Question about Refrigerators
LGHC2342L cooling issues
Problems regulating freezer temp goes up and down from 6deg. to 11deg. should be at 0 deg. while refrigerator maintains constant 38 deg. doors shut tight, tried reseting control pad, tried unplugging and then temp shot up to 22deg immediately, fan seams to be running fine but. what should i do? is it malfunctioning ?????
  • 351 Answers
SOURCE: "Refrigerator/freezer runs continuosly but temp never goes below 42 deg in refrig or 18 deg in freeze"
well i hate to be the one to give you the bad news but most likely a bad thing... your compressor is 1. either weak, or 2 you are running low on freon....
Posted on Apr 28, 2009
woodchuck789
  • 4070 Answers
SOURCE: I have a 4-yr old Electrolux 22.6 counter-depth
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Jan 07, 2010
  • 256 Answers
SOURCE: Side-by-Side: Refrigerator will not maintain temp
Your problem may be with:
* the "damper control assembly", which is located in the upper left side of the fresh food compartment. This control regulates the amount of cold air originating from the freezer compartment that enters the fresh food compartment.
* there may be an issue with the "fresh food temperature control assembly"
Check the temperature settings in the fresh food compartment (should be located up front). I recommend the "one-half way mark" for both freezer and fresh food compartments.
Contact an appliance service company.
Posted on Feb 20, 2010
Sea Breeze
  • 4655 Answers
SOURCE: freezer runs constantly. food freezes in bottom
I see this happen a lot on these models. The defrost control board is part of four operations. If you changed the Defrost control board then one of the two thermostats is not responding to changes in temperature settings. For freezer if turning the thermostat warmer should cause the compressor not to run as much and open the damper and regulate. If the only place the thermostat setting is placed to off and it responds only to off I would believe that thermostat is the reason. I believe you are on the right track to repair but if you have a look at the wiring diagram you see the connection and point I'm trying to make here. Let me place the diagram and send you a link shortly, Thanks, Sea Breeze
heatman101
  • 43501 Answers
SOURCE: I have a maytag MFC2061HES.
I agree with you about the board....it is more likely that the relay in the board is causing the problem them the motor...
Have not checked the prices, but if the motor is alot cheaper, I would probably change that first being the your basically grabbing at anything anyway....
There is really no way to test this and know for sure what the exact problem is...
heatman101
Posted on Dec 27, 2010
How to set freezer on LG Bottom Freezer LRFD22850
Hello Fran Miller,
For OPENERS... (my opinion)
always start by setting you temperatures at mid range.
Owners manual... Page 16
Setting the controls 16 - 17 Adjusting control settings...
http://www.searspartsdirect.com/partsdirect/user-manuals/LRFD22850ST-LG-Parts-Refrigerator-Parts-manual
I get a little PUSHY about FOOD TEMERATURES...
(stored poorly there's no quicker way of poisoning ones self)...
I strongly recommend getting TAYLOR refrig/freezer
THERMOMETERS (like Amazon... cheap = $6 ea).
Let the refrigerator stabilize EMPTY 24 HOURS
Loaded with food (not recommended: 72 hours).
ADJUSTING CONTROL SETTINGS
Give the refrigerator time to cool down completely before adding food. It is best to wait 24 hours before you put food into the refrigerator. The mid-settings indicated in the previous section should be correct for normal household refrigerator usage. The controls are set correctly when milk or juice is as cold as you like and when ice cream is firm.
THERMOMETERS
Amazon com Taylor Refrigerator Thermometer 20 Deg To 80 Deg 3 1 4 3 3 4...
Hope I am helping
Carnac the Magnificent
Jul 11, 2017 | LG Refrigerators
The Refrigerator's Freezer is not working but the fridge is, what is wrong?
You probably have one compressor that cools the freezer section and the refrigerator section. Usually the freezer gets cooled directly with the cooling coils. A fan blows cool air to the refrigerator section. The air flow to the refrigerator may be modulated with some time of "air door". What you have written says to me, is that the fans and air doors are working but there is enough cold for the refrigerator but not enough for the freezer.
Here is what I would do:
  1. Put a thermometer in the refrigerator and in the freezer.
  2. Be sure the coils underneath or behind the refrigerator are clean. If they are very dirty, clean them.
  3. Keep the doors shut for at least 12 hours and then read the thermometers and write down the temperatures.
  4. Freezer temperature
    1. If the freezer has started freezing again, you fixed it by cleaning the coils
    2. .If the freezer temperature is between 0 deg F and 32 deg F, consider putting the food in a cooler and packing in some dry ice to try and save it.
    3. If the freezer is warmer than 32 deg f, throw away the food.
    4. Doctors and hospitals are pretty expensive. I would throw away the food no matter what the thermometer read.
  5. Look inside the freezer at the cooling coils. See if they are ice coated or not.
    1. If the freezer is above 0 deg F, and the coils are ice covered, the defrost control is not working. Unplug the refrigerator for 12 hours and let the ice melt. (Keep the doors shut.) Then, plug in the refrigerator for 12 hours and check the temperature like in step 3.
    2. If the freezer is above 0 deg F, and the coils are NOT ice covered, the compressor is not working.
  6. Call the service technician. When she comes out show her the temperatures and tell her what you found out about the ice on the coils.
Good luck
Jun 07, 2015 | Refrigerators
Ge freezer temp changes from -3 to 44degs and the ice melts and runs on the floor. I replaced the main board about 2 yrs ago, help?
Self defrost mechanism appears to be ok sinc eyou can get down to -3 degrees. The culprit in this refrigerator is the temperature regulator or electronic thermostat in this box. It should not allow the temp to swing that drastically from one extreme to another.
Mar 17, 2015 | Refrigerators
Freezer too cold
Is this a model=>FGHC2342LF Sounds like the freezer=> 240597203 Thermistor may be defective??There should be one in the freezer that regulates the temp and this one may be causing the compressor to run continious and you may not be getting the correct reading from freezer. Have you seen this?
Sea Breeze
Jan 06, 2014 | Frigidaire FGHC2342LF Gallery Series...
Why does the freezer portion temp indicator bounces between 0 and -12 degrees periodically.
Temps should fluctuate, as the refrigerator will go into a defrost mode every so often. Some models will go into defrost mode after you open the freezer door X amount of times, say 6. So every 6th time you open the door it will go into defrost. Then some models go every 4 to 6 hours depending on settings. Then also, it is normal due to temp control. Temp setting is -10 The fridge will run to that temp setting, -10 and shut off the compressor at -10 but due to pressures it will still cool a bit to your -12. it will stay in this off mode until the temp rises 8 to 10 degs. then kicks back on the compressor. Again due to pressures it may take the system 2 - 3 degs to catch back up and start cooling again. But you maintain average temp of -5 to -6 which is great for frozen food and saves a bit of electricity. As long as the door seals are in good shape and you clean the coils underneath once twice a year it should work fine for many years. Then lastly It may have a lag in the thermostat meaning it has gotten week or going bad. Hope this helps.
Jan 10, 2011 | Frigidaire FRS3R5EMB Side by Side...
Side-by-Side: Refrigerator will not maintain temp below 50 Deg. Freezer works fine - where is the problem? Model Number MSD2757AE
Feb 19, 2010 | Refrigerators
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
