Question about Craftsman Convertible 32cc Gas Line Trimmer - POULAN/WEED EATER
Remove plastic cover over recoil on Craftsman 32cc 2-cycle Hassle-Free 3 trimmer
Need to fix the recoil on a Hassle-Free 3 weed trimmer I have. All the screws are out but can't get the plastic cover to come off. Looked @ Craftsman manual but no help.
SOURCE: have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
Posted on May 10, 2009
  • 41 Answers
SOURCE: No spark Craftsman 989.796060 32CC string trimmer
I believe there is a t20 trox screw holding the clutch cover on. Look down the hole where the drive shaft would insert. After you get that off, the clutch itself needs to be pulled off of the shaft. DO NOT BEAT ON THE END OF THE SHAFT. You may need a small puller to get it off.
Posted on Aug 02, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
vincob
  • 718 Answers
SOURCE: where is the air filter
On the back of the engine.
Posted on Aug 14, 2010
hunter19_46m
  • 7482 Answers
SOURCE: 17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Posted on Sep 19, 2011
How to replace starter pull cord on model no. 358791580
I'm sure i've seen a video showing you the process on youtube of how to replace the recoil.
May 09, 2016 | Craftsman 32cc* 4-Cycle Straight Shaft...
When I pull start rope on my Craftsman 32cc 4 cycle weedeater . . . engine does not turn over . . . when I let go of the rope and it retracts . . . what is wrong?
There are 2 dogs or fingers that expand out to grab the flywheel when the rope is pulled They are sticking and can not expand or slide out. Remove the recoil unit and free them up When the recoil unit is off pull the rope and watch the action
Jun 08, 2015 | Craftsman Garden
I need a trigger for a craftsman weed eater
Go to http://www.searspartsdirect.com/
Select model number and her your model to look-up the part number and you can then order the part from them or some other dealer using that part number.
Oct 16, 2014 | Craftsman Convertible 32cc Gas Line...
Hi pmbaugardne...
Sep 19, 2011 | Craftsman Garden
Yes, I have a Craftsman 25 cc Gas Trimmer and we just snapped the starter cord. Do you have to open up the head to fix this? Does it need a special type of cord?
Yes you have to remove the plastic recoil assembly and install a certain size cord. We use a #3 or 3.5 cord on all our string trimmers, blowers with that size engine.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
After pulling the starter coil, it will not be pulled back into the machine or better said, it will not coil for another attempt at starting.
Sounds as either the recoil spring located under the the recoil housing has either broken or the plastic housing that holds the spring end has broken. you will need to remove the recoil housing to determine the problem. To remove:
1. Remove the drive tube by removing the clamp around the front of the housing and gently pull the drive tube from the engine.
2. Remove the torx or slotted screws holding the recoil assembly on
3. Remove the star washer with a flat screwdriver and gently lift the recoil from the housing.
The spring will be directly. You should be able to see the problem at that point.
Sep 27, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Repairing fuel line on craftsman 32cc weed trimmer.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
Repalce the pull cord a Craftsman Weed eater 32CC
I have a craftman weed eater model M358.796600 and the pull cord will not retract any more...how do you fix it?
Drew
Jul 02, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman Convertible 32cc Gas Line Trimmer - POULAN/WEED EATER Logo
55 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
