Question about Samsung RS2556 Side by Side Refrigerator
Samsung rfg297aars/xaa temperature sensor - Samsung RS2556 Side by Side Refrigerator
Samsung washer model#wf306law/xaa error code tE - temperature sensor problem. what part do i need
This could be either a sensor or a wiring issue, You need to check the wiring that runs from the sensor to the electronics, the wires can break inside the plastic sleeve and cause the electronics to think there is a sensor fault, It could be a sensor fault but i usually find a broken wire in these machines.
May 10, 2017 | Samsung Washing Machines
How I fix the Thermistor DA32-00027B
The temp sensor is the white cover where your fan is on the back wall. It has vent slits on it.
Sep 27, 2015 | Samsung Refrigerators
I'm getting error code tE on samsung silvercare WF316LAS/XAA
tE is mostly related to
temperature sensor wire and connection problem. Look for a broken or loose wire.
Dec 07, 2012 | Washing Machines
Can't find temp control food is getting freezer burn
I clicked on the below links to find your manual.
http://www.samsung.com/us/support/owners/product/RFG297AARS/XAA
http://www.samsung.com/us/support/downloads/RFG297AARS/XAA
There are 2 links for manuals on the 2nd link above
(13.53 mb english and spanish) with file name DA68-01820A_v1.3.pdf)
http://downloadcenter.samsung.com/content/UM/201104/20110428084005272/DA68-01820A_v1.3.pdf
The first one is the quick guide (pretty much useless)
Electronic control from outside of Pantry Cover (Left side)
Adjustable temperature control ((around 41F(5C):Deli /around 38F(3C) : Fresh / around 34F(1C) Chilled) Temperature control from outside of the Pantry : user friendly design helps keep foods fresh for longer.
If adjusting the temp to a wamer temp does not correct the problem you may have an air damper or thermistor problem. You must allow 8 - 12 hours between temp changes to know what the stabilized adjusted temp result is.
Thanks for choosing FixYa,
Kelly
Aug 25, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
What is the required psi for water in my samsung rfg297aars
All Refrigerators are designed to work anywhere between 15-120 psi
Aug 01, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Model RS267LBSH/XAA - freezer working but refridgerator side warm (54 degrees). Heard sound like fan blade hitting, then no longer hear fan at all. What could it be
Have same model rs267lbsh/XAA and fix refrigerator. What I did was take off cover where evaporator is there a wire called defrost temperature sensor that goes bad I changed that sensor and my fridge is now working .if u need to ask me question please email me at jwilliams1957@sbcglobal.net
Apr 12, 2011 | Samsung Refrigerators
Samsung RS2556 Side by Side Refrigerator Logo
23 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
