Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Unsupported content i was running a movie via usb ... 1080p..movie is running fine..but there is a notification at bottom of the screen saying "Unsuppoted content" with an "!" mark.How do i get rid of it???
How do I change connection mode on my galaxy s4 mini with android 4.4.2?
Turn on your phones screen drop down your notification bar and press notification about your phone connected via usb and it gives you two options and one of them its Mtp and second Ftp. Choose Mtp. And thats all
Jun 25, 2014 | Samsung Security Cctv Sod-14c Soc-120...
Tip
How to Play iTunes DRMed Movies on Samsung Smart TV via Mac
Apple makes its digital content too proprietary so that we can't enjoy any content we purchased or rented from iTunes store on any other Non-Apple products. It of course won't allow us to watch the iTunes movies on Samsung Smart TV.
But this will make Samsung Smart TV users depressed if they have purchased or rented movies frm iTunes store. This tip is written to help the Samsung Smart TV users to solve the issue.
Method 1. Transfer the iTunes movies to Samsung Smart TV using an USB port.
If you have a smart tv on hand, you will see there is a USB port on this TV. So we can transfer content via USB port to this TV set. But iTunes movies are DRM protected, we can't transfer it directly. So it needs us to remove the DRM at first. TunesKit iTunes DRM Removal application is a must-have tool for Mac users.
iTunes DRM Removal for Mac Remove DRM from iTunes Rentals and Purchases...
Step 1. Download and install the TunesKit DRM removal software on your Mac
It works with Mac OS X 10.8 or later and the newest iTunes. The Windows version is coming soon.
Step 2. Add iTunes M4V videos to TunesKit
Click "Add Files" icon, you can add iTUnes movies from iTunes library directly. Or you can also drag and drop the movies to TunesKit.
Step 3. Manually choose output subtitles, audio tracks and AC 3 adolby 5.1 surround
If you don't want to output all the audio tracks, subtitles in the MP4 video. You can manually choose the audio tracks, subtitiles or 5.1 surround, stereo channels for the output.
Step 4. Start removing DRM protection.
Click "Convert" button to start removing iTunes drm protection from iTunes movies now. Once the conversion done, you can find the output MP4 video under the "Converted" tab or clicking "Open" button.
The output MP4 videos are totally DRM free and 100% original quality preserved. You can copy and paste the videos to USB now and plug the USB device to Samsung Smart TV.
For more methods to watch iTunes movies on Samsung Smart TV. You can refer to this page: How to Watch or stream iTunes DRM Movies to Samsung Smart TV
on Aug 20, 2014 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Connection for cellph to laptop
Music, movies, photos and more can be stored on the micro Secure Digital memory card on your Samsung Galaxy S phone.
To get all those goodies on the microsSD card you need to transfer them from your computer. Connecting your Galaxy S to your computer is done with the USB cable that was included with the phone and doubles as the charging cable when plugged into the outlet adapter that also came with the phone
Plug the large end of the micro USB cable into your computer and the small end into the USB port on the top of your Galaxy S phone.
Wait for your computer to recognize the phone.
Press the "Power" button on the top right side of your phone, briefly.
Unlock the phone by dragging the padlock icon to the top of the screen.
Drag the notification pane down by touching the top of the screen and dragging your finger to the bottom.
Touch the "USB Connected" notification and then press the "Mount" button.
Your phone's microSD card will appear to your computer like an external drive.
Click on the "Start" button on your computer and then click on "Computer."
Double-click the drive icon that corresponds to your Galaxy S phone.
This will open a folder that shows the contents of your phone's microSD card.
You can copy files to and from the folder like you would any other folder on your computer.
Click the "USB Device" icon in the task tray of your computer.
Click "Eject USB Device."
Wait until you're done transferring files before ejecting the phone from the computer.
Unlock your phone and drag down the notification area.
Tap the "USB Connected" notification and press "Disconnect."
You can now safely unplug your phone.
Bluetooth
http://www.samsung.com/global/microsite/galaxys/userguide/connectivity.html
Jun 22, 2013 | Acer eMachines 520-2890 Notebook
Vizio won't switch from 720 to 1080p
the game itself may not be output to 1080p. most ps3 games are 720p
Oct 04, 2017 | Televison & Video
My toshiba tv 46inch 1080p says that it's on
Your TV can only present resolutions as good as the source you provide it. For instance a standard DVD likely provide 720 or less resolution while a good Blu-Ray will deliver 1080 content to you TV and show "1080" as it receives the data from the Blu-Ray player as the movie begins. You may see this number switch often even on 1 single DVD as the resolution often changes between movie trailers and the main content and menus can all have different qualities. So, your TV is only as good as the content you feed it. It can not make the content better then the original source you provide. Hope that helps
Jan 22, 2012 | Toshiba Televison & Video
Toshiba SD2010 DVD player
It can't read the files on the USB, wrong format.
Jul 14, 2017 | Televison & Video
Onkyo 606 Video Drop out
main board fault, its input feed on the board might be failing, it could also be a failing capacitor, you would need to open it up to have a look and see if there are any capacitors failing.
May 14, 2017 | Onkyo TX-SR606 Receiver
Ps3 playing BD in 720
first try to reset the video refresh output by holding down the power button with the switch in the back on. hold the front power for 13 secs ..you should hear two beeps one 6 secs after the other. if this doesnt work reset system settings on the XMB menu (all the way to the left)
Nov 10, 2008 | Sony Playstation 3 (PS3) Console
Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Oct 11, 2008 | Samsung YP-Z5 MP3 Player
1080p Prob with TH-50PE700U
try diffrent hdmi cable, sometimes with this new digital stuff there are compatibility issues, not common, but not unheard of
Feb 20, 2008 | Panasonic (TH-50PZ700U) Television
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
747 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
