SOURCE: won't stay running
Check the oil level. It may be overfull. If so, a carburetor problem may be allowing fuel to get into the crankcase.
SOURCE: push mower runs, starves, recovers, repeats
Sounds to be the float and needle needs replaced. The float raises the needle to let gas through the carb. If the float isn't working properly the carb starve for gas. If replacing the float, be sure to clean the carb to.
Testimonial: "Thanks, all. "
SOURCE: the mower starts runs very weak , for a few
i would try first of all replace the fuel filter and check clean or replace your air filter. Personally I think it is going to be the fuel filter that is clogging and causing this. And for little cost replace the plug and make sure it is gaped right.
Is it Blowing White smoke, if Yes then
Use the lawnmower's oil dipstick to determine whether the oil
level is correct. Maintain the correct level of oil. If you've overfilled the
oil, open the drain plug, and drain some of the oil into a waste container.
Dispose of any excess oil properly. Burning off excess oil is undesirable. It
can foul the mower's spark plug, piston rings, and other engine components and
contributes to air pollution. If your mower's engine has not been overfilled
with oil, but still is smoking, it may have stuck or worn piston rings or
another maintenance problem.
Some maintenance shops offer a
mower transport service. Check to see if this is available in your area.
