Ge hydrowave washer
Why doesn't my washer fill the tub before it starts washing?
Oceti
  • 51 Answers
SOURCE: GE WHRE5260E1WW Washer
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
Posted on Jan 23, 2008
  • 130 Answers
SOURCE: Wash cycle won't start after the tub fills up with water.
There's no delicate or regular spin or agitation If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Posted on May 07, 2009
SOURCE: no agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Posted on Jan 21, 2010
  • 11 Answers
SOURCE: GE washer model WHDSR209
On some models, the drive motor is universal meaning the drive turns clockwise in wash mode and turns counter clockwise in spin mode.
Possibly the motor windings is defective for the wash mode and thus the entire drive motor will require replacing.
Hope this helps..
Posted on Jul 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: GE Washer Model whdrr418e1ww overflows the tub!
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
GE Hydrowave top loading washer is leaking around the top side and back of unit when filling.
check for the water outlet from the water solenoid control valve
it may be displaced or broken and not directing water to the bowl
Sep 29, 2016 | GE GTWN4250MWS 27" Top-Load Washer, 3.7...
My washing machine GE HydroWave is acting up and I took it apart, where the tub is and I think there are parts missing so I want to know the parts of machine
Check the coupling between motor and tub. Most times that is the problem 2 brackets and motor comes out. If the couplings are round inside. That is the problem. Most times that happens by over loading washer or washing carpets. Bed spreads etc
Feb 16, 2015 | GE Washing Machines
Agitator doesn't run
The problem could be transmission failure
May 23, 2013 | GE WWSE5240D Top Load Washer
My Ge Top load washer will not power up start button?,no lights.
Their is a fuse in the harness red wire that runs down from the control to the motor on the hydrowave washer. Hydrowave washer manual
Of course if yours isn't a hydrowave maybe you oughta post a model number. GE has several different styles.
Mar 09, 2013 | Washing Machines
My Ge Hydrowave doesn't know what cycle it's in. It agitates when in spin cycle and doesn't spin at all.
That problem with your washer sounds like its the mode shifter solonoid,To check it use a multimeter set to ohms and measure for appx. 98 ohms on that solonoid coil.
What you can try first though is to reset the motor control baord and that remedies so many troubles with the Hydrowave washer. This tip i wrote will tell ya how to reset the motor board.
http://www1.fixya.com/support/r10292912-will_ge_hotpiont_top_load_washer_not
GENE
Sep 21, 2011 | Washing Machines
Purchased a GE washer WHRE5550kww need to know why it isn't filling to the top 'holes' when set on large/super wash?
Hello....I don't know the answer to your question, but would like to know if you like this machine in general, are you happy you bought it??? Would you buy it again? Thanks
Aug 04, 2009 | General Electric WHRE5550H Top Load Washer
No agitation in ge hydrowave rinse cycles
Dec 01, 2007 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
