Question about Garden
How to remove pto casting on case 970 tractor
I need to replace some(or all) of the clutch packs in the pto of my 1976 case 970 tractor. I have removed all the bolts holding the cast housing at the rear of the tractor, but cannot get the housing to budge.
SOURCE: cannot remove pto clutch assy
You can use an impact wrench, but more than likely the bolt is unscrewed and you will need to get a set of pulley pullers to pull the clutch.
Posted on Apr 04, 2009
  • 6 Answers
SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
Posted on May 27, 2009
  • 130 Answers
SOURCE: PTO clutch stop needs replacing 2130 Cub
take cover off flywheel so you can hold it from turning.or use a air compressor on clutch bolt
Posted on Jul 21, 2009
d_hubbs
  • 270 Answers
SOURCE: I have a 2510 John
Hi, I'm David .Hope i can give you some help.
First of all I beleive if you Make Sure you Don't Hahave the Clutches Backwards,Its Easy to do this.To line them Up your going to need a Helper,Trying this by your self will were you out.
Check to make sure The Splines are the Same as the Old Clutches.Includind the amount of Teeth in Each Clutch Have Got to be the Same.
Second make sure you have Plenty of Slack in your Clutch Adjustments.Remember you just removed a Work set of Clutches.So you'll need to Back off The Clutch Adjustments.
To give you plenty of Slack.You might also want to See if your Dealer Has a Pilot Tool or Clutch Alingment Tool to Help you .
Sir I hope i've Helped you.
Please let me Know by Voting on The Quality of my Solutiuons. Thank You:
Posted on Sep 23, 2010
  • 6468 Answers
SOURCE: pto, electric clutch
check the wires they rub on sharp edges
Posted on Mar 24, 2012
Case 970 AgriKing tractor. Wont move forward or reverse, but PTO still works
cheek if the large snap ring that goes inside of the drum is not missing
Sep 29, 2016 | Garden
What are the two wires on the PTO for?
John, the wires put power to the PTO to energize clutch and make it engage when switched on. I will post a video link of simple fix for wire that have been ripped out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Repair Ripped Out Wires On An Electrical PTO Blade Clutch
lawn tractor pto wire Google Search
Troubleshoot Replace mower PTO CLUTCH
Broken PTO clutch wire JD717A
Apr 22, 2016 | Garden
Pto won't disengage, unable to start tractor. pto attached to post hole digger in ground
It could be gear bound and not allowing it to disengage, i experienced that a few times in my farming days, we dug a lot of postholes with a PTO driven digger. What usually happened is i ended up getting caught on rocks and stalled out because i had the engine speed to low. What i generally had to do to fix it was remove the PTO shaft from the digger, disconnect from the tractors output shaft, then get it started and everything moving, then disengage the PTO and reconnect the post hole digger, then give her hell and get the engine speed up before re-engaging the PTO, that would generally shock it loose. If not then i would have to disconnect the PTO shaft again and spin it backwards by hand to rotate the digger in the opposite direction to remove the hangup.
Nov 25, 2015 | John Deere 670 770 870 970 1070 Compact...
Toro LX468- Was replacing belt and a small (2") spring came loose from I think the PTO ? Also the PTO clutch should be in what position to permit belt guard installation? Does the guard go into the gr
Yess it goes into the groove to prevent clutch housing from turning and the position of the housing when install the retaining bolts.
The spring into the hole on the clutch housing and other end goes somewhere on the frame. It is being used as a damper spring.
The below should be correct.
Oct 23, 2014 | Toro Garden
How do I replace the electric pto clutch on a Troy bilt RZT 50 ?
b2b3a5a6-0c1f-4aa7-a9a9-2c36ba7a3894.gifremove center bolt holding the clutch one and watch for a spacer to fall. when installing it theres an ear that has to line up in a notch on outside of clutch to keep it from turning
Sep 14, 2014 | Garden
How do you remove the center bolt on the pto clutch
The easiest way to remove one is an impact wrench; otherwise, you would block the flywheel of the engine so it won't turn and use a pull bar.
You will need block the flywheel upon installing as you will need to torque the center bolt to about 55 ft lbs and don't forget to burnish in the PTO clutch.
Jul 30, 2014 | John Deere Garden
How to change out an electric clutch on a cub cadet zero turn RZT50?
Removal is simple if you have access to an impact wrench so you can the center retaining bolt.
When re-installing anti-seize compound needs to used on the crankshaft so the new clutch assembly doesn't seize on the shaft. To tighten the center bolt you must hold the flywheel in place by blocking it. This center bolt must be torqued to 45-55 ft fts. Also the new pto clutch needs burnishing in. Most new clutches come with instruction on this procedure.
Jul 23, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
How do I replace the Blade Clutch Assembly on a Craftsman mower, model 817.288160?
There is one bolt in center of pto clutch. Its best to have an impact to remove this. If you try to remove with a wrench engine will spin. Remove both belts first. Then simply unplug the PTO, Use impact wrench and remove center bolt and gently pry off. Installation is the reverse order.
Oct 15, 2013 | Craftsman 20 hp 42 in. Deck Yard Tractor
Adjust clutch pto
yes there is. The feathering valve spring is broke.
Aug 24, 2013 | Diesel Case 1370,1470,1570 Tractor Piston...
Garden Logo
294 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
