Question about Sony DCR-HC26 Mini DV Digital Camcorder
Red screen Hi, i recently purchased the camcorder and i now have a completely red screen when i turn the camcorder on, as well as a dark red line down the left side, can anyone help me with this?
    An expert whose answer gotĀ voted for 100 times.
  • 206 Answers
CCD sensor faulty and Sony agent will very likely do this repair free of charge. 1 hour labour max to replace the faulty CCD block : does not reqire resetting the camera and the component in question is easy to access but you have to have a new CCD block.
Posted on Aug 29, 2007
I dnt know which button is to turn the camcorder would somebody help me
To turn on the camcorder press the red button to the left of the screen when the screen is open. To turn it off either close the screen or press the same button for 1-3 seconds
The red button looks like an 'o' with a line coming out of the top of it.
Aug 09, 2011 | Aiptek A-HD 720P Flash Media Camcorder
Red arching lines showing up on screen promident when a dark background is present
Red picture tube needs screen voltage adjust. Open fornt or back of TV and look for a black square looking box with adjustment knobs. Look for red screen adj and slowly turn rt or lft until lines just disappear. If screen goes too bright tv will shut down, just turn back on again and retry
Dec 04, 2009 | Sony Televison & Video
Panasonic SD H80 Lens cover
Make sure gas valve is turned on. Make sure spark plug is not soaked. If has has a primer, only prime it about 3 times. No more than 5
Jul 03, 2009 | Panasonic SDR-H40 HDD Camcorder
Dark screen red arched lines
turn down the red screen control slightly the box is located behind the grille 6 knobs on it look carefully for the screen making on it for red do not adjust any other control best done in a dark room with no source in a video input if the tv will not auto align you have the control backed off to far
Oct 06, 2008 | Sony KP-46WT500 46" Rear Projection...
Red Bowed Lines / Red Hue
I tried the solution that was posted for this problem and it worked!
Just remove the Low front panel by removing the two bottom screws that are covered by two screw covers, then remove the second panel (black) by removing the 4 screws then you'll notice a module with 6 adjustment knobs, get a small screw driver, and with the t.v. on, being carefull , and with somebody accross the room looking at the screen begin with the lower left knob and turn left very slowly and ask the person across the room to let you know if the screen is better or not, after this I had to adjust the green as well so, I adjusted the next knob over to the left. Do this adjustment carefully and try to remenber the original position of the knobs in case you have to go back.f
Good Luck,
Jun 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Blue and red arched lines on screen when background dark
Sounds like you are describing retrace lines that could indicate that your CRTs or something in the drive circuits are bad.. Check the resistors on the CRT sockets to see if they are in tolerance. If they are try turning the red and blue screen adjustments down just a little this should take the lines away. You will however be needing service in the not to far future. Turning the screens down should help if the resistors check out. Let me know if you need anything further.
Jan 31, 2008 | Sony KP-48S35 48" Rear Projection...
White screen on LCD and two vertical lines-1 red & 1 blue
Hi, check the lense. It might be dirty or you may have left the lense cover down.
hope this helps,
Dec 31, 2007 | JVC Everio GZ-MG130 Camcorder
Thin Red Lines on Top of Screen
Sorry, that is common for generic replacement xformers for
your make / model . There are some adjustments to minimize
the effect in servicer can try turning down the
screen control a bit....................T.
Dec 21, 2007 | RCA F36650 36" TV
Red lines on screen when recording
Important Notice
Digital 3CCD Camcorder
Panasonic has discovered a premature component failure with a limited number of PV-DV953 (2003 Model) and PV-GS200 (2004 Model) 3CCD camcorders, which may cause an abnormal camera picture (incorrect color reproduction, reddish, noisy image, etc). This anomaly is limited to a specific range of serial numbers listed below.
If your camcorder demonstrates the specific symptom and falls within the serial number range, Panasonic will repair the camcorder free of charge.
Please call the following toll-free number for assistance in receiving a free repair:
Panasonic Call Center: 1-800-973-4264
Model # Serial Number Ranges
PV-DV953 (2003) E3Hxxxxxx, F3Hxxxxxx, G3Hxxxxxx, H3Hxxxxxx, I3Hxxxxxx, J3Hxxxxxx, K3Hxxxxxx, L3Hxxxxxx and A4Hxxxxxx
PV-GS200 (2004) C4Hxxxxxx and D4Hxxxxxx
Nov 19, 2006 | Panasonic NV-GS200 Mini DV Digital...
Sony DCR-HC26 Mini DV Digital Camcorder Logo
95 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
