Question about KuulAire Port-A-Cool KA50-BL Scratch & Dent Portable Evaporative Cooler
How to clean inside of it ?
I need to know how to get into the area where you put the water into to clean it out ?
Is there any way to clean INSIDE the toilet bowl rim? I don't mean under it, I mean inside, where mold seems to have formed.
the underneath of the rim is not completly open but a series of holes to direct the water flow
the best way to clean in that area would be to put some quality cleaner ( bleach or such like ) in the cistern water then flush the toilet
do it a couple of times and see if it improves the situation
talk with an accredited plumber as the problem may be in the water supply allowing the mould to grow
it takes water and moisture for the growth of mould so it may be a leaking stop washer in the cistern that is the real culprit
as after a flush that area of the bowl dries out and mould will not start
Jul 09, 2015 | Washing Machines
How do i clean the inside of illuma kettle
You can use Lime-Away (at Home Depot) or Apple Cider vinegar. It seems to work much better then regular vinegar. In either case let it boil if it has no element inside the water compartment, put a small clean rag inside and use a wooden spoon to clean the heavier areas. Boil it a few times, then dump it, and boil and clean with clean water twice, then put it back in service.
Feb 26, 2015 | Morphy Richards Illuma 43121 Cordless...
What kind of water is to be used in the steam station RHST 100. I mean to say that only distilled water is to be put or ordinary tap water can be used ?
hi.
distilled or de-ionised water is recommended in all steam generator units.
tap water can contain minerals and salts that will remain in the unit and fur the inside of the steam generator.
if you live in a soft water area where there are very few impurities in the water you should be ok to use the tap water.
if you are in a hard water area, do not use tap water.
the best way to work it out is look at the inside of your kettle.
if the inside is clean with no sign of scaling, the water should not scale your steam generator.
if there is any sign of scaling, do not use tapwater for your steam generator.
distilled or de-ionised water is recommended though
Apr 08, 2011 | Vacuums
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
Does not clean dishes in upper rack. Looks like middle and upper water sprayer rotors are not working. I have disassembled everything and cleaned out all rotors and water piping, etc and the...
The problem may be a bit deeper in the sump area of the pump. I have put together some instructions on how to clean out the sump and chopper area which can cause low water pressure and no water to the upper arms. Take a look at the link and let me know if it helps.
Sump Clean
Jul 21, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishes on top rack not clean. appears water not getting up there. now lower rack also...seems like low water pressure?
This could be due to debris in the sump area. I have put together some instructions on cleaning this area. Follow the link and let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 10, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
Basic instructions and mixture ratio of cleaner and water
I would not leave the solution on the carpet for more than a few minutes! Clean it right away to minimize chances of bleaching out your carpet.
I have a Proheat 2X and and it would not dispense water & cleaning solution. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing. With the dial set to "Tools", I had the same problem.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW on carpet & tool settings. Don't know if this will help you, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 18, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
The conditioner part is always full of water and does not take down any fabric condtioner that is put in. Have cleaned drawer an inside but does not work.
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. Use a pipe cleaner, cotton buds or piece of coiled curtain wire to ensure that the U shaped pipe is clear of obstruction. Pull it back and forward to dislodge any accumulated fabric conditioner. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. A good idea is to slightly water down fab con concentrate as it will eventually clog up the dispenser. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Oct 18, 2009 | Bosch Washing Machines
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Algae in water tank?
Try to clean it with soap, if you are careful you can bend in the edge and take it off.
Use some glue on it when you put it back.
/Mirran
Aug 22, 2008 | Saeco Incanto Classic Espresso Machine
KuulAire Port-A-Cool KA50-BL Scratch & Dent Portable Evaporative Cooler Logo
13 people viewed this question
Top KuulAire Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a KuulAire Heating and Cooling Expert? Answer questions, earn points and help others
