Question about SanDisk Sansa e250 MP3 Player
I turn on my sansa e250 it goes to refresh database, then blanks
I went to recovery mode then it says to enter USB2.0 MSD MODE i dont know how to get there
  • 34 Answers
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Posted on Jul 22, 2009
SOURCE:
mixmaster
  • 626 Answers
SOURCE: my sansa e260
Change the USB port on your computer.
If that doesnt resolve it, check the HOLD switch to make sure it is sliding over all the way.
Best of Luck.
Posted on Oct 25, 2007
  • 3 Answers
SOURCE: USB2.o and MSD mode
You need a memory card.
sincerely, Britani
Posted on Apr 19, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: help please
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
SOURCE: Sansa e250 has Refresh Database Frozen
Look at this site:
http://www.expansys-usa.com/ft.aspx?k=89682
follow the steps showed by MrSinister27
It worked for me!!
Posted on Jul 23, 2008
  • 4 Answers
SOURCE: Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Posted on Aug 26, 2008
How can I enter de USB 2.0 MSD mode to fix muy sansa e280
To change to MSC, Scroll to settings, scroll down to USB Mode, and choose MSC. You should be good
Apr 05, 2010 | SanDisk Sansa e250 MP3 Player
Refresh database loop
SCREN LOAD MAIN IMAGE FAILED SWITH TO RECOVERY MODE
WHAT HAVE ?
Sep 24, 2008 | SanDisk Sansa e250 MP3 Player
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
My sansa is spazzing out
Go to settings - USB Mode -- msd; and make sure the port on your computer is a USB 2.0 port.
Jul 05, 2008 | SanDisk Sansa e250 MP3 Player
USB2.o and MSD mode
sincerely, Britani
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 locks up in refresh database during startup
if the computer can find ur sansa(or 16mb format) you should rightcliick and format it. this will delete ur music, videos, etc but it will make ur player usable
Mar 17, 2008 | SanDisk Sansa e200 MP3 Player
Refresh database fail
Hi try this for me see if you can put your mp3 into recovery mode if it goes into recovery mode then i tell you what you need to do next ok follow these instructions
1. with mp3 off switch lock button to on position
2. press and hold rec button on left hand side
3 whilst holding down rec button switch mp3 on this should now be in recovery mode let me know if you get this far ok
Feb 23, 2008 | SanDisk Sansa e250 MP3 Player
Recovery mode and USB2.0 mode
my sansa sandisk e200 was plug to the pc i then remove it and plug another device.when i later power it on all it could display "refresh database".also i fix it to the pc another problem is "recovery mode and usb2.0 msd mods"
Feb 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa 250R ~ It will not reformat
how can i refresh the data base, tks
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Try emailing SanDisk technical support team at: support@sandisk.com And ask them for the Recovery Mode firmware upgrade (Also send them the problem the way you posted it here). They should send you a link to some firmware upgrade file. You could also try calling them at: 1-866-726-3475 but an email should be sufficient because, from what I remember, it is just a link to file that you need to download. I hope that helps...
Feb 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
176 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
