite does not appear to offer it anymore I could not find anyone who published the information, hence the referal to Homelite. A typical pump curve for a small pump like this will show GPM or GPH based on several discharge heights. You do not need to consider the overall run of pipe or hose but only the total change in height. In other words, pumping thru 150' of 3/4" hose up an incline that has a total rise of 12' would end up delivering the GPM for 12' on the curve or something very close anyway.
    Contact Homelite here.
    John
    Jan 04, 2011 | Homelite Plumbing
    Pull rope stuck
    It sounds as if the motor may be locked up. WIth spark plug wire disconnected, turn mower on side and see if you can turn blade. It should turn rather easily, but you will feel the compression stroke. If you can' turn it try removing the spark plug. If you still can't turn it, check the oil level, if it's low the motor may be siezed. You also could have a stuck valve. If it is a valve you can try removing the cover, and soak it with oil. It is imperative to watch the oil level in small motors, as well as being sure to change it.
    Jul 23, 2010 | Poulan "" Push Mower
    Garden Logo
    20 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
