Question about GE Refrigerators
How to test dispenser control board on gss25wsti
2 Suggested Answers
  • 2533 Answers
SOURCE: GE side by side refrigerator in home just purchased. No water to ice maker or water dispenser. Replaced filter to no avail. - Model # GSS25WSTI SS
Check with where you purchased it if its new.
Posted on Dec 23, 2017
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
GE profile refrigerator ice maker not working
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
  1. Dispenser switch
  1. Door switch
Water dispenser doesn't work
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Maytag MSD2756GE ice maker issue. makes ice fine. While dispensing water in the door, it also fills the ice tray at the same time. Water comes out ice fill tube AND door. If no water is called for at the...
This is an odd one!The water control valves has separate sets of wiring that travel through the dispenser control board. That gives an opportunity for strange things to happen as mentioned in your post. If you haven't replaced the dual water control valve and put the wires back wrong the next thing will be to test the 61005274 Dispenser Control Board
If you have a OHM meter and a voltage testing meter I don't mind helping you to test the wires and 61005274 Dispenser Control Board I can send you to a link to view the wiring diagram and walk you through the diagnostics. Let me know, Thank you, John T
Appliance 911
Contact Me Here
Apr 27, 2014 | Maytag MSD2756G Side by Side Refrigerator
The water dispenser in our GE side by side fridge model gss25wsti made a loud grinding noise and stopped working Has anyone experienced this or have any suggestions
First the water dispenser will not make any grinding noise while dispensing water perhaps a hum. The grinding noise is from the auger motor which dispenses crushed ice ad ice cubes. So please check the intake valve at the rear of the fridge if its working, if not you may have to replace the intake valve. Or if that"s ok please check the control module on the door of the freezer.
Jan 13, 2014 | Refrigerators
Whirlpool refrigerator model no. gd5nhaxso00 makes beeping sound at dispenser
I have heard of this same complaint that customers hear a beeping sound coming from the controls at the dispenser panel and this usally will be a sign that the 2303843 Dispenser Control Board is failing. Do have anything that appears not to function properly there in the display? Insure that you hear the sound there and if you do we will need unplug power to disassemble the dispenser housing and have a look at that board. Here is a link to a GD5NHAXSB00.Parts Manual and a D5NHAXSB00 User Manual. Let me know if you will like my assistance testing the board or removal and reinstalling the board, Thanks Sea Breeze
Jul 04, 2013 | Refrigerators
Softener or Bleach will not dispense. Any idea how to fix this problem? I have Neptune TL washer FAV6800AWW.
For the FAV6800A or FAV9800A:
If you have no water flow to the Softener dispenser or Bleach dispenser see if you can turn the dispenser valves on Service Mode and verify water flow to the reservoirs.
Enter Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the
Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the Fabric Softner dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Softener dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open or loss of 120VAC from the Control Board to the valve. Do the same for the Bleach Dispenser Valve.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Bleach dispenser valve.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or find best price. Before I would order any parts you need to isolate the fail point, this could be a Control Board issue or machine wiring harness issue.
Did both reservoirs stop flushing contents at the same time or different fail dates?
Rich
Apr 01, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Will not dispense water only ice.
I will need the model number to proceed. But it does sound like the dispenser control has malfunctioned. If you get the number for me will you be able to let me assist you. We will need to test wiring in the keyboard, control board, hinge, back to control board if needed, Let me know, Sea Breeze
Dec 17, 2009 | Maytag Refrigerators
Maytag refrigerator no power to dispenser control board
I believe looking over the service manual that white is the common. and it should be the one to test the keyboard before the keyboard plugs into the control board. If you would like the service manual please let me know because it does show some test to eliminate the origin of the problem, Sea Breeze
Sep 11, 2009 | Maytag MSD2655HE Side by Side Refrigerator
Ice and water working intermittently, makes ice, Artica PSS 26NG
Go into the test mode and use 0 4 as the test code between the dispensor board and the main board .(communication test) Sounds like the main control board though .
Jul 18, 2009 | GE Profile¿ Arctica® Energy...
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
