Whirlpool sm8525492 Agitator not working properly . It moves but feels loose
Jimster
  • 240 Answers
SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Posted on Oct 24, 2007
SOURCE: Whirlpool Ultra Care II
how easely can it be changed. Tell me what to do. George
Posted on Jan 08, 2008
Thanks! Removed the fabric softener dispenser, then the plastic cap with the raised plastic strip, inside the post by reaching in and twisting until the o-ring seal becomes free, then removed the bolt using a 7/16" socket with a long extension. Walked in the washer supply store with the whole module that holds the dogs and the man at the counter saw it in my hand, reached under the counter, laid the 4 plastic dogs on the counter without me saying a word and said "that all you need?" think they sell a lot of them? part number fsp-80040. repaired in 40 min.s including the 5 mile trip to the parts store!
Donna K.
Posted on Jun 19, 2008
  • 958 Answers
SOURCE: loose agitator on Whirlpool Ultima Care II washer
it could have stripped the spline on the plastic agitator. there is a bolt at the middle of the agitator and you can access that thru the top . remove the top cover and you can remove the bolt using a deep socket.
once you remove the agitator you can look at the dog agitator. these a 4 pcs plastics that works like a one way wrench.
be careful on the location, they are very hard to put back.
check also the spline on the inner part of the plastic assembly.
they do get stripped.
if they are, replace the whole agitator.
tnx 4 using fixya,
drcool
Posted on Sep 07, 2008
cjrepairs
  • 60 Answers
SOURCE: My whirlpool washer, model #sm8525492-a doesn't
check that there is a rise on the outlet pipe as if this drops onto a low level it may cause the problem you describe.
Posted on Aug 16, 2009
The agitator on my Whirlpool washing machine isn't working properly. It is moving a little bit but not fully, any help?
You may have worn out agitator dogs. Those are replaceable parts. Not sure which model you have, but if you google for:
whirlpool agitator dog replacement
you should get plenty of hits.
Apr 01, 2015 | Whirlpool Washing Machines
WHIRLPOOL MODEL LSQ8543J TOP AGITATOR DOESNT MOVE. THE BOTTOM AGITATOR MOVES FINE DURING THE WASH CYCLE BUT THE TOP AGITATOR HAS STOPPED MOVING. HELP!!!!! WHAT COULD THE PROBLEM BE????
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the proper inspecting and replacement of these parts. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
May 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
The agitator arm is intermittent on my ultimate care II
If this just a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 07, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Hi, This agitator is a 2 piece agitator. Can you see if the lower half on the agitator is working properly? If the lower part is working and the top is not, you will need to change the agitator dogs. If neither half are working, you might be having transmission issues.
To change the dog kit, re,ove the top cap on the agitator and locate a 7/16" bolt. Remove the bolt and the agitator will lift out. Pull the agitator apart and the dogs are 4 small plastic pieces inside the top half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator movement
Hi, If this is a two piece agitator, start the wash cycle with no laundry in it and see if the lower half of the agitator moves. If the lower half works, you will need to change the dog kit inside the agitator. There is a 7/16" bolt under the agitator cap the will need removed to get the agitator out.
If the agitator does not move at all, It could be the coupler connecting the transmission to the motor. If the coupler is bad, tub will not spin the laundry dry.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Whirlpool LSN1000LW Top Load Washer
My agitator on my whirlpool washer doesn't work properly and that keeps the clothes from getting clean. it seems as something is loose,the bottom part works somewhat but the upper of the agitator's not...
The top portion of the agitator is designed to go in only one direction. The purpose is to keep the clothes moving from top to bottom of the basket. When this "ratchet" action fails to occur, it's due to worn "agitator dogs" (part # 80040) usually caused from overloading. It can be a do it yourself repair, or a very inexpensive service call if a professional is used.
http://www.servicematters.com/docs/part_instruct/285747.pdf
Jun 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
if the agitator barely moves, sounds as if yo have a bad set of agitator dogs, part number 80040. if you removeth agitaotr,(7/16 screw) down the center ofthe shaft. yo can removeth efabric softener dispensor by hitting with the palm of hand. after removing the agitator, it can be split in half to reveal hte "agitator dogs" easy repair problalbby about $20 and 30 min tops
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Adjetator (sp) isn't spinning properly .
The agitator dogs (little dog ear gears) are stripped. This is a very easy fix and the new dogs are very cheap. Go down to an appliance part store and ask them for agitator dogs for a direct drive whirlpool washer. Ill help too with installtion
Jan 12, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
