Question about Garden
Bolens bl110 Trimmer Head spins freely and I cannot remove the String spool.
woobie dog
  • 1273 Answers
SOURCE: how do you remove the head off of a string trimmer
It should pull straight off.
Best regards, --W/D--
Posted on Aug 18, 2009
  • 881 Answers
SOURCE: How do you Replace string on the trimmer head spool
Take the spool off and turn it up side down take out the centre and wind the left side 6 times to the left and the right side 6 turns to the right then put the ends through the holes and refit to stud and screw on butter fly nut...
Dont try winding them both the same way as when you try to get more out 1 side will come out and the other will go inside so you will be back were you started
Posted on Sep 27, 2009
  • 51 Answers
SOURCE: my pull string came out and will not retract on my
the coiled rewind spring ends are bent back in a hook. the hook usually breaks so springdoes not wind up. some times you can re bend but steel is very brittle and keeks breaking and must be replaced
Posted on Jul 18, 2010
riceski
  • 1851 Answers
SOURCE: I am tryinng to remove
These are REVERSE THREAD - this should do it - turn it the other way.
Gary @ Fix Ya
Posted on Sep 05, 2010
rycgl
  • 1545 Answers
SOURCE: I have a Echo Gas trimmer SRM-210 Rapid feeder
In your manual under section 12: Line Head Installation. You will do the opposite of what it says here. The key is to LOCK the gear drive so the flex-drive shaft won't turn WHEN you are removing the trimmer head. They use a special tool (maybe you have it). But a small-shafted Phillips screwdriver or the like can be put in the drive hole to lock the gearing up as well. Look for the hole in the upper plate and align with the notch in the drive housing and grasping the entire string head unit, remove it. Here is your manual, see Section 12
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
Posted on Jul 17, 2011
The head on my Bolens BL110 weed eater is slipping
Check the drive shaft. Within the drive tube there is a tightly sprung drive shaft, check where this connects to the head of the cutting attachment, it could have a worn drive.
http://www.ereplacementparts.com/mtd-bl110-41ad110g965-trimmer-parts-c-20039_20040_143532.html
Apr 10, 2016 | Garden
The line that I'm looking for came as stock supplied when I bought the trimmer.I can't believe that Bolens doesn't have a scource for replacement line. Help. Gene
Genuine MTD 791 181460B Reel Line Assy McCulloch Ryobi Troy Bilt Bolens OEM
Reel and Line Assembly
Bolens String Trimmer Spool 791 153577B
the spools come with line already installed,they are all for bolens,line is generic,you buy your own line,there are 2 different sizes,and a bunch of types,like round or star,you buy generic line because bolens wont make any money if they sold "BOLENS" line.
Jul 11, 2015 | Garden
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
What could be causing this?
to much dirt got up in clutch housing and shoes are not making full contact unit needs to be dissembled and cleaned.
Sep 06, 2012 | Garden
I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
May 06, 2012 | Garden
My pull string came out and will not retract on my Bolens BL110 2 cycle gas trimmer. How do I fix this?
Jul 17, 2010 | Mtd Garden
The string on my spool ran out.
• Turn off the trimmer and remove the battery
• Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
• Lift the spool of nylon line out of the hub and clear any broken line and debris
• In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
• Pull the line through the hole to maintain tension while placing the
spool down into the hub with the notched side exposed.
• Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
• Snap the spool cover back on.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
