Question about Dryers
Nutone fan just installed model 773bnnt it is not working but shows electric current
4 Suggested Answers
bargainbin2
  • 123 Answers
SOURCE: Older Nutone bath- fan/light/heater Model
Most of the time is is cheeper and less time consuming to replace the unit than to find what happen to it and then order parts to repair it.
Posted on Aug 29, 2009
heatman101
  • 43501 Answers
SOURCE: Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Posted on Feb 28, 2010
karns
  • 122 Answers
SOURCE: we have a "Nutone"- ceiling
You might be able. check Ebay. but it being as old as it is, you may not be able to find parts anymore.
Posted on Aug 13, 2010
Nutone Model 671 Died and need Replacement
You should be able to use any replacement by Nutone. The kit should have finishing rings to install and cover anything from the old one.
Mar 12, 2014 | Broan-NuTone Dryers
Old NuTone 9093n Model replacement.?
Hi -- I just spent a couple of days taking out the old assembly, cleaning all the parts (layers of dust coats) and putting the 9093N back in order to fix the noisy fan. The cold air coming back in is from to the heating and I'd guess the heating element is busted. Yes, you can run it in both airflow modes: ceiling air exhaust and hot air blown to the floor. That said, the noise level on mine hasn't gone down. So I'll look for the replacement assembly. Good luck!
Mar 23, 2013 | Broan-NuTone Dryers
I would like to replace a Nutone 8663Rm series bath exhaust fan with a Broan 683L The 683L requires an opening of 8" X 8 1/4". Since access it is located in the attic, where it is unbearably...
You can buy a replacement motor assembly for that model.
http://vacuums-intercoms.centralvacuumstores.com/search?w=8663rmsa&af=type%3Aproduct&asug=&x=0&y=0
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rmsa&Search.x=0&Search.y=0
Jun 16, 2011 | Broan-NuTone N-8663RMSA Combination Light...
Can not find motor for LS100SE . ref p/n 62345000 given by Nutone
Packard Electric Motor Company model # 65345 is a direct replacement motor for the nutone LS100SE. It can be ordered from Conrey Electric Inc in Portland OR.
Aug 13, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Fan motor does not work.
The replacement motor is available for that fan model. The NuTone part number is the 0696B00. It can be purchase from these sites:
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://www.ventingdirect.com/nutone-0696b000-power-unit-assy-packaged/p431404?y=16&term=0696b000&x=41
Jul 24, 2010 | Broan-NuTone QT100L Fan
I am installing a intilitech 7 day in wall timer replacing an old mechanical 12 hr timer. The load is a 1/4hp 2 speed attic fan. The original wiring had hot in hot out of the timer. This has hot in, hot...
Utilitec does not make a 2 speed timer.
http://waterheatertimer.org/Program-wire-Utilitech-LW60419.html
1) One possible option is a timer with NO and NC terminals like Intermatic-Grasslin FM1 series rated 1 HP. This example timer would have the motor running continually on either one speed or the other.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/grasslin/fm1%20series%20time%20switches.ashx
2) Inside a 2-speed motor are two separate windings.
Windings are loops of copper wire that cause the fan motor to rotate.
For 2-speed, each winding has to be connected to a different 'switch.'
For example, like a ceiling fan. You pull the chain once, and electricity flows to one winding. Pull the chain again, and the switch sends electricity to another winding.
3) The following wiring diagram shows ordinary on-off timer connected to 2-speed switch: This is the basic plan for Broan Nutone 2-speed switch timer, which might be the product you are replacing
http://blog.airscapefans.com/wp-content/uploads//timer_option1_1-1024x768.jpg
4) Nutone makes a 2-speed whole house fan timer.
http://www.nutone.com/PDF/InstallGuides/CFS2WHins89777.pdf
5) And open following Broan Nutone manual that show the two spped timer wiring
http://www.nutone.com/PDF/InstallGuides/CFS2ins57169.pdf
Jul 01, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Nutone ls80l motor stopped working
If you remove the motor, which usually isn't to difficult to do. I would recommend plugging it in to one of your electrical outlets to check it. There is a possibility that the wiring is messed up or the plug in the housing went bad. If the motor doesn't work you need a new motor if it does work then you could try replacing the plug in the housing. All these parts are still available.
Here is a motor finder for NuTone motors:
http://www.centralvacuumstores.com/nutone/fan-motor-main.php
Here is the manufacturer you can get parts from them:
http://nutone.com/
Jul 14, 2009 | Broan-NuTone N-LS80L White Polymeric-...
Dryers Logo
16 people viewed this question
Top Dryers Experts
