Question about Home Fencing
What can i use to get rid of my warts under my feet
How can I get rid of a CYST ON MY FINGER that is hard, sensitive and doesnot produce liquid?
This does not sound like a cyst. Are you sure that it is not a wart?
Aug 31, 2017 | Medical
Tip
TO MANY WALL WARTS WITH NO IDEA TO WHAT THEY GO
Here is a quick and simple way to code your wall warts (transformer power supplies for drills,camera, electronic items etc). I have many wall wart style chargers and sometimes I forget which item they go too. I have lots of guitar effects, bass effects, camera, camcorder and much more. Now after I have figured out what they go to, I buy multi-colored tie wraps and put one color on the wall wart and the same color on the tool or device it goes too. If I run out of colors I buy colored tape and do the same thing and you can resuse colors that way. It has helped me eliminate a frustrating situation.
on Mar 23, 2011 | Televison & Video
Will a pumice stone spread a wart?
Pumice stone will just grind it down but not kill or remove the kernel responsible for wart. Need to get some sort of wart remover - Walmart has one - takes time and repeated applications but it does work.
Jun 06, 2016 | Skin Care Health & Beauty
How to hard wire the power supply on a radioshack 2.4 wireless camera model 49-2535
What is the voltage? If it is 9 or 12 you can get a wall wart and run it from the garage to the camera. The best way it to run the power supply in one solid run. DOnt make several connections, that creates a fire hazard. Neighbors is hard wired and he has about only 20 feet of wire going to it. They run on a small amount of current. Its not like you are running 5 amps of current. Anything that covers the amount of current an correct voltage will work.
Jan 31, 2015 | Home Security
The dual charger does not charge the batteries
Simply fix the wall wart. AE6JI 704-745-2067 Extra Class FCC VEC +45 years practical electronics.
There is a fine wire, (under the paper wrapping) or on the transformer, re-close, and it will work 99% of the time.
WARNING random wall warts WILL vary, up to 200% of what their rating label states!
Next time do not have the wall wart plugged into the Wall AC, until AFTER you plug it into the radio.
Jan 09, 2015 | Radio Communications
Can apple cider viniger remove warts and skin tags
No but it does a good job of detoxifying your liver.
Jun 30, 2014 | Computers & Internet
How to get rid of ******* warts at home
Dr. Scholl's sells little pads you stick over the wart. Compound W lets you freeze the wart off. My brother-in-law from Arkansas swears he caught an insect called a Kaydedid and it ate the wart off his hand. I once successfully treated plantar's warts on my feet with tiny dots of bleach, however, the skin absorbs bleach and can cause breathing problems and on people with sensitive skin, bleach can cause a burn. Wal-Mart even sells a homeopathic wart cream.
May 05, 2014 | Health & Beauty
How do you get warts to goaway easy and cheap?
compoun d W works for alot of people-over the counter @ most drug stores.
May 13, 2013 | Health & Beauty
Roland mc-303
Yes, that is the likely problem.
The unit takes a 9 volt AC adapter with enough current.
Several sources are selling them on eBay. Search for mc-303 and some will come up.
Likely the adapter you have does not have enough current, hence the regulator within the mc-303 drops out of regulation paprt of the AC cycle.
Nov 17, 2009 | Music
My dsl light is on green but my power light is on red. After a while no lights are on. My router is a 2wire that's about a year old
These 2Wire devices are known to have their wall-wart weaken over time. Although you can measure the proper voltage coming from the wall-wart, when you load it with the DSL modem, the actual voltage drops giving you the red power light. The green DSL light may or may not be accurate while the DSL modem is not getting the power it needs. Look online or go to a store like Radio Shack for a replacement wall wart.
Aug 26, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Home Fencing Logo
184 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
