Question about Carpet Pro Vacuums
Vacuum Manuals: My Carpet Pro Vacuum just stopped working and I forgot how to fix that problem
Stopped Steaming.. Can I fix it ?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Nov 22, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
While using, steam stopped coming out in force at the port levels in the head. Suddenly started high pitch whining, pressed button just above connection site and end flew off with great force pouring...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How dose it **** water up
This machine does is NOT a vacuum and does not **** up water. It's a shampooer/polisher. If used properly, with the correct solution of Turbo Shampoo to water, the carpet dries in usually no more than 2 hours. If you need a copy of the user's manual, go to the following site, "Current Models", find "Floor Pro", and download manual.
http://www.aerusvacuums.com/support/manuals/index.cfm
Oct 03, 2010 | Electrolux Floor Pro Vacuum
I need the instruction book. Wanted to more about carpet use.I don't have a book with mine. So can it be printed out online. I wanted to know about carpet use. The # of mine is S350l
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
heatman101
Sep 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I was using the steam mop this morning working great, went to put on the attachement for carpet, that's all I did, and now it doesn't work, no steam comes out, I don' know what happened one minute it was...
Hey it just broke like most of them do...
heatman101
Sep 06, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Automatic height adjuster is not working,it grabs carpet and stops roller
Hi There,
Actually usually when this happens, it's usually the belt that causes the brush to stop and not the height adjustment. What happens is, over time the belt will get hot, which causes the belt to stretch. Once the belt stretches out, it becomes too long, and will stop the brush from spinning when it feels any resistance to the brushes. This is most likely why the brush is stopping when you put it down on the carpet.
I'm pretty confident that if you replace the belt on your vacuum, this should fix the problem of your brush stopping when it hits the carpeting.
Here's a link to the owners manual for your vacuum that will explain step by step how to replace the belt:
http://www.dirtdevil.com/manuals/?id=03c9b130-874d-4601-9e64-2da6376ccfab
I hope this information was helpful to you. If this did help you solve your problem, please be so kind and rate my repair, or leave feedback for me. Thanks so much,
Chris Jones
GoVacuum.com
May 17, 2010 | Dirt Devil Featherlite Bagless Vacuum...
My bissell carpet cleaner won't dispense the
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fdghd
Apr 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Need instructions on how to attach carpet attachment
heatman101
Aug 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I need to get the steam mop attachment
Check the manuals link...
heatman101
Jul 16, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
65 people viewed this question
Top Carpet Pro Vacuums Experts
Ted Maxwell
Andrew Taylor
Andrew Taylor
JoeVacs
Are you a Carpet Pro Vacuum Expert? Answer questions, earn points and help others
