Need remote for auria 32 inch sound bar 40 watts model EQ 3024
5 Suggested Answers
SOURCE: Need manual and remote code for EQ3299 Auria LCD
Menards has them on sale right now, dirt cheap. Just 319.99 with a $50 rebate, making them $269. You should be able to make a copy of their manual in the store, and get the remote code there.
Posted on Oct 16, 2010
  • 10865 Answers
SOURCE: I bought auria EQ 3299
hello. Here is an article that will be of interest to you. http://www.ehow.com/how_4441981_program-dish-network-remote.html
Here is the official list of codes from Dish
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Before you go to the official list, I scanned it and there is no code listed for your TV. Therefore, do this. Call DISH directly and ask them what the code is. IF they don't have one for your TV they can create one..
DISH® - Official Site 1 (888) 359 8968 www.DISHNetwork.com
Joe
4 thumbs up please. ty.
Posted on Oct 17, 2010
  • 5472 Answers
SOURCE: i need a new remote
You can try remotes.com for an exact replacement or substitute remote. Search by the TV model number and not the brand. (Sylvania doesn't have a parts store but you may find the parts on line from other vendors. Searspartsdirect.com has parts for many appliances that were sold by Sears. Partstore.com also has some parts, including remotes for some TVs.)
Otherwise, look for a universal remote that matches the features. If the original remote had a menu button and a source or input button, you will probably want a remote that matches the feature. This is extremely important if there is no matching Menu or Source/Input button on the TV. Any remote that was programmed more than 6 months after the TV was released should have a code that works for your TV. You may need to try several codes before you find one that makes all of the features work on the TV. The USB programmable remotes are a lot faster to set up.
I hope this helps.
Posted on Jun 26, 2011
ekcnoel
  • 998 Answers
SOURCE: I have an Insignia 32
Sir try to check on e-bay.
Posted on Jul 13, 2011
What are the remote control code for Aura Sound bar EQ-3024
http://electro-medical.blogspot.com/ Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites . It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Jan 12, 2016 | Televison & Video
Can't hook up my sb 2920x-c6 to my auria eq 5888 tv where audio out jack
can't find that eq 5888 model number but does the tv have a connection labelled as spdif this is a special digital audio out standard by phillips.
http://www.hardwaresecrets.com/everything-you-need-to-know-about-the-spdif-connection/2/
I am not sure if this can be plugged into the sb 2920x-c6 digital in socket or if you need a digital amplifier between the two items ?
Someone else on fixya may know if a digital amplifier is needed or a direct connection from tv to sound bar is possible via a spdif cable.
Nov 27, 2015 | Audio Players & Recorders
I need a wiring diagram to get the color codes for a realistic 40 watt equalizer booster model 12-1954
All the wires on my 40watt realistic eq are all the same thickness and I have three red wires can someone tell me what side the power wire should be on and which color wires would go for speakers and which color go for the amplifier
May 09, 2012 | Car Audio & Video
Find the sum of all integer multiples of 8 between 33 and 3051.
This sum is equal to 40+48+56+64+72+...+3024+3032+3040+3048= 40+(48+3048)+(56+3040)+(64+3032)+(72+3024)...
There are (3048-40)/8+1=377 terms in sum. (48+3048)=(56+3040)=(64+3032)=(72+3024)=3096 and there are (377-1)/2=188 pairs whose sum is 3096. Only term that is not in such pair is 40.
Finally sum is 40+188*3096=582088.
Jul 01, 2011 | Computers & Internet
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have...
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
May 06, 2011 | Kustom Deep End 200HD 200 Watt Bass Amp...
My remote doesn't turn on my tv AURIA EQ5588, do I need a code
I also have an Auria EQ5588, the on screen prompts are the same as my APEX 32" 720p I bought over a year ago so either both are the same company or they share the same software. Both are Chinese Mfg. so who knows??? If your factory remote doesn't work call the phone # on the warranty page. There are universal remote codes listed on P. 6 of the owners manual if you are trying to code a cable or dish remote. There is also a reference to LG codes which are carried by Best Buy, Perhaps they can help you out if nothing else helps. The only glitch I've noticed is switch back to TV before turning off your blue ray player. If I turn off my Sony blue ray player and then go back to TV mode I get no sound, turn off the TV and restart it and it's fixed. Seems to be an issue between the brands. I'm pretty happy with the Auria since I got it for $700. Could have spent a lot more!!!!
Feb 23, 2011 | Televison & Video
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
