Question about JVC KD-LH810 CD Player
I can only eject cds apparently...
Turn car on. CD player does not light up. Eject button works, the side buttons light up red and then turn off, the main screen is still off. The display button works all lights light up including main screen, main screen tells me the time. Then all the lights turn off including mainscreen. Does not play cd, does not play radio, does absolutely nothing except tell me the time when I push the display button. What gives? fuses all good. Unit is not moist at all. All wires are spliced together to a 2002 toyota corolla. The only difference from the jetta I took this out of is the illumination wire. The Jetta didnt need that wire hooked up to anything, The Corolla has an illumination wire, so I connected them, still no difference. I disconnected the illumination wire, still no difference. Whats the deal?
2 Suggested Answers
  • 3 Answers
SOURCE: JVC KD-G340 Power Problem
yellow wire is another power wire that goes directly to batt.,red goes to acc. or fuse box & black is ground
Posted on Mar 04, 2009
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Radio will not power up when I pust power button.
Make sure you have power going to both the red and yellow wires. If power is going only to the yellow wire, it will eject cds, however both the red and yellow wires need to have voltage going to them in order for the radio to work.
May 29, 2012 | Clarion XMD3
Help!! I have a library CD stuck in the CD changer. I can see it but it will not eject...it won't even acknowledge that it has a CD in the changer. I have tried tweezers, switching CD slots and trying to...
TRY TURNING OFF CD PLAYER.WAIT 10 MINUTES THEN TURN CD PLAYER BACK ON THEN PRESS THE EJECT BUTTON.SOME TIMES CDS PLAYERS GET HOT WHEN PLAYED FOR A LONG PERIOD OF TIME.MY CDS SEEMS GET STUCK WHEN I PLAY CD PLAYER LONG TIME.SOMETIMES IF CD DONT COME OUT .IF IT STICKING OUT JUST A LITTLE.TRY PUSHING BACK IN CD PLAYER THEN EJECT IT.THIS TRICK WORKS SOME TIMES.
Mar 11, 2011 | 2002 Ford Escape
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
Cds are stuck in the default cd player of 2001 Dodge Intrepid. How do I get them out?
The first step is turning the car off. Then before turning the key back on, push and hold the Eject button then turn the ignition on. If the CD fails to eject then you can use a old CD and try to insert it into the CD Player, just as it try's to take your second CD pull it out and hit the Eject button again. This will usually get a Dodge CD player to Eject.
If this fails then the CD player must be removed and a manual eject can be performed.
May 15, 2010 | 2001 Dodge Intrepid
How do you eject the damn cd out of the pioneer DEH-P7900BT
Your Manual
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
will go over all the functions in detail.
3 EJECT button
Press to eject a CD from your built-in CD
player.
Press and hold to open or close the front
panel.
Bottom rightmost button.
Nov 11, 2008 | Pioneer DEH-P7900BT CD Player
2008 Durango Limited
The eject button is the load button on our 2005, maybe the same for you. Just hold it in for a few seconds and it should spit out your cd. You should be able to lightly put the cd up to the insert space and it should take your cd. If your cd player holds multiple cds then perhaps there are some in there that have not been ejected. Hope this works for you.
Oct 27, 2008 | JVC KD-AVX1 Car DVD Player
Toyota dashboard CD player won't eject
I had this say problem with my 2000 solara. Here is the fix, remove one of the car battery terminals for a couple of mins (3-4mins). The reattach the battery terminal back. This would make your cd player and car clock reset. once you start your car you should be able to eject the cds. You'll just need to reprogram all your preset radio station. Hope it helps
Oct 04, 2007 | 2003 Toyota Celica
JVC KD-LH810 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
