Kross GY2002 WF light
W.F light is flashing and air conditioner won't turn on. I cleaned all 4 filters and reinstalled them.
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
SOURCE: Air conditioner turns on then shuts itself off immediately
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Posted on Oct 07, 2008
  • 400 Answers
SOURCE: LG Room Air Conditioner Model
I would say that your return air sensor is faulty or not positioned correctly. Check sensor
Posted on Mar 05, 2009
Krazytech
  • 725 Answers
SOURCE: What does E1 flashing on display mean?
if its a sharp ac ... it will need to be reset..
1) hold down the on/off button keep it held down and plug in the ac ..you should hear a beep...
2) hold down the mode button keep it held down and plug in the ac ..you should hear a beep...
one of two ways will reset the e1 error hope it helps..
Posted on Sep 19, 2009
  • 400 Answers
SOURCE: Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Posted on Nov 19, 2009
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
The red alert light indicates that the filter needs to be cleaned. I have cleaned it but the light remains on. I have turned the unit of and on again but it doesn't change the light. The unit is...
Tunr the unit OFF & unplug it for 15 minutes. Then plug it back in and turn it on. The electronics should have reset and reverted back to the original factory settings & the red light should no longer illuminate, as long as the filter was reinstalled properly.
Hope this helped you and thanks for choosing FixYa.
Aug 08, 2011 | Heating & Cooling
I have a Maytag window air conditioner unit (model M6T12FSA). The 'check filter' light came on and after I cleaned the filter, the 'check filter' light remains on even after a few hours of...
Turn the unit OFF & Unplug it. Remove the filter and reinstall it, being sure that it's installed properly. Particularly, which way the plastic filter frame is facing when installed.
Plug the unit back in and turn it ON. Hopefully, the electronics now will accept the filter being properly in place.
Hope this helps and thanks for choosing FixYa.
Jul 25, 2011 | Maytag Heating & Cooling
The filter light keeps blinking. the filter isn't dirty. the filter is in the front and slides out either side. we keep it clean. so.. how do i get it to quit blinking? is there some regular...
Pam, be sure tat the filter is properly installed. Whenever you remove the filter for cleaning, be sure to turn the unit OFF, before removing it. And back ON after it is cleaned and reinstalled.
For the blinking problem. Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. Once the time has elapsed, plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the unit's electronics reset themselves and reverted back to the original factory settings. If so, the filter light should have stopped blinking, if the filter is installed properly.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Whirlpool ACQ122XK Air Conditioner
UNIT WILL NOT COOL. FAN AND HUMIDIFIER WORK. THIS IS ONLY THE SECOND SEASON USED AND THE UNIT HAS NEVER BEEN SITTING UP AND NEVER LAID DOWN OR TURNED UP SIDE DOWN. WHAT IS THE PROBLEM?
A portable air conditioner may not cool for several reasons. Check the filter by removing the unit's grill and clean the filter.
Also check for clogs in the evaporator or condenser coils by light vacuuming. Make sure the evaporator isn't frosted over, but if it is, allow it to defrost and normal operation should resume.
Lastly, ensure the ambient temperature is lower than your AC's set temperature, as this can prevent cooling. However, if all of these steps fail to resolve your problem, the compressor may be malfunctioning, and in this case, the compressor needs to be replaced or repaired.
In summary, if the air won't cool, remove the grill and clean the filter. Clean out any clogs in the evaporator or condenser coils by vacuuming them and scrubbing them lightly with an old toothbrush. And since fan is working, you compressor might be defective.
I hope the above information is clear.
Regards.
Jun 24, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
Unit ices up and quits cooling
There are a couple of things that contribute to the problem you're experiencing:
1. A dirty or clogged air intake filter. Turn unit OFF, remove and clean the filter. If filter is washable
be sure filter is thoroughly dry, before reinstaling it.
2. Cooling fins are dirty. Turn unit OFF, remove the outer shell of the AC unit, if necessary and
clean the fins with an old toothbrush and a vacuum cleaner.
3. Humidity level in your area is extremely high. This is Mother Nature's problem and is not readily
solvable.
4. Defrost sensor is not functioning properly. Replace sensor.
5.. Low refrigerant gas in the AC's compressor. Have compressor recharged.
Hope this helps you trouble shoot and solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Friedrich TwinTemp EL24J35A Air...
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
Flashing green light persist even after the filters are cleaned and properly reinstalled. no air conditioning function
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 30, 2010 | Fujitsu 24C1 Air Conditioner
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Jun 18, 2007 | Whirlpool ACQ158XP Wall/Window Air...
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
