Question about Bunn STX
Thermal fuse What's the temp setting? Part no is g4a01141c maybe as read on part.
Oven won't heat in Bake or Broil Stove top burners all working fine
Hello. I really need the make and model number of your unit to help you accurately. The symptom you describe, however, leads me in the direction of an open thermal switch--a temp activated safety device. Did you use the self-clean feature? If so, that is a notorious cause of blown thermal fuses. Often, they are located on the back wall of the oven, inside the rear cover. Normally, the fuses are round, diameter being approx 5/8 inch to 1 1/4 inches wide. They have 2 terminals on them. You'll need to TURN OFF THE POWER BEFORE OPENING THE REAR COVER!! You will need a voltage/ohm meter set to continuity or a low ohms scale. Most have a setting that shows a triangle and sound wave symbol(diode test, continuity) and when the probes are shorted together, the meter beeps. If the leads are apart, the reading is "off scale" like having a broken wire. Disconnect a wire from one side of the thermal and check across the thermal. If it is good, the meter will beep.
Also, the thermal fuses can be inside and behind the control panel at the front of the range(if your range has the control panel located in front of the cooktop). Now, if it's a wall-mounted unit, the control panel will have to be removed and you'll need a flashlight to see if there is a thermal behind it(some better ranges and ovens have a resettable thermal switch--one with a little red button on top that pops out if too high a temp is sensed. If you are not comfortable doing any of this, please call for service.
Sep 02, 2015 | Kitchen Ranges
How do you test ohms on a thermal fuse for a dishwasher
Disconnect all sources of power to the dishwasher.
Set your multimeter to the lowest RESISTANCE setting.
Place one probe on each side of the thermal fuse. The meter's reading should drop to zero, or very nearly zero, and should be the same reading as you get when you just touch the two probes to each other.
If you read anything significantly higher than zero across the thermal fuse, replace the thermal fuse with an identical one - same part number, or same current/temperature ratings.
Aug 12, 2014 | Dishwashers
Change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside
An iron should be calibrated to 410 degrees on wool setting to get the other settings to work correctly.
Dec 26, 2012 | Irons
Trying to set thermal stat to cool
Look at the bottom of the T'stat or in the newer ones click menu and follow instructions to preset individual days or on some week and weekend if there is a switch at the bottom set it on the cool selection click the menu button if it has a next buttton then click it until it gets to the degrees and push the <or> button until you get to the temp you want it to be at and then click next until you have all the days programed to the temp you want it to stay at and when your finished push the done button if it has one and it should be programed for the cool side to set the heat set it to heat and do the same as you did on the cool part remember down for cool and up for heat on the degrees you set them on example if you set it 78 for the temp on cool and during the day you want it cooler set it to lower temp say76. if you set it 79 then it won't come back on until the temp is 79. Maybe this will help some programable t'stat are a little more complicated then this
Aug 17, 2012 | Honeywell Programmable Thermostat Heater
Not getting heat
Hello there mark and welcome to fixya
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, you will need to test it for continuity it should read 000 on the meter if good and a 001 or a 1 means bad ok the meter needs to be set at the lowest ohms scale . Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Dec 17, 2011 | Whirlpool Dryers
Wed6400sbo dryer wouldnt heat now start button wont work
check thermal fuse. Testing a thermal fuse
Note: Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel. Testing a dryer's thermal fuse is much like testing its thermostats. Follow these steps to replace your dryer's thermal fuse.
The wires leading to the thermal fuse are connected using metal slip on connectors. Remove the wires by pulling on the connectors, and not the wires themselves. It may be a good idea to use a pair of needle nosed pliers to help you.
Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermal fuse should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. We strongly recommend that you test your thermostat at room temperature.
If the test you conduct with your thermostat does not produce these results, then you should replace the component.
Dec 09, 2011 | Whirlpool Dryers
Samsung dryer model dv209aew/xaa will not dry. I cleaned the lint vent inside dryer, made sure the duct work was all clear, setting was at normal not air fluff, even tried at different setting like heavy...
Hi shadowand me2...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 18, 2011 | Dryers
Model 110 73932101 kenmore elite. Blew the circuit board replaced it and checked the relays. Wont heat, found the thermal fuse is blown. Checked the high limit thermostat and the thermistor. Thermistor...
there is thermal fuse, Hi limit, and thermistor. the thermistor should have continuity at room temp I don't know what resistence(ohms) it should have. Most units I have seen provide a schematic and trouble shooting guide taped under the control panel for service personal.
Apr 15, 2011 | Kenmore Dryers
Maytag dryer is less than 3 years old. Blew thermal fuse. Cleaned all of the venting inside and out. dryer still overheating and blowing the thermal fuse. Replaced the thermal fuse and the high temp sensor...
Have you tried replacing the operating thermastat it's what shuts it off at the right temp and would cause the thermal fuse to go if it is not shuting.off at the right temp. It happens.
Hope this helps.
Dec 05, 2010 | Maytag PYE2300AY Electric Dryer
My kitchen aid oven has error codes f3 e1 what do these mean, i can't use it , it keeps shutting off.
Hello there:
F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor
Now if it is just a f-3 and nothing else3 f 3
Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse
Jan 22, 2010 | KitchenAid Ovens
Bunn STX Logo
105 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
