Question about ASUS R503u-rh21
LAPTOP SCREEN i had accidently closed my asus laptop screen with my charger cored in the middle while the laptop was charging now halft of my screen is solid white with vertical/horizontal color lines along with black blobs .. please help me.
Joed911
  • 4338 Answers
SOURCE: charging my asus 701 laptop
Usually what happens is that the ac connector on the laptop get loose. It happens when you wiggle the ac adapter out rather than pulling it/pushing it straight in. You can check if this is the problemsby
powering off the laptop. Insert the ac adapter. just slightly wiglle it. if it wiggles at all, then this is the problem. It can be fixed by resoldering the connector back on the System board, which entails taking the laptop completely apart.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 13, 2008
SOURCE: Screen black and no windows
1 Remove the battery
2 Hold the power key down 30''
3 Put back the battery
4 Try to turn on you computer
can you see anything(by pulling the screen down ?fade light) on your screen??
try to connect it toa monitor. ( if it work ) you might have a back light issue
Posted on Nov 09, 2009
parrotheadpc
  • 2600 Answers
SOURCE: blue vertical line on my desktop
The blue lines are a sign that the screen itself is failing. You can try to reseat the data cables from the motherboard to the back of the screen, but in most cases this is indicative of an immenent screen failure.
Posted on Jan 13, 2010
big_al_1982
  • 95 Answers
SOURCE: screen turn to white & cant recovery the system
I would reinstall windows sounds like the update corrupted it.
Posted on Feb 23, 2010
Davethesnake
  • 689 Answers
SOURCE: Horizontal white lines on screen on ASUS netbbok
This is symptomatic of battery problems at a vague guess
Posted on Sep 03, 2010
Why my computer screen black no sound when I turn on or pictures lights for charger work and lights on Asus laptop1000ha
Sounds like your laptop is not powering up. I'm aware your charger led light lights up. How you described your laptop symptoms, it's not booting up, the screen is not displaying nor any sound. You may have a bad battery or your charger.
Jul 22, 2016 | ASUS Computers & Internet
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Aug 10, 2014 | Sony SVE15135CXS - VAIO E Series...
Won't Charge
If it's not a recognized charger it'll stop charging the battery and try to run on the charger alone. If the peak draw of the laptop is higher than the charger output, it'll go right back off.
Try removing the battery and see if it'll boot on the charger alone.
Apr 01, 2014 | ASUS Q200e Touchscreen Notebook
Hi I have a serious problem with my laptop, sometimes the laptop will blink to a black screen and won't do anything. The laptop is still on but won't do anything so I am forced to hold down the power...
there might be a problem with your charger maybe it is giving in some extra power that your laptop is unable to handle...try charging it with another charger
Oct 27, 2013 | Apple Gateway P-7811-fx Gaming Laptop Core...
I have got apple macbook pro unibody , my charger light is blinking and not charging battery while my laptop is on but when i shut down my laptop its connecting and disconnecting for 10 seconds interval
Try charging your laptop with a spare charger. If your laptop is still under warranty, make an appointment with a genius bar representative at a local Apple store to diagnose your laptop's issue and replace the charger.
Warning!
Do not use the USB ports to charge any external devices from your laptop! Instead use the chargers they were packaged with.
If the spare charger doesn't work after an hour of charging you will have to reset the System Management Controller with the Mac turned off:
Press Shift-Control-Option-Power key combination.
Release and press the power button.
If resetting the SMC doesn't work try resetting the PRAM. Keep in mind that you have to enter the key combination before the grey screen appears!
Reboot your laptop.
Immediately hold down Command-Option-P-R combination.
A reboot sound should confirm the reset.
Aug 26, 2013 | Apple MacBook Pro Laptop Computer with...
I cannot get my Asus U52F laptop to turn on.
Unplug from AC, remove battery, plug into AC , boot normally.
Dec 06, 2012 | ASUS U52F-BBL9 Laptop
Battery does not charge in new Asus K55VD laptop
i have same probliem in my laptop Asus K55VD if i put a charger it get on other ways a massege showing that Battery is not avilable.
i think its could'nt help battery is ok i buy it yesterday and its genuine new i don't know whats happend can someone else help me
Oct 25, 2012 | ASUS K55vd-db51 16" Led Notebook - Intel...
ASUS R503u-rh21 Logo
22 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
