Question about Acer Veriton M460 Micro Tower Core 2 DUO E4500 2.2GHz Dvdr GigaBit Ethernet Wvb VM460UD4501 PC Desktop
Ports not working
No video oputput, usbs dont work or audio. When turned on the 2 fans go on but thats about it. Monitor works fine. No beeping either.
    Master:
  • 992 Answers
Do you hear the hard drive seek?
Posted on May 16, 2014
  • 62 Answers
SOURCE: lost several drivers
You can download Astra32 from http://www.astra32.com/download.htm .
It would tell you that which drivers do you require for your system.You can download drivers accordingly and install it.
Posted on Sep 17, 2008
marked
  • 6487 Answers
SOURCE: none of my usb ports
There's a big possibility that the driver for your USB and audio device is not installed properly, it will be better if you can run again the setup CD for your motherboard so all software will be reloaded again for it like the driver for your USB and audio device...
Posted on Dec 03, 2008
rwalkero
  • 82 Answers
SOURCE: can not start my computer
Plug the unit directly to the ac outlet if it is plug into a surge protector. See if it boots. Did you shut it down yesterday or was it left running? Any bad weather last night? You could try another computer memory and see it is the memory. Not sure what it could be at this point. What type of system is it?
It could possibly be a bad power supply.
I hope this helps.
Posted on Feb 18, 2009
  • 942 Answers
SOURCE: At the front of computer, the 2 usb are not working
By the way that kind of port is an optional to function, because it is not an onboard port not like the port at the back. The front port is disabled if the connector inside is not connected. If you want this port functioning you need to open your CPU casing and locate the ping which is the connector to be connected.
Regards
PCmania
Posted on Sep 26, 2009
  • 4 Answers
SOURCE: USB ports quit working on Acer E60 Desktop
Check for bulging or crusty capacitors
Posted on Jan 12, 2010
How do I get P2210 monitor to work with USB with Dell Inspiron 15R that doesn't have a VGA port
The Inspiron 15R should have an HDMI port. You should be able to connect the HDMI to the DVI-D port on the P2210 with a cable like this: http://www.monoprice.com/Product?c_id=102&cp_id=10231&cs_id=1023104&p_id=2661&seq=1&format=2 . Alternatively, you can get an HDMI to Display Port adapter. Connect either cable with the notebook and monitor both off. Then turn on the monitor before turning on the computer. Pressing F1 should send the signal to the monitor. However, if you right click on the desktop (anywhere there isn't a program or icon), you should see some links for DIsplay options. You can use those to select the monitor resolution and whether to use both screens (extended or mirrored) or one at a time.
The most expensive option would be a USB to video adapter, see http://www.startech.com/AV/USB-Video-Adapters/ , or docking station. These come with VGA or other video output ports depending on the model. The USB ports on the monitor are just an integrated hub to plug in an external devices. It doesn't communicate to the display.
I hope this helps.
(The DVI to HDMI cable doesn't supply audio but that doesn't matter in this case. However, you may need to go into the Manage Audio devices control panel and disable sound on the HDMI port. Open the Control Panel (Windows + X in Windows 8 or from the Start Menu with Windows 7). Go to Hardware and Sound and then look for Manage Audio Devices under Sound. In the playback tab, adjust the default audio device by right-clicking on the appropriate device. Then click Apply.)
Jan 25, 2015 | Dell P2210 22 inch Monitor
No sound
Sounds like a loose connection that has finally failed in the audio out circuit
Jun 04, 2008 | Hitachi 61HDX98B 61" Rear Projection...
Usb ports dont seem to work
In order for the usb ports to work you must have 1 usb from the computer connected to the monitor. The monitor may have a specific input port from the pc in order to activate the other ports on the monitor
Mar 22, 2014 | Dell 1704FPTt 17" TFT LCD Flat Panel...
My Dell Inspiron does not boot up only the solid amber light on the Motherboard on I try everything and still nothing works please help
Not so sure about this but I hope this will help.
-try to disconnect all the cables from the back (monitor, keyboard, mouse, usb's, power cable, etc.)
-then disconnect all the card (video card, sound card, NIC) if all are integrated then you dont have to.
-connect just the power cable
-try to turn on the computer and check if it beeps
-if it does not beeps need to replace the motherboard but before you do this check if the fan will spin even for a single second if does not spin then you also need to replace the power supply as well
-if it beeps then turn it off again.
-connect the video card and connect the cable of the monitor, keyboard and mouse
-turn on the computer then check if theres any display
-if theres no display check for any beep indication. and right it down on a piece of paper on how many times it beeps and if its long beep or short beep.
kindly provide an email if this things does not work so that I can give you a resolution.
Apr 01, 2011 | Dell Inspiron 530 Desktop Computer
Computer does not display any boot screen, although it turns on. no USB ports work, not do any other inputs on the rear of the machine. this was done after migration of parts to a new case for the...
DC5000MT (i think you left off the"T" right?) MT=mini-tower then.
they at SFF then too.
old old desktop pentium 4, with pata hard drive?
no monitor stated, make nor model #
no vga card stated.
migrating? oops.. why do that? nor if PC ran before?
NO OS stated,? windows XP what? (it came with XP)
ok the mobo turns on with case power button?
and the CPU fan spins fast, as does PSU fan?
what does USB ports mean>? using what there?
PS/2 keyboard. using that? or pS2/mouse?
does it beep:?
are you sure the monitor is ok?
if monitor is ok ?
and PSU and 1 stick of ram is ok
the BIOS screens work.
or the PSU
does this mobo have onboard VGA jack GPU:>
if yes, try both it and PCI video card.
and 1 stick of ram at a time. slot1, bank 0
Aug 12, 2017 | HP DC5000M PC Desktop
System boots up but no image on monitor i have checked the monitor it works fine both fans are working no beeps no image what could the problem be
sounds like your power supply is toast, or your video card is improperly seated in its slot. or maybe its simpler than that , how many video ports are on the back, check your monitor cable to the computer, try other VGA ports if they exist. ( need to boot it after the connection is made)
Aug 27, 2010 | Lenovo Computers & Internet
My USB Ports on the monitor have stopped working
Try replacing the usb cable from the monitor to the computer with a new one or make sure that the cable is connected.
Feb 14, 2018 | Dell SP2009W 20 in. TV
When turned on all i get is fans constantly running and nothing else was working fine up till then
Sometimes the best answers are the simplest. First, make sure the video monitor is switched ON, securely connected to the computer video port and the "brightness" control set to at least mid-point. Before focusing suspicion on the computer itself, try a different "known to be working" monitor AND CABLE. Failing all the above you should carefully observe a manual re-start of the computer noting the presence or absence of 1.) pilot or drive indicator lights on or flashing, 2.) A beep tone or series of beeps emanating from the computer ( one beep is good - more than one is an indication of trouble requiring a technician ). 3.) Fan(s) running. If you have lights, fans, and a beep but no video, ( not even a blinking cursor in the upper left of the screen ), replace the video or graphics card in the P.C. with one known to be working. This should solve the problem.
Jan 29, 2010 | IBM ThinkCentre S50 8183 - P4 3 GHz...
E machine wont recognize the moniter or keyboard
With the limited info that you provided, it seems like the motherboard is not functioning. When you turn the computer on, does anything happen in the box?
Jul 17, 2009 | Computers & Internet
No power to USB ports, no video output
Make sure you have connected the USB's on right spot on the motherboard.
It's few places where it fits, so just try it out.
Apr 13, 2009 | Computers & Internet
Open Questions:
Acer Veriton M460 Quad won't start after running Vista Scheduler I have a new Acer Veriton M460 Core2 Quad PC running Vista Business. Something weird is happening that seem to be related to the Vista Task Scheduler. I have a complex chain of actions that start from one action. The chain is: run software to download .html files, run Microsoft software, run DOS batch files and DOS executables. It works fine if I start it from the desktop and if I start it using Task Scheduler. However, if I used Task Scheduler, the next time I boot up the PC it freezes at the Acer pre-Windows boot screen. Even the set up keys mentioned on that screen don't work, e.g. "press F12 to choose a start up mode". I have to pull out the power plug. When I plug the power back in, even after quite some time, the PC proceeds with the boot up successfully through to Windows without me having pressed the Power On button on the computer. So the bottom line is that if I use the Scheduler, my PC won't start the next time I go to use it. There was an event that may have some relevance or could be coincidence: about a week ago after I first scheduled the task I came back to my PC, which had run my scheduled task unattended after waking itself from Sleep Mode. I found it showing not Windows but the PC boot options menu. I pressed the highlighted option, which I think was Normal. This hasn't happened since but could be related. Incidentally, my PC was supplied with Sleep Mode set to start after 20 minutes plus there is a screen saver. But neither was going when I last used the scheduler for my task. Any ideas?
Feb 28, 2017 | Acer Veriton M460 Micro Tower Core 2 DUO...
Acer Veriton M460 Micro Tower Core 2 DUO E4500 2.2GHz Dvdr GigaBit Ethernet Wvb VM460UD4501 PC Desktop Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
