Question about Motorola Mobility RAZR V3
Cannot access phone book
Good day... I do have a problem with the D&G version. when i press the phone book, it goes back to the previous menu. I cannot access completely the phone book. I've found out that a number has no name on it. It happened to me in my E398. I've access the phone book by immediately pressing the phone book option and quickly prssing a letter so i can access the phone book. But in D&G, i can't do it. I've tried storing the no name number in quick dial but i can't edit the name of it. I would really appreciate it if someone can find the answer. Thanks...
  • 43 Answers
Haha simple flash back with any flex compatible with your phone SW.
Posted on Aug 30, 2007
How to change phone back to default settings
You can erase the previous user's voicemail access number by pressing the [MENU] button, [#], [3], [3], [1], then press and hold the [CLEAR] button until all digits are erased. Additional details can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/KXTG6511-MUL.PDF#page=43
May 22, 2014 | Panasonic KX TG6512 Twin Cordless Phone
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
My nokia c3 radio doesnot work. when i select the radio option nothing happens even after connecting the headset. please help.
Update your Phone.. to back to original setting then update for new firmware heres the guide just follow me
-Make sure have 75-100% of battery life other wise charge your C3 first (Required before updating -Go to MENU >Setting>Connectivity>WLAN>Available WLANs.Select your Preferred Scanned network ,then connect -Go to Menu > Setting > Phone > Phone Updates > DOWNLOAD. Phone Software -Choose your connected WLAN Server -"Updating.." /just follow the on-screen instuctions. -Phone Will restart -Done check your current version by typing *#0000# hope it will helps you :)
Jul 14, 2011 | Nokia C3 Cell Phone
How can i unblock a previously blocked phone number from my blackberry phone
Hello.
First, access your Block List:
  • 1 Press the "Menu" key or option from the home screen on the BlackBerry.
  • 2 Scroll to and select your "Address Book" icon.
  • 3 Click the "Menu" key when your Address Book list appears.
  • 4 Select the "Manage Numbers" option.
  • 5 Click on the "Block List" option.
  • 6 Select "OK" or "Yes" to access the block list in your address book.
Then, remove the number:
  • 1 Select the option for "Number" or "Unknown Numbers" from the block list.
  • 2 Delete the number that you want to unblock or remove.
  • 3 Press the "Menu" key when you are finished.
  • 4 Scroll to and click the "Save" selection.
Hope this helps.
May 26, 2011 | Cell Phones
How to set the packet data setting for nokia 5310?
  1. Press Menu
  2. Choose Settings and select
  3. Scroll down screen to choose Configuration and select
  4. Scroll down screen to choose Personal config. Settings and select
  5. Now, press Add (visible if you don’t have a previous Personal Setting created) or press the Options button. when you have pressed the Options button, choose Add New. Then you will have several options to choose from.
  6. Now, scroll down and choose the Access Point and select.
  7. Choose option Access point settings and select
  8. Go into Bearer Settings
  9. Now, choose Packet Data Access Point
  10. Now, enter your APN address corresponding to your operator, then press OK
  11. Now, go back to the Personal Configurations Settings menu (press Back 3 times), where you now should be able to see an Access Point (or called My access point) selected.
  12. Now press Options button, and then choose to activate the Access Point.
  13. Now you should be able to access internet.
Aug 10, 2010 | Nokia 5310 Cellular Phone
How to access and use Video for Motorola RAZR cell phone?
1)Press the Menu key-->Select Multimedia-Videos
2)View videos on memory card
or phone memory by pressing->Menu key, then selecting
Switch Storage Device
Memory Card or Phone
3)Select a video and press Play.
4)Scroll up to pause/play.
Scroll down to stop.
Scroll right/left to skip to
next/previous video.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 30, 2010 | Motorola Cell Phones
Setting up your voicemail
I bought and Uniden Dect 6.0 phone and the other day I had a voicemail msg but I can't retreive it how can I do that the book doesn't show how to set up for voicemail
Nov 15, 2009 | Lands Phones
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
Apr 06, 2009 | GE Telephone
Gives wrong time and day
This is from the Manual. If you want the whole manual, at the end of the instructions, there ia a link to the manual.
Setting Day and Time
Day & Time sets the day and time of your display.
1) Enter the Global Setup menu, and then the Day & Time
submenu option (see "Entering the Menu" on
page 17). Image is for the base.(Here is how)
Entering the Menu
1) In standby mode, press the MENU soft key.
2) Use volume up/down to move the pointer to a desired
main menu (DirectLink Mode, Room Monitor, Handset
Setup, Base Setup, Answ. Setup, Global Setup, and
Deregister HS).
3) Press the OK soft key to select the desired main menu.
To return to the previous screen, press the BACK soft
key.
4) Use volume up/down to select a desired submenu and
then press the OK soft key to enter.
5) In the submenu option, use volume up/down to select
an item. Press the OK soft key to confirm your
selection. For detailed instructions, see the following
sections for the desired submenu option. To return to
the previous screen, press the BACK soft key.
6) To exit the menu, press end on the handset or cid/exit on the base.
2) Press volume up/down to select the day of the week,
and then the → soft key.
3) Press volume up/down to set hour, and then press the → soft key.
4) Press volume up/down to set minute, and then press the → soft key.
5) Press volume up/down to choose A M or P M, and then press the SAVE soft key. You
will hear a confirmation tone.
http://www.uniden.com/pdf/TRU8885-2om.pdf
Jan 08, 2009 | Uniden TRU8885-2 Cordless Phone
Phonebook access
i can help... i have incurred this problem a couple of times and understand the frustration! firstly, the reason why snd how this problem occurs is you have saved a number to your phonebook without a name and this causes the phone book to wig-out! to fix the issue simply press "1#". This will allow you to view your phone book in its speed dial order. Scroll through this menu until you find the saved number without the name and DELETE it. This will immediately bring your phone book back to normal. Good luck!
Dec 22, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
