Msh 12rv heater stops and intermittent fault lh green light flashes quickly continuously restart is difficult
5 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: My reverse cycle air con (Mitsubishi MSH 12RV) is
I would check the reversing valve. This is what switches the flow of refrigerant for Heating and cooling.There could be several other reasons that could cause it not to heat.
Good Luck, Sincerely, shastalaker7
ps Heat pumps are very temper mental, like I said there could be many things that could cause this problem, and I couldn't walk you through them all. If you have a split system, two piece unit, go to the out side unit and have some run the a/c in cool. Then after a few min. have them switch it to heat and you can hear the reversing valve switch to heat, as it will make a swishing sound.If it doesnt, the valve may be bad, no power to the coil on it, or even the coil could be burned out.
Posted on Oct 30, 2009
heatman101
  • 43501 Answers
SOURCE: i have a a/c unit mitsubishi electric ms-12rv r22
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
SOURCE: Mitsubishi split-type air conditioner model
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
Posted on Mar 11, 2011
  • 37 Answers
SOURCE: I have a heat pump
If its not being turned off by the thermostat, sounds like it might be the low presure switch kicking it off due to low freon. You will have to get a HVAC tech to charge it back up.
Posted on Mar 14, 2011
Ford airbag code 54
94+ AIR BAG DIAGNOSTIC TROUBLE CODES/CLEARING
Code Component/Fault Description
No Air Bag Indicator - Inoperative Indicator Circuit
Continuous Air Bag Indicator - Diagnostic Trouble Code Timed Out, Diagnostic Monitor Disconnected or Inoperative, or No Ignition Voltage to Diagnostic Monitor.
12 Lost Battery Feed
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Diagnostic Monitor Not Mounted to Vehicle Properly
22 Safing Sensor Output Circuit Shorted to Battery Voltage
23 Memory Clear Circuit Improperly Grounded
24 System Disarm Failure or Internal Diagnostic Monitor Fault
32 Driver Side Air Bag Circuit High Resistance or Open
33 Passenger Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Circuit Low Resistance or Shorted
41 RH Radiator Primary Crash Sensor Feed/Return Circuit Open
42 LH Radiator Primary Crash Sensor Feed/Return Circuit Open
44 RH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
45 LH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
52 Intermittent or Repaired Lost Battery Feed
53 Intermittent or Repaired Air Bag Circuit Shorted to Ground
54 Intermittent or Repaired Primary Crash Sensor Circuit Shorted to Ground
61 Intermittent or Repaired Diagnostic Monitor Not Mounted to Vehicle Properly
62 Intermittent or Repaired Safing Sensor Output Circuit Shorted to Battery Voltage
63 Intermittent or Repaired Memory Clear Circuit Improperly Grounded
64 Intermittent or Repaired System Disarm Failure or Internal Diagnostic Monitor Fault
72 Intermittent or Repaired Driver Side Air Bag Circuit High Resistance or Open
73 Intermittent or Repaired Passenger Side Air Bag Circuit High Resistance or Open
74 Intermittent or Repaired Driver Side Air Bag Circuit Low Resistance or Shorted
75 Intermittent or Repaired Passenger Side Air Bag Circuit Low Resistance or Shorted
81 Intermittent or Repaired RH Radiator Primary Crash Sensor Feed/Return Circuit Open
82 Intermittent or Repaired LH Radiator Primary Crash Sensor Feed/Return Circuit Open
84 Intermittent or Repaired RH Radiator Primary Crash Sensor Not Mounted to Vehicle
85 Intermittent or Repaired LH Radiator Primary Crash Sensor Not Mounted to Vehicle
Rapid Continuous Flashing of Air Bag Indicator (No Diagnostic Trouble Code) Both Primary Crash Sensors Disconnected Assembly Plant Mode
TROUBLE CODE CLEARING
1. Follow the diagnostic procedures to service the fault condition flashing on the air bag indicator prior to code clearing.
2. Cycle the ignition switch to OFF and then to RUN.
3. Observe air bag indicator prove-out (six ? two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
4. Locate the Diagnostic "Trouble Code Clear" Connector (grey connector). located underneath the glove compartment, left side (06010) containing Circuits 631 (T/R) and 57 (BK).
5. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
6. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
7. Release short on Circuit 631 (T/R) to Circuit 57 (BK). This short must be released within 25 seconds after the diagnostic monitor tone sounds.
Diagnostic trouble code is now cleared from memory. Next highest priority diagnostic trouble code stored (if one exists) will begin flashing.
The codes and clearing proceedure above are to be used as a guide, NO claims are implied as to the correctness or accuracy of either.
Sep 11, 2013 | Cars & Trucks
I have a heat pump mitsubish MSH-12RV. It turns itself off after 1-2 minutes operation. Ihave cleaned the filters and re-set the clock. Any other suggestion?
Mar 14, 2011 | Mitsubishi Heating & Cooling
Cda cw 494 - dishwasher makes beeping noises and stops halfway through cycle . will restart if turned off but will not complete . doesnt seem to be filling properly .now and then does complete cycle and...
Greetings,
usually, open and close door..then start counting the flashes. these will give you your fault code. The code then tells us where to go from there. off hand, i would say you have a heater problem.. Either, the water is not getting hot enough because of a faulty heater, or faulty thermostat. The button above the green light that flashes try and hold that down for a minute to reset....let me know about the flashes
Nov 16, 2010 | Whirlpool Dishwashers
Clean light keeps blinking...how do i reset?
it's telling u you have a fault but to clear it just press ur start button until the washer beeps then shut the door and leave shut until the aplliance stops. it will be ready to use. The flashes are usually intermittant i.e 3 quick flashes then a small break then 3 flashes again this process will repeat over and over. Count the flashes and let me know the amount i'll look at the fault for you
Hope this helps
Mar 19, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Flashing power light.
Have you tried a differnt usb cable if that dos not do it get back with me and I will walk you though checking it out
Jan 09, 2010 | Computers & Internet
Dishwasher keeps pumping out - won't start cycle - green light flashing on panel
I had same symptoms on a Hotpoint dishwasher.
Turned out to be a failed water heater.
The logic in this case goes like this:
When wash cycle starts, the first thing the machine does is pump out any water that has collected in the sump since it was last run.
It then allows a small amount of clean water in and enables the water heater.
If heater okay, it then continues with the rest of cycle.
In this case, the control board detected failed heater so pumps out the water and then stops with an error code shown by a flashing lamp.
No simple fix I'm afraid - machine had to be turned on its side, bottom panel removed, several items had to be removed to get at the water heater which was then repalced with a new one.
You dont state what make/model your dishwasher is so maybe worth adding this information as someone else may recognise your fault and have a quick fix.
Oct 02, 2009 | Dishwashers
I have a a/c unit mitsubishi electric ms-12rv r22 when starting it on cooling or heating mode it stops after 30sec and the operating light flashes and the otdoor unit does not run the indoor unit fan stops...
heatman101
Apr 04, 2009 | Mitsubishi MS12TN Air Conditioner
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Canon i9950
Yes, the flashing light on start-up is actually the Waste Ink pad is full
a Canon tech suggests that the job is very difficult (unfortunately even for them)
HOWEVER....
good news is that you can override it for awhile...
  • turn off power
  • press & hold RESUME button, then press POWER button
  • continue to hold POWER then release RESUME button
  • Press RESUME Button 2x quick
  • Release both RESUME and POWER
  • Green light will now blink, then stop
  • With Green light on....press RESUME 4x
  • Push Power button to turn printer off
this should resolve the issue
remember to rate the solutions...anything less than FIXYA actually lowers my rank...I didn't make the system...just wanting everyone to understand the impact of their vote....so if you need further help...just ask....hope it fixya'd...if it did then rate please!
bearb
Aug 01, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Washer will not work
Possible drain fault, check filter. Regards Advisor
Jan 28, 2007 | Zanussi FJS1225W Front Load Washer
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
