Question about Home
Ventura shower mixer
How do you fix leaking shower mixer
2 Suggested Answers
  • 54 Answers
SOURCE: leaking faucet
Most likely bad solder joint or leak where shower arm is screwed into fitting.
Posted on Sep 26, 2009
Methven beta shower mixer rose is leaking
the problem will be at the tap washer
replace it and the water will stop from the rose
Sep 23, 2016 | Home
Seem to have water leaking under shower into storage competition ment, tried caulking only happens when shower is on and someone is in it very frustrating
Very often happens for a number of reasons
Bad caulking around the shower base and the base drops with the weight of the occupant allowing water past the caulking.
Crack and bad seal on a wall tile.
A split in the base itself which opens up with weight and you can't see with the base empty.
A leak in the pipes behind the wall from the mixer unit to the shower head.
Split pipes or fitting to the drain.
Best way is a full tear down, refurbishment and start anew :>)
Jul 10, 2016 | Home
I have an iflo thermostatic bar shower mixer which no longer delivers hot water for the shower. Do i need a new Bar Mixer?
To get rid of this problem, you should consult with a professional. Apart from this, you can buy attractive and best quality shower mixer by visiting this site: showerenclosures
Jan 02, 2013 | iflo Home
I have a sceptre shower unit. the valve was still leaking water when i shut it off. plumber took the valve out and one of the o 'rings/washers was worn out. he replaced it with another o ring but this did...
We have a Sceptre shower mixer, and are currently expieriancing a problem with the hot water supply only being warm.... pleae could you advise ?
regards howard young
Nov 17, 2010 | Home
Mixer shower leaking needs o-ring replacing, plumber reckons need new shower. Can I repair this by undoing the main unit? finding the o-ring and replacing, or will i open up a can of worms?
Maybe...maybe not...but what do you have to loose??? I would open it up and then figure out what size the o-ring is and then go to the local hardware and try to buy one...worst case...you replace the shower anyway....
Go for it.. you have absolutely nothing to loose...
just get a shower first so your good for a day or two if you need time to get it back together...:-)
heatman101
Aug 16, 2010 | Home
How do I replace a single handle Delta mixer??
You would have to open up your drywall, cut and re-solder a new single handle faucet. An easier approach could be to shutting off your water supply, draining the lines in your bathroom from someplace below, and then trying to fix the bad soldered joint if you know how to do so.
I hope this helped.
May 25, 2010 | Delta & Single Handle Shower Faucet
How does the mixer value come apart to replace leaking seals in the handle
Sorry, requires special tools to remove yhe valve spool. You may be able to buy the tool at home depot. I'm not positive.
Nov 05, 2009 | Delta Faucet 3-Function Showerhead &...
Leaking faucet
Sep 26, 2009 | Home
Home Logo
26 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
