Question about Philips TP3281C TV
Philips tp3281c chasis#32d700-7570
How can I test the horizontal output transistor of this set with a simple multimeter?
  • pamminger Aug 30, 2007
    The H.O.T has 3 pins. I assume that from left to right, the first pin is (B)the base. The middle pin is (C)the collector, and the last pin on the right is (E) the emitter. I first tested the H.O.T. using the analog MM in a 10 ohm setting. There can only be 6 combinations with the test readings as follows where continuity = 0 or some measurable ohms of resistance; no continuity = infinite resistance:
    Red lead of mm to B, Black lead of mm to C; the reading is no continuity
    Black lead of mm to B, Red lead of mm to C; the reading is + continuity
    Red lead of mm to B, Black lead of mm to E; the reading is +continuity
    Black lead of mm to B, Red lead of mm to E; the reading is +continuity
    Red lead of mm to C, Black lead of mm to E; the reading is + continuity
    Black lead of mm to C, Red lead of mm to E; the reading is no continuity
    Next the six various combinations were then tested with a digital MM set into the diode testing mode where non-touching leads display a reading of 1 and when the leads are touching the device reads 0:
    Red lead of dmm to B, Black lead of dmm to C; the reading is .426
    Black lead of dmm to B, Red lead of dmm to C; the reading is 1
    Red lead of dmm to B, Black lead of dmm to E; the reading is 0
    Black lead of dmm to B, Red lead of dmm to E; the reading is 0
    Red lead of dmm to C, Black lead of dmm to E; the reading is 1
    Black lead of dmm to C, Red lead of dmm to E; the reading is .426
    I am not sure exactly what these results represent! Based on the above test results, is the H.O.T. is good or bad? Would appreciate any feed back.
    Thanks, peter
  • 1,153 Answers
I believe this set has a horizontal output that has a damper diode inside. you can check inset or out, most popular is out set. take multimeter and put on ohms or continuity and touch each leg by holding one lead to end and if you are looking for a short then in continuity it will beep or zero or very ohms. And Ohms just the same way. looking for low ohms like 1.0 or 0.9 or anything close. Switching leggs back and forth. If all three legs are shorted then replace. but in this one 2 can be shorted and still be good, just depends on which ones
Posted on Aug 29, 2007
Am I testing this horizontal output transistor correctly?
Check the resistance between collector and emitter. It should never be Zero Ohms.
Dec 01, 2012 | Symphonic Televison & Video
Will not come on. light blinks 6 times
Six blinks denotes the absense of horizontal sweep. Check the horizontal output transistor, whcih can be located very near to the LOT [Line Output Transformer]; for short. If it is shorted, LOT must be suspected. Replace the line output transistor with a new one, and switch ON the tv for a short period of time, say 6 seconds or so, and check the heat of the replaced transistor. If it overheats within this time, be sure that LOT is damaged; shorted inside; and should be replaced with same type and number. If a digital multimeter which can measure frequency is available, take the frequency at the collector of the horizontal driver transistor. It should come around 15525Hz. If not replace the jungle IC. OK.
Jun 19, 2011 | Sony FD Trinitron KV-32HV600 32" TV
Power ok but not eht function
If you have tested the secondary section of the SMPS power supply of your Sony TV, amd found it OK I thinks, and posts this solution.
If the secondary supply rail 125VDC is found ok, just goto to the Horizontal Output Transformer, a small transformer diretly soldered on tho the main board, very near to the Line Output Transformer [LOT], and its secondary winding is connected to the base of the line output transistor, which in turn drives the LOT said above, generates EHT you described.
The base of the line output transitor must get appropriate frequency to switch on and off. This frequenct is gerally comes to 15625Hz. Just measure the voltage across the primary winding of the above said line driver transformer, which can be a possiblity open winding. Check the voltage at the collector point of the line drive transitor connected ti the one end of the primary winding is easy. Then check the voltage at the other end of that winding. There must be a little difference of 2VDC or so, if the line drive section is working, and fault is after that section, that is line output section. If you have a digital multimeter capable of measuring frequency, measure the frequency of the collector point of line drive transtor, and find out whether there is 15625Hz or near to this frequency comming out. Never touch the multimeter prob to the collector of Horizontal Outout Transistor, while it is working. Your meter will get damaged.
Line output section, contains tha LOT said above and line output transitor. If the Line Output Transistor has some sort of leak, normally collector to base leak, it will not drive the LOT to produce EHT and it wlii heat up also.
Just check it heat effect, after switching the set on for a short period of time, say 30 seconds ro so. If it heats up abnormally, suspect the line output transistor and LOT. You just replace the line output transistor first, with same type and number. If it doesn't retify your problem, LOT said abve is faulty, and it also should be replaced with same type and number.
If you have to replace the horizontal output transistor, and the LOT said abve, insist on orginal, and not replace it with a susbstityution, as these are critical components in all TVs..
If you need further assistance, get me through Fixya, and be free to conact me. Ok
Nov 29, 2010 | Sony KV-XA21M61 21" TV
Hum coming from unit
If there is no picture,and the set will not power on,then the horizontal out put is shorted causing the set to shut down on a protect signal. You can check it yourself if you have a multimeter. Look for a 3 legged transistor on a metal heat sink and put the multimeter in diode scale. The outer two legs will always read 0, but the middle to outer legs should NOT. If it does,then the horizontal output is the culprit but the tv needs to be serviced anyway to make sure that there is not an underlying problem that caused the output to short to begin with.
This is also the answer to 90% of picture tube (CRT) televisions that have either lost power and/or lost picture.
Nov 01, 2009 | RCA F32650 32" TV
My tv is making a squeaking noise its a model 736668.
If you have that loud noise and no picture it may need the horizontal output transistor, this noise comes from the h drive circuit and usually is caused by a shorted h.o. transistor. Some times is not enough to replace the transistor, and a hv transformer may have to be replaced also. The model does not appear to be correct, but if you are a bit able with how to use a multimeter you can test the transistor which is the easier component to test. Technical expertise will be needed for the inspction of a hvt unit or something elese. hope this helped you and please leave feedback if your question was answered. thanks!
Aug 28, 2009 | RCA Televison & Video
Panasonic pt-47wx53g horizontal outout transitor short whit new transistor flyback voltage are all to low the tv does notlight up the crt
Hello oncle_jc,
You may have a problem with your flyback transformer, I would suggest that you perform a ring test to see if any of your windings on the flyback are shorted. In addition You may want to also check the input to the Horizontal Output Transistor, to see if the driver pulses are of the proper amplitude. Besides these two things the only other issue colud the the high voltage trippler (if this is not part of the flyback). Check these things, you will need the following equipment:
1) oscilloscope
2) voltmeter (multimeter set to DC volts)
3) High Voltage probe
4) A test set that can perform a ring test (My shop uses the Sencore LC102)
Or what you can do is take the flyback out and take it to a TV shop and for a small fee they can run the test for you, (My shop usually charges $20.00 - $30.00 for this
I hope this helps
Feb 24, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Hello valexandrur,
You are in the correct section, now your problem may be a shorted Integrated High Voltage Transformer (IHVT) also called a Fly-back Transformer and or a shorted Horizontal Output Transistor (HOT). I would first check the Transistor to see if it is shorted between the emitter and collector (to do this use a multimeter set to "Rx1") and the reading between the emitter and collector should be near infinite no reading, if the reading is 000 ohms then the transistor is shorted and should be replaced. Now for the hard part, you technically can not check for shorted transformer turns in the IHVT using a multimeter, you will have to use a device which will allow you to do what is called a ring test. If you do not have this piece of equipment (IHVT tester), I would replace the IHVT just as a matter of good measure, since the HOT had drawn a lot of current I would assume that the IHVT was damaged to since it is in the serial path between the collector of the transistor and the VCC supply.
I hope this helps,
Thank you,
Jan 19, 2009 | Proton MM2701VT 27" TV
Rca 2006 32v434t dead shorted out put
One special transistor is there. Before you change the transistor please sure that this is the first time problem or repeat H output TR failure. If it is first time means simply change the special type of transistor C5591. This is the high current rated tr and Panasonic is the manufacturer. Repeat H out failure means do the following simple works. If there is any capacitor between H sync output from Ic and horizontal drive transistor. Reduce the mf value and slightly increase flyback capacitor value. And then put the new horizontal output transistor.
Sep 06, 2007 | Proscan PS36800HR 36" TV
RCA F27669 27"
The F27669 uses the CTC203 series chassis. The most common cause of that symptom is a shorted horizontal output transistor, caused by a cracked solder joint on a small coil connected to that transistor's base. When this happens, the main B+ supply is shorted to ground so the power supply squeels. Every once in a while I also see the horizontal output transistor shorted due to a shorted flyback (high voltage) transformer. A good tech will replace the horizontal output transistor, resolder the coil and drive transformer, test the flyback (replacing it if necessary) and your set will be back to perfect.
Aug 08, 2007 | RCA 27V570T 27" TV
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
Televison & Video Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
