Thermostat error codes flashing E2 & won't come on
American- Carrier flashing ERROR code 2 and wont come on
SOURCE: My Heat will not work
the e2 code on a carrier comfort zone thermostat is indicitive of the external safety sensors which are located on your units ductwork in the attic. the e2 code are the hpt/ and lat sensor codes. the hpt is the heat pump temperature sensor and the lat is the leaving air temperature sensor. you can pull off the cover of the panel and behind it will actually give you all the fault codes associated with you carrier tsat.each sensor has a certain ohm rating and if its out of the range it will fail. now as to the reasons for failure, the indoor coil could be dirty, filters dirty, refrigerant charge incorrect.
Posted on Dec 22, 2008
  • 38 Answers
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Posted on Jun 30, 2009
SOURCE: Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
Posted on Aug 09, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
SOURCE: I have error codes flashing
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Posted on Sep 21, 2010
American standard error code 158
thermostat error codes for an american standard ... - AllExperts
en.allexperts.com > ... > Heating, Air Conditioning, Fridge, HVAC
Aug 22, 2010 - programmable thermostat, error codes, american standard: James, I am not familiar with that stat set up,short of goggle/yahoo the codes may ...
Jul 24, 2015 | American Standard 5000 Heat Pump Unit
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Totaline Thermostate P274-1100 works fine when following programming but when I adjust the temperature manually it will start the furnace and after a few minutes the screen displays E2 error, blanks out,...
E2 is the error code for low line voltage. I would think that this is a erroneous code witch would indicate that the thermostat is defective. do you know if this is true line voltage 120v or transformer voltage 24v?
Mar 05, 2014 | Carrier Totaline P291-1003 Capacitor 10mfd...
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Getting error code e2 and
U2 this invalid or undue motion scanning device, lamps or copiers panels. It is Necessary to make sure that 2 and 3 mirrors are not bolted screw for transportation, they are found with left side, where the mirrors 2 and 3 stoped . For checking remove glass and try to move the scanning device. Avoid the reason of the stop. If no, search for the fault in sensor, on the left and on the right on движени скарующего device, they can be запылены. opposite event follows to call the service engineer.
Sep 10, 2009 | Office Equipment & Supplies
Jun 29, 2009 | Carrier 38CKC060 Air Conditioner
I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Jun 24, 2009 | Carrier 38CKC060 Air Conditioner
My Heat will not work on my upstairs unit. I am getting an E2 error code on my carrier thermostat. what does that mean?
Dec 03, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
257 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
