Question about SanDisk Sansa e250 MP3 Player
Headphones My headphone wire ripped so i matched the colors and it still didn't work. The colors were 2 gold, 1 red, and 1 green can you please help me and tell me if that was right.
    Scholar:
  • 155 Answers
I would recommend purchasing a new headphone for the player that would be much easier. or you can try contacting sandisk to have your headphone replace and remember it will be a one time replacement.
Posted on Aug 29, 2007
6ya staff
SOURCE:
Sennheiser head-phone cable problem?
This should help, skip to the part where he starts soldering the parts
http://www.youtube.com/watch?v=OhnXUQRQ4u4
Feb 17, 2013 | Sennheiser HD428 Stereo Headphones
Replacing connector need to know wire color description. commons? red +? gold -? green? blue?
See my tip on replacing dodgy plugs/cables on heaphones. You will find it by clicking my name.
Nov 24, 2010 | Philips SHP 2500 Consumer Headphones
I need to replace my headphone plug end
See my tip on replacing dodgy cable and plugs on headphones.
May 26, 2010 | Sony MDR-V150 Professional Headphones
I have to replace the plug on my headphones. I have stripped both wires and found that there are two wires on each side. Am I correct in assuming that the gold wires on each side are the ground wires and...
Yes that's correct! The Red will be right and Green left. You might have to scrape the wire ends with a Stanley Knife to get solder to stick. It's best to apply solder to the wires first. I find that a bit of spit helps to get the solder on to the wires.
Jan 02, 2010 | Sony MDR-V150 Professional Headphones
Snapped off at jack leaveing three exposed wires
Yes.Here is some info:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
Oct 24, 2009 | Audio Players & Recorders
Dog chewed through Turtle Beach X1 wire any advice on fixing??
Your best long term fix will be to solder the wires together then tape them individually and finally tape the whole thing. Second choice will be to use crimp (**** splice) connections and then tape. Last choice will be just twisting stripped wires together and tape everything.
Mar 29, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Wire has been cut
My wire was cut, and I made it worse trying to fix it....with several failed attempts... was becoming despondent, but gave it one last try, and was successful. First, each little tiny wire has two internal wires, one green (ground) and one gold (hot). At first, the green one looked like some fiber or filler and I cut it, connected the gold wires and nothing happened. On further inspection, with magnifying loopes, I determined the green fiber was in fact green wire. There was also a lot of clear fiber, which is insulation? filler?... I don't know, but I cut it out, leaving only the wires. From the internet, I determined that the wires had a thin layer of plastic on them for insulation, which I burned off lightly with a lighter, connected the green together, soldered it, wrapped in electrical tape, then connected the gold together, soldered it, and taped again....and to my suprise it worked. I used twist ties, and epoxy to strenthen the area and was done, my headphones are working again.
Nov 04, 2008 | Bose TriPort Consumer Headphones
MDR-7506 - No sound on right side
It sounds like the pin cracked. If this is the case, you'll need to soldier a new jack on it. Here's how, assuming you already know how to soldier a new 1/8" TRS phono plug.
Cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Nov 01, 2008 | Sony MDR-7506 Professional Headphones
How to Rewire Sony MDR-7506 headphones
Okay, cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Nov 26, 2007 | Sony MDR-7506 Professional Headphones
SanDisk Sansa e250 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
