Question about Garden
Troy bilt tb130
Recoil starter won't come out
#1 Taper
  • 1040 Answers
SOURCE: Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Posted on Jun 21, 2009
woobie dog
  • 1273 Answers
SOURCE: Motor seems to be locked up!!!!!!!!
It may be your engine, but it may also be the water pressure. Try this: Hold the trigger down while pulling the recoil starter. This acts as an unloader for the pressure washer, and may allow the engine to turn over. There is also an oil level in the pump as well as the engine. Check both levels.
Just a thought, but I've been there. Best regards, W/D
Posted on Aug 16, 2009
harlan301
  • 205 Answers
SOURCE: I have a Troy-bilt chipper/vac 47279 with a
check with you local service center that handles tecumseh parts. I can get it thy should be Abel too. your new number is 36221
Posted on Oct 17, 2009
Testimonial: "With the new part # I was able to find several web sitrs saling the part. I bought the part on ebay. Thanks for the help."
  • 89 Answers
SOURCE: troy bilt mower. starts but shuts off within seconds.
sounds like you have a primer bulb if you take the bolt that holds the float bowl off and take a tip cleaner that they use for welding tips and clean the holes out of the side and the top it should let the fuel in again that will save you a trip to a service repair shop
Posted on Nov 23, 2009
  • 152 Answers
SOURCE: troy bilt mower 6.75 hp smoking too much oil...
Check oil level, it could be just excess oil. Also check air filter, it may need cleaning/replacing. Depending on how old the nower is, it could be broken rings in the engine, in that case... time for a new mower. hope this helps!
Posted on May 25, 2010
Starter rope is loose on lawn edger
remove the recoil housing and wrap the chord round the spool more to take up the slack
Feb 11, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Nov 16, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
How to fix recoil starter?
It appears that the recoil spring is broken or has come away from its anchor position. It means opening the unit (usually 4 screws) and re-seating the recoil spring and rewinding the recoil spring so that it will recoil the starter rope with the correct tension. It may take a few attempts to get it right. If you do get it right, don't over-extend the starter rope when starting the washer. Someone was over-zealous!
May 11, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
Pull cord engaging
recoil clutch fingers are broken or stuck. Take the recoil cover off and look at it while pulling the cord to see if the fingers arent coming out. If the fingers are still coming out then you have worn out grooves on starter cone where fingers engage to turn the motor. If the recoil is damaged a new one can be purchased as a unit from Troy Bilt online for a reasonable price.
Jan 25, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Troy tiller won't crank
is it electric start or manual pull?? remove pulg and see if it cranks over. Could be mouse nest under recoil cover or under flywheel, could be rusted to the magnets. need more info. Oh yea make sure belts are not holding you back remove them or make sure they are loose.
May 05, 2011 | Troy-Bilt Pony Garden Tiller
PULL ROPE IS STUCK ON A TROY BILT BLOWER
Partial disassembly of the machine will be required to access/diagnose the exact problem. The starter/recoil unit goes on top of the flywheel and the flywheel is on the engine shaft. The obstacles will be removing the main cover (and getting it back on correctly). If you have never done this, them maybe take pictures as you disassemble it to help you reassemble. Once you reach the starter/recoil unit, you will see how it works and be able to resolve the problem. Some of these units have inferior design and engineering flaws where they mate nylon parts with metal and of course, the nylon doesn't hold up. Post back for more help if needed once you get to the starter unit.
Feb 10, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Looking for a recoil cup for a Troy-bilt chipper vac model 47282 with a tecumseh engine H5065582V. Thanks JR
Tecumseh part #36221 should be the starter cup you are looking for. It is available through www.partstree.com or try your local repair shop. Any shop that handles Tecumseh parts should be able to order it for you.
Dec 01, 2010 | Garden
How do I fix/replace the starter rope on a TB20CS (Tuffy Troy Bilt String Trimmer) that's broken? Do I need any special tools?
Probably no special tools needed. Take the starter assy off. Turn the recoil in the direction it will turn if you are pulling the rope. When it gets tight, hold it there and install the new rope. When it is installed, let go of the recoil and it will draw the rope in.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Troy Garden
Brand new, troy-bilt chipper model 4265. put oil in engine filled it with gas and tried to pull the recoil starter. It's locked up. I could lift this unit in the air with the recoil starter.
Sounds defective. Even if you could fix this problem something else is bound to go wrong. Troy-Bilt has a reputation for quality products and I'd suggest, since it's brand new, you get it replaced.
Apr 10, 2010 | Troy-Bilt Chipper Shredder
How to change the pull starter cord.
drill out rivets then re-rivet or use self tapping screws
Oct 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
