Question about OnStream DP30 (DP30-01) ADR Tape Drive
Can't Get Onstream to Load Tape
Had left my computer on couple of weeks ago and had retreived info from one of my cartridges. Working fine. Using echo software version 3.1 and was able to get the shuttle and firmware from one of my cartridges that I backed up. Couple of weeks later tried to retrieve info and the monitor was black and had error message "Trapped General Protection Fault and some other crap, trie d to reboot and it wouldn't kept coming up went the same screen, then I notice a floppy in the drive, took it out and rebooted okay, but onstream would not read the cartridge, it kept ejecting the tape out..Finally I downloaded 1safe and the tape still won't load my cartride. Can you help? I need to get information from my cartridges. Thanks
  • 2 more comments
  • jamal86 Sep 27, 2007
    I tried cleaning the heads, but it still does not read. I'm thinking I made need the original software.
    Thanks
  • jamal86 Feb 16, 2008
    These solutions did not helpt the problem.
    Tape drive still will not read, or load, it still reads "Idle"
    I have this theory, It was working fine at one point, but I think it has something to do with saving the data file before reinstallling and I don't think I saved the data file. But even still, after reinstalling, shouldn't it still be able to load the cartridges, that has data on them?
    should I try using another drive like "f" right now the software uses T, and V.
    Shelby
    I will try that.....
  • 19,396 Answers
First ensure that is not a software problem, possibly reinstalling software and drivers.If you are sure that the problem is not related to dirty heads the second most common cause for tape units not reading is the azimuth gone bad. Azimuth is controlled by a tiny screw inside the tape unit, near to the head. If you still cannot fix the problem then you may require specific hardware assistance from a repair center.
hope it helps
Posted on Feb 16, 2008
    President:
  • 1,944 Answers
Is there any way you can try the drive on another computer?
  • Damen Wong
    Damen Wong Feb 16, 2008
    Did you try uninstalling and reinstalling the drive?
  • Damen Wong
    Let me know how it goes.
    President:
  • 2,961 Answers
This may sound a liitle silly, but i have had problems similair, if its an external drive, it could be the power supply cable, if its internal apologies and ignore me.
Posted on Sep 25, 2007
  • 78 Answers
HI, This is normally a sign of a dirty drive head. If have any or if you can buy them, get yourself a cleaning tape to clean the head. Also check the tape itself is clear of dirt and nothing is broken/loose. M
Posted on Aug 30, 2007
I have an Lexmark x3350 and bought a new black ink cartridge a couple weeks ago. I was working fine till now, printer screen is showing Left cartridge incorrect. I unplugged everything, tried ...
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Good Luck!!!
Sep 22, 2011 | Lexmark X3350 All-In-One InkJet Printer
No tape is seen in my adr onstream drive cartridge. does the cartridge already contains a tape or you would have to buy that one too
The cartridge does always contain the tape. If the drive fails to detect a loaded tape after the cartridge is put in then there is a problem with the drive.
Jan 05, 2011 | OnStream DP30 ADR Tape Drive
I keep getting an error message saying "Remove the Cassette" and the eject mechanism won't work so I can't even remove it. It hasn't been dropped or anything. I just used it a couple of weeks ago, and it...
The only thing that you can try is to unplug the camcorder from any type of power supply, leave it sitting for about 10 minutes, plug it back in, and try again. If the tape was left in the unit while it was not being used, this could have caused a problem. If you are still unable to remove the tape, you will need to have the camcorder repaired or at least get an estimate. www.austintelstarservices.com
Aug 29, 2010 | Canon VIXIA HV30 DV Camcorder
My computer crashed, onstream driver still works. Can I install driver on new computer?
if it is compatable. try it and see
If it does not work on the new computer it will not hurt anything at all it will just reject the driver
Apr 30, 2010 | OnStream DP30 (DP30-01) ADR Tape Drive
Borrowed a flip video to tape daughters
camcorders don't generally charge from pc's as the voltage is much higher.they won't switch on when the battery is low or i should below a certain voltage..try charging it using its charger it will probably be fine .good luck farr64[colin]
Dec 29, 2009 | Pure Digital Flip Video Ultra Camcorder
I RECORDED OFF OF TV ON A BRAND NEW 8 HOUR VHS TAPE ABOUT A YEAR AGO AND NEVER PLAYED IT SINCE... TODAY I PUT THE TAPE IN AND THE VCR SHUTS DOWN... WHEN I TURN IT BACK ON, THE DISPLAY SHOWS "EJECT T"......
Well, it's always good to know the exact cause. Your post may help others. I deal in media issues all the time in the data processing world. Though not always the cause, it is unwise to at least examine the media when the hardware won't load it, and try others to certify the hardware functionality.
If your tape isn't actually broken why don't you try loading it and immediately fast-forwarding it past the defect? It should load fine a couple of feet into the tape. You may miss the beginning of your program but it won't be a total loss.
Nov 20, 2009 | Maxell T-160 PLUS
Cartridge error
what make and model???
need more information.
every printer have its unique problem.
Oct 16, 2008 | Lexmark X6170 All-In-One InkJet Printer
Can't put cartridge into printer
If your replacing the fine cartridge follow these steps. Sorry for jumping in but it looks like your in a hurry. If you already solved it, great.
1 Make sure that the printer is on, and then open the Front Cover.
The FINE Cartridge Holder moves to the left.
i_expl.gif Caution
bullet_s.gif Do not hold the FINE Cartridge Holder to stop or move it.
bullet_s.gif Do not touch the metallic parts inside the printer.
i_important.gif Important
If the Front Cover is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. Close and reopen the Front Cover to return the holder to the left.
2 Remove the empty FINE Cartridge.
(1) Push down the FINE Cartridge.
(2) Remove the FINE Cartridge.
bullet_s.gif Handle FINE Cartridges carefully to avoid staining your clothes or surrounding work area.
bullet_s.gif Discard empty FINE Cartridges according to the local laws and regulations regarding disposal of consumables.
3 Prepare the replacement cartridge.
(1) Unpack a new FINE Cartridge and remove the orange protective tape (A) gently.
*1 To the FINE Cartridge Holder
bullet_s.gif Do not re-attach the protective tape once you have removed it. Discard it according to the local laws and regulations regarding disposal of consumables.
bullet_s.gif Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE Cartridge. The printer may not print out properly if you touch it.
bullet_s.gif Be careful not to stain your clothes and hands with ink on the removed protective tape.
4 Install the FINE Cartridge.
(1) Insert a new FINE Cartridge all the way into the appropriate slot.
The Black FINE Cartridge should be installed into the left slot (ug_maintenance37.jpg) and the Color FINE Cartridge should be into the right slot (ug_maintenance38.jpg).
(2) Push up the FINE Cartridge until it clicks into place.
The printer cannot be used unless both the FINE Cartridges are installed.
5 Close the Front Cover.
Hope this does it. I'll check on you later. If this fixes you up just rate it a 4 fix ya and I'll know you're ok.
Mar 26, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cyan cartridge
My IP4200 started doing this about a week ago it tells me I have two Cyan cartridges. I don't, cartridges are canon cartridges and were changed four months ago worked fine until now. Pressing the middle button the resume button is working eventually, so far, but I don't know for how long. Seems like a hardware problem as I deleted and reinstalled the software no difference and everything worked fine for the first four months.
Jan 11, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
OnStream DP30 (DP30-01) ADR Tape Drive Logo
85 people viewed this question
Top OnStream Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an OnStream Computer and Internet Expert? Answer questions, earn points and help others
