Question about Garden
Pressure washer shuts off
While using machine it just shuts off starts up 1st pull start using again shuts off after several min. Any idea?
stug_57u
  • 99 Answers
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Posted on Nov 01, 2008
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
  • 15 Answers
SOURCE: I have a Briggs & Stratton gas power washer. This
Sounds like the unloader is not working correctly. Try replacing it and see what happens.
Posted on Apr 23, 2009
  • 2841 Answers
SOURCE: New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Posted on Apr 25, 2010
  • 5603 Answers
SOURCE: PRESSURE WASHER RUNNING BUT NO
The water admittance valve is stuck. The spring loaded valve lets more water into the pump when the pressure drops when you trigger the wand. Take the valve apart, clean the bore with crocus cloth on a dowel rod. Replace the O Rings and lube with plumber's grease and reassemble. Good as new! The O rings get dry, deposits build up in the bore, and the spool valve sticks at the high pressure end so no further water comes in to be pumped. Half hour job, get an O Ring kit to refurbish.
Posted on May 31, 2011
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Dado
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
Won start
Depending on set up there's a chance because you ran it out of gas the bowl is dry? Get some old school lighter fluid pull out the plug squirt some into hole , doesn't take much. Reinstall plug quickly and give it a pull and see what happens
May 08, 2017 | Briggs Stratton 020273 Elite Series...
Pressurewasher runs fine then shuts down and cant pull
Same thing happened to me and I found out that water was getting into the carb filter media. Try taking the carb filter cover off and see if the foam filter is wet. If so, try starting without the filter and see if it works. THis issue used to drive me crazy on my unit, hope this helps.
Jan 20, 2013 | Garden
Pressure washer problem
hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a cloged vent, !!
Feb 18, 2012 | Garden
Apr 25, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Started right out of the box last year, used it less than an hour, now can't start it. I've pulled on for over 45 mins with no success.
SOME OF THE NEWER ENGINES HAVE A OIL LEVEL SWITCH THAT WILL SHUT THE UNIT DOWN IF YOUR LOW ON OIL OR THE SWITCH GOES BAD TRY JUMPING THE SWITCH IF ONE IS FOUND
Oct 22, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
No pressure
It is probably air locked....Here's what you need to do. Connect the garden hose, and HP hose, but not the gun. Turn on the water, and let it run while you make sure that there are no high points in the garden hose that can trap air....Work the hose so that any air is displaced through the pressure washer. Continue in this manner through the HP hose. Shut off the water and connect the gun. Turn the hose back on, and operate the gun for several minutes, pulling the trigger and releasing. This alternately allows the water pressure to build up on house pressure and then to depressure, pulling residual air from the system. Release the trigger, and start the machine. Usually, this is enough to get full washing pressure. If it is very difficult to start, you can hold the trigger down on the gun and pull the start cord at the same time. Holding the trigger down acts as an unloader, making the starting easier.
Hope that this helps, --W/D-- please feel free to rate this solution! Thanx!
Jul 31, 2009 | Garden
Garden Logo
142 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
