Question about Health & Beauty
Can we remove the governor on a gio 500w mobilitty electric scooter
We get 12 km/h on this scooter can we do something to increase the speed?
SOURCE: how to increase speed?
You can bore out the barrel to take a bigger piston or swap barrels from a 110 or 125. I know the 110 barrel can be taken out to take a Kawasaki 150 piston. This will need a new CDI and best to modify the exhaust too (more free flowing). I've done this with my Honda C70 and gone up to a wave 125 piston. the only thing holding me back is the 3 speed gear box but I have changed the sprockets to give higher cruising speeds.
You will need a bigger carb. Honda Dash Carb is just spot on. Its a Keihin and get an original (with the heavy plunger) not a cheap fake. They can stick open causing problems!
Posted on May 02, 2010
damneddle
  • 1607 Answers
SOURCE: A bicycle travels 12 km
18 km/hour
The bike is traveling at the speed of 12/40 = 6/20 =18/60
18 km/60 minutes
Posted on Jun 21, 2011
  • 14585 Answers
SOURCE: How to remove speed limiting governor from nissan UD model:- GKB4CLBHNB engine model:- GEBT1GGK-N,YOM:- 2007.We can speed to vehicle upto 65kmph only.we need to remove governor please advise me.
There isn't one. First I would replace the fuel filter. After that I would do a diagnostics's on the engine and transmission.
Posted on May 14, 2015
  • 12962 Answers
SOURCE: I have a gio electric scooter and it sometimesoon looses all power and then the only way I get any power is to have the charger plugged into it what's wrong with it
It appears that you may have battery issues. Check out the battery and replace if necessary.
Posted on Aug 21, 2015
gregg201
  • 45650 Answers
SOURCE: chinese scooter yy50ccqt-6 cutting in and out at high throttle
Hi, Michael for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Johnway, despair not, for a mere $0 you can download another one I could only find one similar but has the same engine. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
scooter bogs down when throttle it Scooter Doc Forum
Bike cutting out at Full Throttle 50cc Scooter
http://www.extremescooters.biz/manuals/gy6_service_manual.pdf
http://www.carlsalter.com/pdfs/Jonway%20YY50QT-6.pdf
Posted on Jul 01, 2016
Cruise control stop working light dont show on dash can a fuse be out if so where is it located
There are three fuse's in the smart junction box , do you know where it is ? It's under the dash panel left side ! The fuse's are F2.27- 10amp , F2.32 - 10amp , F2.17 - 15 amp . They power the speed control servo ! Maybe the control switch's on the steering wheel don't work.
A little back ground on the system ! Speed Control The vehicle speed control system consists of the following components:
  • Brake pedal position (BPP) switch
  • Speed control actuator cable
  • Speed control switches
  • Speed control deactivator switch
  • Speed control indicator
  • Smart junction box (SJB)
  • Principles of Operation
    The speed control system is designed to maintain vehicle a set speed above 48 km/h (30 mph). After the speed control ON switch is pressed, pressing the speed control switch SET/ACCEL will activate the speed control actuator. To increase a set speed, either press and hold for continuous acceleration, or momentarily tap the speed control switch SET/ACCEL for 1.6 km/h (1 mph) acceleration increments. To decrease a set speed, press and hold the speed control switch COAST until the target speed is reached, or momentarily tap the speed control switch COAST for 1.6 km/h (1 mph) deceleration increments. When the speed control system has been disabled by tapping the brake pedal, the speed control switch RESUME can be pressed and the vehicle will return to the original set speed if the vehicle is traveling over 48 km/h (30 mph) and the speed control switch OFF has not been pressed.
    NOTE: The deactivator switch is provided as an additional safety feature. Normally, when the brake pedal is pressed, an electrical signal from the brake lamp circuit to the speed control actuator will deactivate the system. Under increased brake pedal effort, the deactivator switch will open and remove power to the speed control actuator, releasing the throttle independently of the speed control actuator.
    NOTE: The clockspring provides the electrical interface between the steering column wiring and the speed control switches in the steering wheel.
    The inputs to the speed control actuator are:
    • Vehicle speed signal
    • Deactivator switch
    The outputs of the speed control actuator are:
    • Speed control indicator lamp
    • Speed control actuator cable controlling the throttle position
    • Inspection and Verification
      NOTE: If any concerns are noted with the speedometer, stoplamps, or horn, address those concerns by referring to the appropriate sections before continuing speed control diagnosis.
      1. Verify the customer concern by operating the speed control system.
      1. NOTE: Any aftermarket modifications, including but not limited to those listed below, may cause the speed control to not operate correctly:
        • Any wiring or lamp modifications affecting the brake lamp operation
        • LED brake lamps
        • Non-factory installed trailer wiring
        • Radios (speed sensitive, auto mute)
        • Remote starters and alarms
        • Lighting and electrical accessory modifications
        Visually inspect for obvious signs of mechanical or electrical damage:
        • Visually inspect the speed control actuator and accelerator controls.
        • Visually inspect the speed control cable without removing it and ensure smooth cable operation. Inspect the speed control cable connection to the throttle body.
        • Visually inspect the accelerator cable without removing it and ensure smooth cable operation. Inspect the accelerator cable connection to the throttle body. Also check for cable interference with the carpet, bulkhead grommet, insulation and instrument panel wiring.
      1. Visually inspect for obvious signs of mechanical and electrical damage.
      2. Visual Inspection Chart Mechanical Electrical
        • Throttle linkage
        • Battery junction box (BJB) fuse(s):
          • 4 (40A)
          • 12 (60A)
        • Smart junction box (SJB) fuses:
          • 14 (15A)
          • 57 (10A)
        • Wiring harness
        • Loose or corroded connections
        • Powertrain control module (PCM)
        • Bulb
Mar 14, 2015 | 2007 Ford Taurus
I have a Titan 7000 generator I just bought used. It needed a capacitor, so I bought one from Titan. It starts and runs ok but at an idle it barely put out enough power to light a light bulb. If I increase...
hi
ok this is how generators work principally when the engine starts it will just tick over ( 700/ 850 rpm. ) but once you plug in for electric power the generator engine automatically speed up . this is done by two item as the voltage regulator demands more power the governor
open up to increase speed engine .
solution check that the mechanical part of the governor is not sticking , check that air filter is not clogged up as this also stops the governor to function properly
Dec 25, 2017 | Electrical Supplies
I have a Gio 500w ebike. The tube inside the back tire needs to be replaced and I cannot find the size to buy anywhere.The Gio website sells them but dont give u the size. I was also told that you can...
Hi! I have 2 Gio Scooters. I looked and looked for a tube for my tire and couldn't find a place until I realized that if you go to Ebay online you can actually buy them through Sven the supplier who sells the Gio Scooters on Ebay. You can just buy them from him and pay through paypal. Make sure the valve is curved and not straight out or it's not the right one. He ships pretty fast too:) I hope this has helped. It took me awhile to get parts. He also will ship parts, he's out of Vancouver. So Good Luck:) Do you know anything about fuses for these bikes???? Grrrr....
TTYL.G
Jun 15, 2011 | Health & Beauty
Scooter cuts off while operating
Scooter hesitates when running or increase in speed could jump forward???
Jul 18, 2010 | Electric Mobility 3 Wheel Motorized...
I have a 1998 murcery villager. there is an assessory box attached to the covering of the driver side axel ampl assy-ws/w f4xa17a431aa 28510 ob710 et20 123 12 v jideco i believe this has something to do...
go to our villager site for help. The wiper motor has a governor assy, that is what you are referring to. What is the problem?
Windshield Wiper Governor Removal
The windshield wiper governor (17C476) is located on the LH side of the engine compartment behind the battery (10655) .
  1. Remove the two windshield wiper governor screws and the windshield wiper governor .
  2. Disconnect the two windshield wiper governor electrical connectors.
http://groups.yahoo.com/group/villagerquest/
Apr 05, 2010 | 1998 Mercury Villager
Speed Limiter/Governor issues 2001 Olds Alero
t there is no mechanical speed governor. It is controlled by the PCM - engine computer which you would have to reprogram to increase the limit. Dealer only
Nov 07, 2017 | 2001 Oldsmobile Alero
Up and down Lawn Mower RPMs
Spounds like a problem with the governor. There should be a spring or something tied to your governor. The governor adjusts your air fuel mixture according to the load. Look closely at all points of connection...Lee
Sep 13, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Health & Beauty Logo
32 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
