Question about Morphy Richards GBD239H9B Microwave Oven
Where is the bolb i need to change it - Morphy Richards GBD239H9B Microwave Oven
Why are underneath lights not working?
Either the bolb is broken or power connected to light is broken. Check voltage on connector to bolb.
Sep 29, 2015 | GE JVM1651 Microwave Oven
I have a mh1150xm microwave and changed the cooktop lightbulb. Still no light. A tech came and said that need to change whole control board. Is this true. Everything is working fine exept the light
I take it you did replace with a bulb designed to withstand heat.check the filament of bulb first these sometimes get damaged in transit.if the microwave is coming on then it won't be the fuse.if the bulb looks okay(you can check using another) finally inspect the door latch and the bulb housing and wiring to it.Sometimes door latch hole can get debris into the mechanism.cost of panel via engineer can cost quite abit..is it still in warranty? Price compare the estimation against buying new replacement.
Feb 09, 2015 | Whirlpool MH1150XMQ Microwave Oven
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
Ge profile microwave jvm1870sf02 buttons don't work do i need to change the control panel frame or Bkt c/panel
You will need to change the keypad along with the control board, because they are essentially of one piece. But the part will equal, if not more than a new microwave oven.
Apr 08, 2012 | GE Microwave Ovens
What do I change when I go from propane gas to natural gas on my Maytag mgr5870bdw Do I change something or do I adjust something? HELP ! Chuck
You will need to change the gas orifice for the type of gas you'll be using. You also may have to change the gas regulator, but you should check the installation manual for details.
You can also contact Maytag by calling 1-800-688-9900 to get the exact part numbers you'll need to make the conversion correctly.
Hope you found this helpful and best regards!
Aug 07, 2009 | Maytag MMV4205 Microwave Oven
Need help on how to change time on oven
To change the time push the clock button then use the key pad to enter the correct time and push the clock button a SECOND time.
May 20, 2009 | Microwave Ovens
Need service manuals for amana HDC12 & HDC12A2 microwaves
Unit says change filter and do not Know what that is talking about? Also need to Know how to clear change filter off of screen?
Mar 17, 2009 | Amana HDC12 Microwave Oven
Microwave inside light does not come on
Assuming everything else is working, then I would assume the bulb is out.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 13, 2008 | LG Microwave Ovens
Morphy Richards GBD239H9B Microwave Oven Logo
15 people viewed this question
Top Morphy Richards Microwave Ovens Experts
William Miller
William Miller
ray gallant
Are you a Morphy Richards Microwave Oven Expert? Answer questions, earn points and help others
