Question about Dryers
Dryer just quit
I have an older Kenmore electric dryer - 80 series. I was doing laundry the other night, took clothes out mid cycle, added new clothes, reset time, and hit the start button. Absolutely NOTHING happened. I've checked all circuit breakers in the house as this is how it seems to be acting, but no help. Is ther some kind of internal circuit breaker I can check?
  • 6 more comments
  • russFixYa Nov 16, 2007
    Series 80 Kenmore. When we push on the power button, nothing happens. It receives power, the timer will run. Using a similar problem solution, I removed the fuse, ran a test of the machine by joining the two contacts temporarily and plugging in the machine. It then runs. So, we will pursue getting a new fuse. And for now we will assume we are back in business.
    What we don't know is why the fuse failed! Any suggestions to consider, beyond a clean lint catch, a clean and none kinked venting system, both of which have been checked.
    Note: we did have electrical work done on the main breaker box
    yesterday, we have not noticed anything else having problems, however.
  • Anonymous Nov 30, 2007
    I have a 70 series, the light when the door is open comes on telling me their is power, However when pushing the button to run it won't do anything.
  • Anonymous Feb 15, 2008
    How do I replace the door switch?
  • Phil Acton Mar 02, 2008
    I have the same dryer with the same problem. If you know what is wrong and have a diagram on how to fix it, it would be greatly appreciated. Thanks.
  • jazens Sep 01, 2008
    have a kenmore 90 series dryer completed a load last night, went to turn it on today and nothing happened when I pushed start....light still functions in the dryer as well as everything else in the house.....including the washer and everything in the bathroom that the dryer is located in. please advise.
  • chisnme3 Oct 04, 2008
    I was drying clothes, took a load out, put a new load in, hit the start button....nothing. Continued to try to hit start, no luck. Next day, still won't start. What is wrong? How can I fix it?
  • Anonymous Nov 18, 2008
    same problem - less than 2yrs old - poor quality!
  • goldmount Feb 27, 2009
    I had the same problem that many of you had and I followed the instructions and found that I had a bad fuse. Thanks
  • 291 Answers
I would check to see if you have 220v to back of dryer where the cord mounts to dryer Check the door switch, , Take back off dryer There is a fuse in the back its white oblong 2 wires coming from it, left side on blower outlet ..be carefull hook the 2 wires togather and if it comes on the fuse is bad needs replacing same way with the door switch.
Posted on Aug 29, 2007
    Problem Solver:
  • 8 Answers
The problem with mine was the same, it just quit. My problem was a little circuit board that is in the housing the start button and the timer are in. Two phillips screws and it comes off. Make sure the dryer is un-plugged. Then turn the housing so you can see the parts inside just pull the 2x3 inch p.c.b it unplugs like a anti theft chip the cars have now days. Test the continuity, but the door switch is the most common problem. The only thing I haven't replaced on my dryer is the motor. I guess that will go next. GOOD LUCK.
Posted on Nov 23, 2008
Kenmore 90 series electric dryer quit mid cycle
quit what? power loss? quit moving? more info please
Jan 03, 2014 | Kenmore Dryers
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
Whirlpool washer periodically will stop mid wash cycle. And won't restart until hours later. Seems to only happen when I need to do lots of laundry what is going on
THIS IS A BALANCE PROBLEM, IF YOU ARE PUTTING A LOT OF CLOTHES IN AT ONE TIME, YOU WILL HAVE TO BALANCE THE CLOTHES WHEN IT STOPS, DONT OVERLOAD IT, AND MAKE SURE YOU ARE EVENING THE CLOTHES OUT IN WASHER ESPECIALLY BLUEJEANS AND HEAVY THINGS, I KNOW MY WIFE DOES THIS HA, TRY THIS AND LET ME KNOW THKS LARRY
Apr 26, 2010 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
I have a kenmore 80 series dryer.When using the auto cycle the clothes come out damp
Kenmore Dryers are all almost the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
May 15, 2009 | Dryers
Kenmore Series 80 (110.74882401) heat cycles on only for 10 secs
This is a pretty easy fix and I recently had the same problem. I made a quick video about it. The problem was the dryer was run only a few mins then quit. The dryer limit was tripping because the control thermostat was not shutting down the lower safety limit was tripping and the power from the control thermostat was diverted via the orange wire to the timer motor which kinda caused the main motor to stop. When i ran the dryer in NO HEAT the dryer stayed running and that was my clue as to what may of been happening and that was the problem in a nutshell. My video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 21, 2017 | Kenmore 659 Electric Dryer
Dryer
dryers take a lot of power to run.the circuit is tripping because it cannot take the load of the dryer.you may have to get a dryer line installed.check the value on the circuit breaker.u need to use twice that value on the dryer.with clothes added to the dryer the motor takes more current to spin.this extra current is greater than the circuit breaker value so it trips to prevent the house wire from going on fire.
Jan 07, 2008 | Kenmore 63942 Dryer
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Dryers Logo
413 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
