Question about Kitchen Ranges
Eurolec gas oven wont stay lit - Kitchen Ranges
SOURCE: EUROLEC 3572 9506 LPG GAS OVEN
OK sista62, here is your solution. The problem is that the thermocouple that controls the valve supplying gas to the ovenjet is not working. A new thermocouple is available from http://blgas.com.au/online/category4_1.htm and will cost about AUD$40.00.
The control valve is located right behind the knob on the frontpanel (the centre one that controls both the oven and the grill.) You will see two small copper tubes going into the control valve. These are the thermocouple tubes, one comes from the griller and the other from the ovenjet. All the other knobs only have one thermocouple for each of the topplate burners.
If you want to test before you buy, disconnect the thermocouple from from one of the topplate burners and connect it to the one for the oven control valve. Now turn on the topplate burner and keep it going by holding the knob down on the front panel for this burner. Now light the oven burner and it should stay on.
Good luck.
Posted on Feb 01, 2008
  • 42 Answers
SOURCE: OVEN WILL NOT STAY LIT
sounds like you have faulty ignitors . replace the ignitors and you should be good to go. if you post your model # i can get you a part #
Posted on Dec 21, 2008
  • 12 Answers
SOURCE: gas oven won"t stay lit
you eaither have a bad regulator from the tank to the house or you have a bad appliance regulator behind your appliance you would need to check the pressure at the appliance if it is propane you should have between 10-14'' of water colum or if it is nat-gas it should be 4-7'' of w/c
Posted on Feb 20, 2009
SOURCE: Garland H283 gas range. Right oven wont come on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Posted on Mar 30, 2009
SOURCE: amana gas oven will not stay lit
i'm having the same thing happen to me however the broiler works fine.
Posted on Jan 15, 2010
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
Oven wont stay lit
If you are talking about the little flame that is supposed to be burning at all times then you need to go to a hardware store and purchase a thermocouple. It is a small copper tube that sense's the flame. When working it will constantly burn a pilot flame so that when you turn on the oven it will ignite the gas in the burner. Once the burner is lit it will stay lit until the oven reaches the desired temperature. Replace the THERMOCOUPLE.
Sep 09, 2011 | Belling Solitaire G755 Gas Kitchen Range
Gas wont stay lit after ignition
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | New World G60m Gas Single Oven
It is gas push knob in for oven to light and it wont stay lit
If it will light but not stay lit then the thermocouple is bad... replace the thermocouple and you'll be good...
heatman101
Dec 11, 2010 | General Ovens
Hi, got old Eurolec Gas oven/hob. Hob lights up fine. Was cooking in oven all morning, no probs. Tried to light oven for evening meal & gas will not stay lit, goes out once ignitor & temp' dial...
Hi, your thermocouple is faulty, it is the little probe like thingy that sticks up into the pilot flame. It is there for safety purposes, detects flame and holds a valve open magnetically to allow the gas to pass through. Try giving it a clean with a scourer, sometimes works, or your pilot flame is not big enough, could be low on gas or unit needs a service Kristian KJ Tech
Sep 15, 2010 | Microwave Ovens
Beko SCG 7521 gas cooker flame won't stay lit in oven.Once you light the flame in the oven & hold in the oven button for the recommended 10 secs it cuts it's self off when you release the oven...
bloody hell that is so scarey i have the same problem and its round about the same time yours went funny if you have a solution can you let me know as im looking for the answer myself klass-a@hotmail.co.uk
Oct 08, 2009 | Ovens
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
