Question about Bosch DHD 865 Stainless Steel Kitchen Hood
DHD 965 Doesn't Work
The DHD 965 is dead. The light on all of the buttons blinks rapidly when pressed, but nothing happens.
0 characters
1 Points
Troubleshoot Bosch DHD8005UC downdraft system which has ceased to raise & lower automatically?
While I don't have a schematic, there is not much to the system. In my case, I removed the entire unit (stationary and mobile parts) and cleaned all the grease out. Be prepared to do this outside on a picnic table with a paint scraper and grease bucket.
Our unit would raise ok, then go right back down. There is a cam that raises the unit up and down. That same cam impacts a couple of micro switches. The push button switch over comes the raise limit switch when it's time to go back down. The limit switches (one up one down) have small metal tabs that get disturbed by grease and increased weight of the grease. After cleaning, just bend the upper limit tab just a little so it is tighter. On my mine, the unit would lift, then coast over the top of the cam profile and go back down. By bending the metal tab connected to the raise limit switch so the switch was more fully engaged sooner (earlier) to the top of stroke, the unit will stop where it should. Pressing the button again by passes the raise limit switch so the cam continues and the unit goes back down. I wish I had taken pictures when I did this. It really is very simple.
Feb 27, 2015 | Bosch DHD 805 Kitchen Hood
HJA2540 cooker hood fan not working. Lights work and little red light comes on when switches for fan speeds are pressed so has the fan gone or is it the capacitor? Many thanks Steve
Unless that's a much bigger range hood than I imagine, there won't be any capacitor - the motor will be of a shaded-pole design. If you have a multimeter, you could measure for voltage on the motor wires when the motor should be running - if reasonable voltage is there but the motor isn't spinning, then the motor's dirty or unlubricated or dead. If no reasonable voltage is present, the electronic controller has failed.
Aug 03, 2014 | Range Hoods
Light button blinking why
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
Jun 22, 2014 | Broan-NuTone Broan Elite E661...
The light inside the microwave will not go off and nothing else will work on the microwave.
Have the door switch adjusted or replaced as the system will not allow anything to happen unless it reads the door as closed.
Apr 07, 2013 | Kenmore 1.7 Cu. Ft. Over The Range...
Fan goes on and off, automatically... it has it's own mind
replace that board with the buttons. sounds like it is shorted out.
Dec 02, 2008 | Kenmore 52153 Stainless Steel Kitchen Hood
Fan and lights come on and go off all day long on their own
We installed our Broan-Allure range hood about ten years ago. On three seperate occasions since, the fan has randomly turned on and none of the control buttons would turn it off. After a while it turns itself off. During those same times, when you turned the lights on, they would blink before finally staying on. On each occasion, I have removed the screens and metal underpieces to gain access to the circut board. Once you can see the circut board, remove and replace the 3 Amp fuse that is mounted on the board. (Radio Shack part # 270-1054)...even if the fuse looks good, replace it. Each time this has work for about three years, then it acts up again..
Oct 13, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 22, 2008 | Zephyr Milano-S ZMI-M90S Kitchen Hood
KitchenAid KWVU265YBA
had same problem. microcomputer part # 4360092 and micro switch part # 4360362 needed to be replaced. cost 255.95 and 23.59 for parts respectively.
Feb 25, 2008 | KitchenAid KWVU265YBA Kitchen Hood
Bosch DHD965AUC Won't Lift Up
i've got the same problem. i'm solving it by replacing the motor that moves the arm that lifts the sucker. i think the part number is AP3193909 good luck!
Nov 18, 2006 | Bosch DHD 865 Stainless Steel Kitchen Hood
Bosch DHD 865 Stainless Steel Kitchen Hood Logo
35 people viewed this question
Top Bosch Range Hoods Experts
Jim Thurston
Carmen Mikulic
Are you a Bosch Range Hood Expert? Answer questions, earn points and help others
