Question about Sewing Machines
How to tread elna 1002 sewing machine - Sewing Machines
SOURCE: Elna sewing machine, the timing is out.
Hi, Purchased an elna contessa 130. could anyone advise threading procedures , as we do not have a manual with it.......problem with top tension.
Many thanks
Maureen
maureen.reinberger@gmail.com
Posted on Aug 02, 2008
  • 14 Answers
SOURCE: ELNA 7000 SEWING MACHINE
If you bend over the front of the machine, you will see a slider switch on the back of the machine, and there is a small "button" at the bottom right of the switch (your right). If you push this button down, you can slide the slider switch to your right and the feed dogs will go up.
Posted on Mar 26, 2009
Sewtech1
  • 69 Answers
SOURCE: elna su motor won't turn off
it is only your Capasitor that is faulty and can be by passed
Posted on May 01, 2009
  • 6 Answers
SOURCE: Manual for Elna Contessa 310
www.janomestuff.com
Posted on Sep 18, 2009
SOURCE: service manual elna 722010 sewing machine
www.whitesewingcenter.com has the manual for an Elna 722010.
Posted on Mar 27, 2010
I have an old elna sewing machine and it started skipping stitches badly I noticed when rethreading it does not want to pick up bobbin thread.plz help with info .Nicole
indicates a needle /hook timing issue
check for correct needle and that he needle in in correctly
possible that the needle tread tension is too light
Feb 11, 2018 | Elna Sewing Machines
I have a elna 664 pro overlocker. The thread keeps on breaking. I have even serviced it. It came back. Worked a while and it started doing it again. Works a few stitches and the tread breaks
Hopefully, it was recently serviced. Take it back and have the technician take another look at it. Do NOT unthread it (just clip the threads below the thread tree) when bringing it in so the technician can verify it is threaded correctly and also see where it may be hanging up.
Jan 29, 2018 | Elna Sewing Machines
How to tread elna overlocker
Search for:
Make Model manual
or
Make Model threading
Be sure to ALWAYS RAISE the presser foot when threading the machine!
May 20, 2017 | Elna Sewing Machines
Elna 6005 - I need to move the tension dial to 9 to get an even stitch. I re-treaded the machine and bobbin and it is still the same. Any solutions?
it is common when threading a machine for the top thread to get behind the tension plates and not between them
this makes it bind up on the mount bolt and gives false tension settings
even threads also depend on the bottom thread tension which is adjustable by the tiny screw that holds the spring clip that you pass the thread under when you put the bobbin back in the case
try going google --type in-- workshop manual for elna 6005 --and see if there is a pdf version available,
Sep 06, 2015 | Elna Sewing Machines
Manual for elna lotus sp
follow this link for free download
http://www.scribd.com/doc/25386753/Elna-Lotus-Sewing-Instruction-Manual Elna Lotus Sewing Instruction Manual
May 06, 2014 | Elna 2007 Mechanical Sewing Machine
I have thread stuck in my machine. The tread is fed from the spool and I'm wondering if I can oopen the machine cover located above the pressure foot.
Maybe: look at p. 90 of the manual: http://www.elnausa.com/data/files/2_users/55/Inst_book_eXplore_320-340.pdf Take the screw out of the left side of the machine -- it's hidden under a cover -- and remove the face plate. That may give you access to the threading path, and then again it might not. Generally speaking, opening the case beyond what's specified in the user manual will void the warranty on most machines.
Mar 01, 2014 | Elna Sewing Machines
I dont know how tread my 634elna serger
you can try youtube for a video or here are 2 links for a manual, this website has a live chat, so you can make sure it's the right manual for the machine. Instruction Manual Elna 634
Jan 19, 2014 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
