Question about Soleus Dehumidifiers
Soleus gl deh 45 2 drainage hose attached but no t working bucket full
SOURCE: when hose is attached, bucket fills up
The hose connection was ok, but, the hose itself was a lttle, I mean little bit higher than the connector, and as a catch all to not allow flooding, will then drip back into the bucket. I laid the entire hose down and then up a little bit to the pump and it works great. Thanks for all the help
Posted on Sep 10, 2007
  • 30 Answers
SOURCE: haier 30 pint dehumidifier continuous drain problem.
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
Posted on Aug 31, 2008
  • 41 Answers
SOURCE: CH1 IS SHOWN AS WELL AS THE BUCKET FULL LIGHT
I have a LG model LHD65EBL that first started icing up along the top edge during humid days. After several months of this, it finally stopped working and displayed CH01 with the bucket full indicator flashing.
I took apart the dehumidifier, removed the temperature sensor from the coil and rubbed it between my fingers. I then plugged in the unit and it started right up, confirming either a sensor or other circuit problem related to that sensor. For my model unit, I ordered sensor assembly #6877A30013L from RepairClinic.com for $21.75 + shipping.
When I received the assembly, I measured the new and old sensor with an ohm meter: new sensor = 5.5KOhms, old, defective sensor = 5.34KOhms. I installed the new sensor assembly and the unit is working fine.
Just because the bucket full indicator is flashing along with an error code does not mean there is a problem with the bucket full switch.
Posted on Sep 12, 2009
  • 4736 Answers
SOURCE: I have an LHD6594EBL dehumidifier that won't
Sue, if you haven't noticed any water draining from the hose recently, it may be that the hose connection and tubing of the unit are clogged and the drained water pressure is causing the unit to show "Bucket Full." Also, if the bucket is not properly in place, whether you use the drain hose or not, it will cause the unit to stop functioning. You know how to correct that, so I won't go into detail on that issue.
To unclog the drain, you will need an 18" long, plastic Zip Tie or something similar (NO wire coat hangers though) that will fit into the hose connection. TURN THE UNIT OFF AND UNPLUG IT. Then carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. You will have to carefully work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, while rotating it, slowly pull it out and be prepared for some water to follow.
Hope this helped you troubleshoot and solve the problem.
Posted on Jun 01, 2011
  • 5 Answers
SOURCE: The unit says bucket full and flashes ch 24 Was
No it is not the cord.
Try it with the bucket instead of the hose.
Let us know what happens.
Posted on Jul 21, 2011
Why is my soleusair dehumidifier model GL-DEH-50 say F2
Pipe Temperature Sensor Malfunction.
1.
Unplug the dehumidifier.
2.
Check the surrounding area
for possible reasons for sud-
den temperature changes.
3.
Wait 2 hours before plugging
the dehumidifier back in for
normal operation.
4.
If the "Error" is still indicated,
please contact customer
service. Call 1-888-876-538
Soleus Air SG DEH 70EIP 6 Operating Instructions Manual Error Codes...
Jul 31, 2017 | Dehumidifiers
Why is water going to the bucket instead of getting pumped out the hose? Does this mean the pump has quick working?
It is possible that the drain hose is not properly positioned. It is very fussy about that. Here is a link to the manual on PDF. See pages 8 thru 12.
http://www.soleusair.com/Manuals/2013%20Manuals/Dehumidifier/SG-DEH-70EIP-6%20Manual%2012-05-12.pdf
Oct 23, 2015 | Soleus Dehumidifiers
There is a part inside the water bucket with a wheel. Where does this attach to the unit?
I have a sg-deh-30-2 model and the unit seems to be doing everything right,the filter is clean the motor is running and room temp is 75 but the machine is not dehumidifying the bucket is dry
Jun 17, 2012 | Soleus DP2-70-03 70 Pint Flat Panel...
Hose hooked up but bucket fills anyway. Hose is attached to internal nozzle. Is that right?
The problem you're having is generally cause by the drain hose or drain hose connection being clogged. When that happens water is diverted to the bucket. To solve this problem do the following:
First disconnect the drain hose for clogs to check for a clog.. Also, the hose should be no longer than 5 feet. If the hose is clear, the clog is in the hose connection or tubing.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor ithe hose for drainage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helps you & thanks for choosing FixYa.
Aug 06, 2011 | Soleus CFM-40 Dehumidifier
I have a Soleus Air Dehumidifier, Model SG-DEH-70-1A, I cannot get it to drain through the hose rather than into the bucket. The instructions say to simply hook the hose up, which I have done, but it...
Several things play a role in the problem you're having.
1. The length of the hose. Shouldn't exceed 5 feet.
2. Is the hose sloping downward from the unit with out any kinks or twists. Most dehumidifiers rely
entirely on gravity to drain the water by hose. It will not drain up and over anything.
3. Is/was there a knockout plug on the dehumidifiers hose connection, that was not removed?
4. Is there a clog in the hose? If so, the water will divert to the bucket.
5. The unit's hose connection or interior tubing is clogged. To solve this problem do the following.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connector hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Then monitor the hose for water flow.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 27, 2011 | Soleus Dehumidifiers
The water doesn't drain through the site to which I attached the hose. Instead it drains through a quarter inch hole (which appears to be a manufaactured hole, not a crack or break)to the right of...
It sounds like the unit should have came with a plug for the hole. You can probably obtain a plug from a home improvement or hardware store or even improvise one yourself. Also, make sure the unit is pitched so that the water actually runs towards the hose.
Jun 26, 2011 | Soleus Dehumidifiers
My direct drain connection seems to have quit working. The drainage bucket fills rather than the water exiting the drain hose.
The line may have "gunk" built up in it. I would suggest checking the drain line to make sure it is not blocked.
Sep 10, 2010 | Haier 45-Pint Dehumidifier
Haier 30 pint dehumidifier continuous drain problem.
Aug 24, 2008 | Haier Dehumidifiers
Dehumidifiers Logo
Top Soleus Dehumidifiers Experts
jeff5may32
john h
AZBen
AZBen
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
