Midea model ccm04 it keeps flashing PO how do i re set or wht is the issue
This is a aircon/heating unit on off switch is out side what could be causing it to go into a po mode
SOURCE: how to reformat nokia 3650
i love u
Posted on Nov 15, 2008
redbeard00
  • 957 Answers
SOURCE: Engine Random Misfire code PO-300
P0300 is for random miss-fire, loose or defective gas-cap, water in the fuel, damaged vacuum line, clogged fuel and/or air filter, faulty plugs and/or wires, fuel injectors. These are more common reasons, there are others but this a good start.
Posted on May 15, 2009
  • 334 Answers
SOURCE: drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Posted on Jun 28, 2009
  • 5 Answers
SOURCE: Hi, I have a wall mount midea split a/c model-
Most heat pumps are 'fail-safe to heat'. That is: the normal position of the valve which reverses the function is in the position which provides heat. The reversing valve must be powered to switch to the cooling position.
Although the lack of valve function could be a mechanically defective reversing valve - it's more likely to be an electrical issue. Start with checking for power at the reversing valve's coil. If it's powered unpower it - you will be able to hear the reversing valve distinctively
Posted on Oct 03, 2009
  • 400 Answers
SOURCE: i have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Posted on Nov 18, 2009
What is the function of ec in midea
EC stands for Energy Compliant. It means the stand-by automaticaly when reaches the setpoint. Try with a different setting.
Sep 10, 2017 | Midea Heating & Cooling
What's the original capacitor number use by condura aircondition model NG 070...
Ano po ang value ng compressor capacitor ng condura room aircon na ang model ay NG090DLX? Naerase nakasi ang number sa metal case ng capacitor .
Dec 21, 2015 | Heating & Cooling
My midea aircon is showing F3 code?
Display = E2
Malfunction or Protection = Communication error between indoor units and outdoor unit.
This is the meaning of the error code. If you need any more AC Cleaning & Repair help contact the professionals.
Apr 07, 2015 | Midea Heating & Cooling
User manual for jnc JAC-24Y2???- want to know what the optimal setting for heating temp is for economy in the unit. We seem to have to have ours set quite high to get the unit to run consistently. If we...
Normal settings 70 heating 74 to 76 cooling, I try to leave my cooling a 76 and keep it there. 76 degrees feels good if its 95 or hotter out side and the lower you set it the more it will cost.
Jul 03, 2011 | Heating & Cooling
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
Changing temp readout on Midea Air Con Controller from F to C
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
Jul 09, 2010 | Heating & Cooling
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
No air blowing from the aircon. though the aircon can be switched on and off.
something is wrong with the fan, it may be jammed with a foriegn object or have a malfunction. kids may have stuck things in it.
Jan 05, 2010 | Midea WP10000 Air Conditioner
I have split system aircon model no ese21hra wont
Nov 14, 2009 | Heating & Cooling
Hi, I have a wall mount midea split a/c model- MSG-36HR that will only heat. when put in cool mode it only blow's room temp air and the outdoor unit won't run. On heat mode it works normally. I have cycled...
Oct 03, 2009 | Midea Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
