Lenovo Z500 battery
I have a 3 month old Lenovo Ideapad z500. Battery is stuck on 22% charged and computer does not run on battery
I did not work for me in the beginning because Z500 didn't know it had a battery.
1. First do a clean install of Windows 7.
2. Install all the drivers only for Lenovo site and respect the restarts. Install Lenovo Energy Management last. Go to Lenovo Energy Management and set it for full Performance.
3. The indicator in the animation should be far right not center.
4. Go to Advanced Power Settings in Control Panel -> Lenovo Energy Management and hit ENABLE
5. Now you restart and you should be able to do the firmware update
6. If you cannot do the firmware update then uninstall LEM, remove ACPI from Device Manager, Reinstall LEM, Enable again.
7. If you cannot do the firmware update then try battery gauge reset in Safe Mode and remove ACPI after, and then Reinstall LEM, Enable.
Posted on Feb 13, 2015
  • 18 Answers
SOURCE: My battery in my Y510 Ideapad shows full charge
Check your power settings in windows set it for max run also Sounds like your battery shows the volts but no capacity 18 mo old this is very close to a replacement sugest aftermarket ebay battery Usualy when you do not run down lithium batteries they become unstable this means some of the cells in the battery hold less of a charge than others in the pack so this is the weakest link senario so you get the volts but when you put a draw volt brop right off and the computer shuts down. some times they can be reconditioned so all the cells hold the same cap but there is no warranty and cost about half of what a replacement battery cost. shop around.
Posted on Sep 27, 2009
walesarumi
  • 6993 Answers
SOURCE: my problem with my Lenovo is somewhat the same but
If your computer works directly to electricity without the battery, then the battery is faulty. Battery showing you 99% does not mean it is working, because bad battries gets full on time. The cell of the battery might have been dead because only GOD knows how long it had stayed in the factory.
But if you are convinced that the battery is good, then check the adaptor, and if the adapter is good.
Just try to check everything to ascertain the fault. And let me know what happens next.
I wish you the best.
Posted on Nov 13, 2009
silntkill
  • 13 Answers
SOURCE: IdeaPad Y530-5243U 15.4" Laptop PC Notebook: My Lenovo ideapad Y530 fails to turn on with batte...
the battery of your ideapad is already defective, try to change battery
Posted on Jun 12, 2010
  • 902 Answers
SOURCE: Hi, I am using ideapad
with laptop batteries its recommended that you charge it fully the first time and let it drain completely then charge it fully again and unplug it. you will do damage to your battery if its fully charged while its still plugged in and with all rechargeable batteries they decrease how long they can be used over time.
please let me know if this helped
Posted on Mar 14, 2011
SOURCE: Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
Posted on May 15, 2012
Lenovo Z400 bright ness issues
Is the brightness problem only when the battery is low?
May 23, 2014 | Lenovo IdeaPad Z500 Laptop Computer -...
When I update Windows 8 to 8.1 Lenovo Z500 Series Laptop than My computer Brightness is decrease?Please give me solution
Try this:
https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/Z400-Adjusting-the-Brightness-in-Windows-8-1/ta-p/1303113
May 13, 2014 | Lenovo IdeaPad Z500 Laptop Computer -...
Adjusting screen brightness on lenovo z500
Try this if you have Windows 8.1:
Lenovo ideapad z500 hardisk partitioning and resize without losing okr
You can use partition softwares to partition the drive.
eg: Minitool Partition Wizard Home Edition(its free)
Partition WizardWindows PC and Server Disk Partition Management Software
Or,if you have the original Win 8 cd and product key,you can re-install Win 8 and during the process partition the hard disk. But doing this may result in losing all your data.
Apr 09, 2014 | Lenovo IdeaPad Z500 Laptop Computer -...
I have a problem with microsoft office 2013 it asks product key i cannot find it it was given at the time i brought the ideapad z500 laptop
In your documents there will be a product key, if not it is an illegal copy and should not be used. If you need Office go to http://www.openoffice.org/?lang=en-US
Open office is compatible with all systems and is totally free!
Feb 20, 2014 | Lenovo IdeaPad Z500 Laptop Computer -...
Lenovo Ideapad z500 produces annoying clicking sound every 1 second, sometimes this happens and stops, then starts again, i have no clue what's causing it.The sound comes from the far left side of the...
Sounds like debris in your cooling fan. Try vacuuming the open grills and see if the click goes away. This is usually caused by something sucked into the fan and clicking, like clothespinning playing cards to your bicycle spokes to make a motor sound as a kid. Since the fan is the only moving part in a laptop this is with 99% certainty the problem and the only way to fix it is to remove the offending debris.
Nov 15, 2013 | Lenovo IdeaPad Z500 Laptop Computer -...
Lenovo Z500 signal problem
Start by unplugging the router for about 5 seconds, plug the power back in. See how the signal is then, if not improved, you can try to log into the router and change the channel. Try 1, 6, and 11. Also ensure there are no other wireless devices that may be causing any type of interference (telephones, baby monitors, etc.) If any of these devices are close by try removing the battery to test if they might be interfering. Try updating the the wifi adapters to the latest version if you have not already done so. I am available for remote assistance on https://www.crossloop.com/RickPoitras if required. Thank you and have a wonderful day.
May 27, 2013 | Lenovo IdeaPad Z500 Laptop Computer -...
My lenovo z500 has a screen brightness issue. It very dim and it won't turn up no matter what I do?
Hi, I had this problem also and I don't know why, but Lenovo Ideapad Z500 seems to have some compatibilities issues with a new Intel video card.
So, what you need to do is rolling back the HD intel video card driver to the previous version OR go to the following path: D:\drivers\VGA\Intel\x64\9.17.10 and press Setup to install the old driver again.
That solved my problem. It's a shame that I can't upload this driver in my laptop.
Mar 18, 2013 | Lenovo IdeaPad Z500 Laptop Computer -...
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
