Question about Measuring Tools & Sensors
Fluke 189 Was using the meter for data logging with a Fluke amp-probe attachment. I power-off the meters, but left the amp-probe connected around a conductor. Several days later I went back and wanted to data log again, but the Fluke 189 would not power-on. It's just dead. I've replaced the batteries, but the meter will not power-on. Any idea what might be 'bad' (besides my stupidity for leaving the amp-probe on a conductor)?
benleves
  • 92 Answers
SOURCE: fluke 97 scopemeter will not power up
i have the same problem now check in your fluke you have a fusse change it
Posted on Dec 03, 2008
dmftrucker
  • 1922 Answers
SOURCE: Dos not work in Volt meters. show 220v as ca 50 v.
your batteries are shot
Posted on Oct 06, 2009
  • 82 Answers
SOURCE: HOW DO I CHECK VOLTAGE WITH A FLUKE METER?
User guide is here http://us.fluke.com/usen/Support/Manuals/default.htm?pid=37115
Includes info on how to measure voltage. For lower voltages it is simply a matter of selecting voltage measurement and putting the probes across the voltage (i.e. on each terminal of a 9v battery). For much higher voltages you may need special probes that effectively step down the voltage by a factor.
If this helps please leave feedback, if not let me know and I'll trya nd help some more!
Posted on Jan 28, 2010
  • 165 Answers
SOURCE: I have a fluke 179 meter that was left outside and
Try taking it apart and drying it out with a hair dryer, much as you would if your cell phone got wet.
Posted on Mar 07, 2010
SOURCE: Fluke 8060AA digital multimeter
test unit reads okay then goes into - OL mode unable to take any readings
Posted on Jul 12, 2011
Fluke 51 II display OL
Open line. Either the thermocouple is open or there is a fault in the meter. The thermocouple that you are connecting to the meter should be color coded indicating what type it is. You can try reading a voltage signal and comparing it to a temp chart based upon the type. Attached is a type k chart and color code chart. http://www.pyromation.com/Downloads/Data/emfk_f.pdf http://www.pyromation.com/Downloads/data/ColorCodessheet.pdf
Aug 05, 2015 | Fluke 51 II Thermometer,type...
Does you fluke 79III beep when turned on?
PDF]Series III Multimeter - Fluke symres:sb_safeannotation.png
assets.fluke.com/manuals/7926____iseng0200.pdf
The meter defaults to autorange when you turn on the meter. ... When the meter detects a new input, it beeps and displays a new ...
Nov 03, 2014 | Motorcycles
Need the model number of a fluke clamp on meter, serial number is 21530517
try looking for Invoice (it should have model) on it or ask place where you purchased unit from
Mar 25, 2014 | Fluke 321 Clamp-On Meter Electrical...
My fluke 45 multimeter displays error 6. how can i solve it?
This is explanation on Error 6 from Service Manual:
EEROM (A1U5) meter configuration corrupted or EEROM not initialized. At power up, A1U6 reads CRC from EEROM (A1U5) location, then reads configuration data from another location in EEROM, calculates an algorithm to compare to the CRC. If an error is determined, the meter configuration is set to factory default and Error 6 is displayed.
You can find service manual with troubleshooting procedure here: http://www.fluke.com/Fluke/usen/Support/Manuals/default.htm?ProductId=56082
Aug 13, 2013 | Fluke 45 Dual Display Multimeter
Fluke tp165x how to use
It's a probe with test button attached to it. When connected to compatible Fluke Insulation tester you can use button on the probe instead using Test button on unit.
If you have to ask hot to use probe then you may have to ask someone to show you how and what for this is used.
Satety first.
Jan 20, 2013 | Fluke Networks Measuring Tools & Sensors
Fluke 51II when I turn on it says CAL. Err
One possible reason: there was steam or water inside the meter through probe. The easy way to fix, just try to Dry it as much as possible (if you like, you can take its battery off first). When its inside dry, it will be OK. I have a Fluke 52 II, this happened many times now. After it back, everything is OK, it has passed its calibration well.
Jun 07, 2012 | Fluke 51-2 Thermometer Series II
Cannot get my Fluke 36 clampmeter to read amps
1. make sure that all buttons can be pressed freely (not stuck)
2. make sure when measuring AC current that you press AC button and AC sigh is on LCD
3. make sure that jaws are closed completely
4. clamp meters use Hall effect and can only measure current flowing through ONE conductor (you cannot measure current around power cord (which has 2-3 or more conductors)
5. when in DC setting and you turn zero knob does value changes (it should)
Nov 21, 2011 | Fluke Networks Fluke 902 True Rms Hvac...
Electrnic hand growler to test electrical armature with green and red indicator
Go on E-bay for electrical test equipment and look for growler.or go google and type in armature growler test equipment and see what you get.
Sep 05, 2011 | Hand Tools
Jan 26, 2010 | Fluke Networks Fluke T+PRO Electrical...
Measuring Tools & Sensors Logo
232 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
