Connect a Sony sound bar to a Sony Bravia tv - Televison & Video
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 1121 Answers
SOURCE: Need to get sound for wii w/ sony bravia tv and sound system
you must use a tv headsets jack or on wii output (RCA Connectors red/white) or Fibre Cable Wii output
Posted on Nov 29, 2009
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 6 Answers
SOURCE: My Sony KDL40XBR4 Bravia TV sounds keeps cutting in and out
Sounds like you have a bad Y sustain board, But if you want to part it out, I will by the screen from you and can offer $200 Dollars
E-mail me helpmycomputerfast yahoo com
Just add the at sign
Posted on Mar 16, 2010
  • 50 Answers
SOURCE: How to connect my audio system directly to sony bravia
There is usually three ways to connect a TV to a Surround Sound system:
1. Optical Audio Cable (Fiber Optic)
2. Coaxial Audio Cable (Orange)
3. Composite Audio Cables (Left - White, Right - Red)
Once you select a cable to use that is compatible with both devices, you must then connect it to the output on the TV set, and one of the inputs on the Surround Sound Receiver (preferably the Video Input or whatever type you selected to use). Then you must change the input on the Receiver to the proper input that you connected the cable to (most Receivers will have a Source Button if not individual source buttons i.e. Tuner, Tape, CD, Video, Aux, etc.).
Note: Some Receivers if using a certain type of input will not have sound out of all 5 speakers unless the input is 5.1 compatible.
Posted on Jul 02, 2010
I have a Sony sound bar Model CT380. It has HDMI ARC and optical digital connections. The TV does not have these connections. What can I do to work around this?
How to connect a TV Sound Bar system to a television. - SONY
https://us.en.kb.sony.com/.../how-to-connect-a-tv-sound-bar-system-to-a...
Jump to If your TV has an HDMI terminal (without ARC) and an ... - Then connect theTV's Optical digital ... If your TV does not have HDMI input ...
2.1 ch Soundbar with Bluetooth ' HT-CT380 ' Sony US
www.sony.com/electronics/sound-bars/ht-ct380
Sony Corporation
Rating: 4.1 - ‎9 reviews - ‎$249.99
Discover the 2.1 ch Soundbar with Bluetooth from Sony & explore all the Sound Barsfeatures. ... filter higher frequencies to distribute audio smoothly around the room. ...against the sound bar to make an instant Bluetooth connection. No NFC? ... the HT-CT380 to allow data to pass through the sound bar straight to your TV ...
Dec 28, 2015 | Sony Audio Players & Recorders
Why no sound when I connect Sony Vaio to Sony Bravia LCD,perfect picture?
You have to set the playback device on your Vaio to the TV instead of the laptop. You can do this in the Windows control panel under "Sound"
Aug 18, 2014 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My nephew has bought a new Sony Bravia, and lost the cable to connect the sound bar (Model FASW-M1). I have been unable to find the name or number for the cable. It has 7 pins on each end to connect from...
If you post a picture that would be easier and I may be able to locate the cable for you. Other than that there is a couple of places to check. One would be LPAV out of St. Paul, MN. They deal with nothing but used/older equipment and have tons of that stuff. The other would be allied electronics. If they do not have a premade cable but have the ends and you need further help I could probably make one for you.
Jan 27, 2014 | Sony BRAVIA KDL-26N4000 26 in. HDTV LCD TV
My sound bar hooked up directly to my tv has no sound
You may have to go into the Bravia setup procedure and opt to disable its internal speakers
Nov 17, 2012 | Boston Acoustics TVEEM25 TVee Model 25...
Didn't get a pedestal with my 32 inch Sony Bravia LCD TV. I do have a pedestal for my 42 inch Pioneer Elite TV. However, as you would imagine, the holes don't line up. I'm thinking of attaching two...
It doesn't sound like it would be very stable. Why don't you just call Sony and ask for a replacement part? They will usually quick ship you a part if it was not included at the time of purchase.
May 29, 2017 | Sony BRAVIA KDL32V5500 32 in. TV
Sony Bravia Tv sound is too loud. the sound bar is at its lowest setting and it sounds like it is at its highest. help?
try opening the settings and lower the treble and bass it should get quieter but you may have to sacrifice some sound quality.
Apr 25, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lousy sound on 32" Sony Bravia
if you are have problems with in built speaker when the tv speakers are on, then connect on audio out hi fi
audio out. and make sure your speakers are on off.
Jan 16, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
Dec 08, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Televison & Video Logo
248 people viewed this question
Top Televison & Video Experts
Electro Med Services...
