Wd10tmvv my computer not recognize still have led power but cant read my external hard disk please help
Crankstart
  • 696 Answers
SOURCE: wd my book device usb device not recognized by computer
Hi, Take the drive to a pc store and ask the techs to move the HDD into a new shell and test it for you. Most likely it's ok and you can just buy a new shell/enclosure for it. If that doesn't work it may need the help of a recovery pro. If that's the case comment back here with your country/state/city and I'll pass on a recommendation for a nearby facility that can assist you in retrieving the files. Chris
Posted on Jun 09, 2009
  • 81 Answers
SOURCE: My WD 2T external My Book hard drive is not working
You will need to try formatting the drive. You can do this from the drive management section on the Mac.
Posted on Jul 10, 2009
kamal1984
  • 1383 Answers
SOURCE: Transcend 160GB Portable Hard Disk is not recognized by computer
when you power up the computer press F2 or "del" key to enter in bios then go to usb option and enable usb 2.0 legacy. then save settings .
then check.
some times usb speed make issue so try this.
Also check your usb cable working fine try with other usb cable.
Also check harddisk jumper settings.
If still face problems then you need to repair it.
You shuold take it to service shop becasue you try with 10 computers and all gives same error then your harddisk has hardware issue.
try above solution .
Thanks for using fixya.
Please rate my solution if it helps you.
Posted on Jul 20, 2009
bob_computer
  • 3153 Answers
SOURCE: usb2.0 hdd external hard disk-unrecognizable device
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Dec 08, 2009
SOURCE: my iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Posted on May 23, 2010
My Hard drive dosen't work again the system could not recognize it.
Good Day.
Don't know if your external hard drive has power led on it, that comes on when connected to the PC. If it has these led, does it come on when connected to the PC? If no, then I believe there's is problem in the connection within the external Hard disk. So maybe you buy a new cord or you just have to change the connection panel or buy a hard disk casing that has the panel for connection in it.
Or, if the led give light, do you feel any movement (or rolling) within the external hard disk when connected? If yes then it's still working, just try the first recommendation.
I hope this helps. Thanks for using FixYa!
Sep 10, 2012 | Western Digital Elements Computers &...
The Samsung Freeagent GoFlex external hard drive is not recognized by Windows 7 OS. I tried to initialize disk under computer management / storage / disk management and got the cyclic redundancy check...
This is a good read on what this error actually means:
http://www.softwarepatch.com/tips/cyclic-redundancy.html
What I recommend is reformatting the drive under Computer Management, and seeing if that fixes the problem.
May 03, 2011 | Seagate FreeAgent GoFlex Pro 500 GB USB 20...
Dear sir, i have a wd1600xmsb external usb. it fell flat on it's bottom on top of my cpu (about 1-1/2 ft. high). my computer cannot recognize it, but it's blue led light lits when it's plugged to the usb...
your disk motor is stuck and not turning the disks from being compressed from the fall. you will need to take it to a computer shop that agrees before they work on it they will be able to save your data. tell them exactly what happened
Dec 27, 2009 | Western Digital External USB 2.0 80 GB...
Hard drive not recognized
hi I am using Hitachi external hard disk with aluminum case. When I connect my hard disk with my PC it is not recognizing my hard disk. I want retrive my data from the hard disk please let me know the solutions.
Thanks,
K.Venki
Jan 07, 2009 | Computers & Internet
Computer cant find driver software
sir maybe your hard drive is already damage or *********** board is damage so sir to isolate this problem first if you have a spare hard disk or borrow from your friends or try your hard disk to another computer using an External IDE connector or simply do it the old way, and sir you if you could put more details please regarding the trouble so that i could help you more. thnm yousir for using this service please give us a feed back regarding the problem. thnk you and fixya
Dec 14, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Don't read the HD
Clarification please:
What????
What kind of computer, os, internal or external hd's?
Oct 09, 2008 | ASUS A7N8X-X Motherboard
External hard disk is not recognized.
IF YOU CANT RECOVER DATA MAKE SOME ARRANGMENT TO SENT IT TO MY FACTORY
AVAIL THIS METHOD
more assistance 0-9-3-2-1-1-0-1-7-1-7-
s-k-y-p-e- a-n-a-e-s-a-r-o-r-a
Jul 23, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Turns on but nothing else
I have been using this hard disk for about 6 months now. It stopped working. The power and the usb cable are connected. I use Windows Xp and it doesnt read it. And for some reason most of the time when i open 'my computer' and the hard disk usb cable is plugged in 'my computer' stops responding !! However the 'safely remove disk' icon comes on the task bar and i can remove it from there. But i cant read it from explorer. The light on the HD keeps blinking. It reads my friends HD and flash drive. Please help me.
May 23, 2008 | Western Digital My Book Essential 500GB...
Western Digital Elements Drive Problem
check the drive on any other system.
may be last time you were using the drive and system carsh or improper shutdown this can cause the drive damage.
Also may be a virus format the disk and try it.
Jan 06, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Computers & Internet Logo
330 people viewed this question
David Payne
David Payne
