Question about Sewing Machines
How to change the stich on JC penney model 4102F
I had my machine on straight stitch and changed it. Now it will only zigzag. How do I change it back to straight?
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
bargainbox
  • 1388 Answers
SOURCE: kenmore 14 stitch machine
Adjust the width selector to zero
Posted on Mar 16, 2008
  • 1027 Answers
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
kent581
  • 87 Answers
SOURCE: FEW STITCHES DROP IN BOBBIN
Dropped stitches troubleshooting:
1>change to a new proper needle (proper needle means quilting needles for free motion, stretch needle for knits, leather needle for leather, microtex needle for micro fabrics.....etc.) of proper size. Most sewers never need a needle smaller then an 80/12 when sewing. Smaller needles bend more easily causing more problems.
2>If a new needle doesn’t fix the problem, remove parts from bobbin case area (as best as easily allowable) and clean out all the lint thoroughly, and oil with 2-3 drops of oil where friction occurs (turn hand wheel and look for rubbing)
3>If still skipping, try a different spool of thread (Yes, thread can caused skipped stitches, not common but I see it).
4>If you haven’t solved it yet, sounds like you could need to make a lower level adjustment like hook timing.
Hook Timing:
To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher
Posted on Mar 21, 2009
Maggie_B
  • 3 Answers
SOURCE: Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
Posted on Oct 31, 2009
I have a Bernina 1030 and the size of the straight stich knob is jammed it willonly turn back to 1 which means it will not straight stich just a small zigzag. Can you please help.thanks Joy
I suspect the machine's stitch selector mechanism has seized due to old, dried oil. (I have a 930 and several older Bernina models, and oiling thoroughly and frequently is necessary to keep these nice mechanicals running smoothly.) However, if the knob on the straight stitch selection lever is frozen, you may need to take it for service if you are unable to free it on your own.
Wheel on right side that controls the needle up and down is very tight...
Aug 08, 2017 | Bernina Sewing Machines
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Elna 3007 reinforces every stitch.
It is in Stretch Stich mode....(SS)
Check your manual to reset in normal mode
Apr 07, 2014 | Elna Sewing Machines
Janome 6125qc
Although you have selected a zigzag have you also set the stitch width and length manually as required? Some stitch types have restrictions on the width you can set so it's important to know which these are.If you don't have the instruction book it is available as a free download from Janome. Go to www.janome.com, click on the Machines tab then choose 'retired' and scroll down until you find the 6125QC - the link to the user guide is in the top right corner of the specifications tab.
Nov 02, 2013 | Sewing Machines
J C Penny zigzag sewing machine model 6600
Am looking for the accessory parts that come with the JC Penney Model 6600 sewing machine any ideas?
Aug 11, 2012 | Singer 5062 Mechanical Sewing Machine
I don't have a manual for a Husqvarna 6440 and don't know how to switch from zigzag to straight stitch. Everything else seems to be sewing beautifully and it was on straight stitch when I first tried it. I...
You have 3 knobs/dials on the machine, the top left dials the stitch, the top right sets the length and the bottom right set your width. set it 0 for straight.
Mar 03, 2010 | Sewing Machines
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
