Maserati quattroporte cpu
I have a 2008 Maserati Cento Limited with the rear entertainment system. The screen indicate that I need to repair the hard drive by inserting the original setup disk which looks to be Windows xp. I have placed an original windows Xp disk in the tray but am not sure that it is the interface for the CPU. Nothing seems to work and i can not find anything related on the web. This is #15 out of 100 cars in the world. How do I fix this problem?
SOURCE: My recovery CD (gateway 7330gz PC) are no working
I have the same problem with my Gateway 7330gz. My laptop got infected with spywares and it was so annoyed that I have to think about recover the system. So I did it with Gateway Recovery software. I chose the recovery option (press F11 when boot up)from hard drive since my dvd drive was broken. It went well but when it boots up again and Windows XP says detecting and installing the drivers and such, it was frozen haft way through. I turned off power many times to reboot but it kept freezing at that point. I search Internet for help and seen this post. Wonderful! I press F2 to go to BIOS setup screen, use right arrow key to move to Advance menu option. There I use down arrow key to select SpeedStep, hit (-) key to disable it. Then F10 to save and exit, hit enter for OK button. The system boots again but this time it was no longer freezing, the setup process went through ok and continues...I am so happy and type this message so it might help others with the same issue. Thanks
Posted on Nov 28, 2008
leecom72
  • 4806 Answers
SOURCE: toshiba spa 40 model No psa45e-0184h-en corrupt hard drive
you can now purchase recovery cd's from the manufactuer
kind regards and please don't forget to rate
Posted on Dec 01, 2008
zohail
  • 1223 Answers
SOURCE: how to format acer aspire 4710 with xp
actually there is no need to touch anything in hardware please do not touch ur hardware without any reason i know what eactly is the solution is now follow this :
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
Solution:
this specific model Aspire 4710 was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset Mobile Intel® 945GM Express download SATA RAID DRIVERS and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
http://www.nliteos.com/
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
important tutorial links
http://www.zimbio.com/Laptop+Reviews/articles/10840/How+Integrate+Floppy+SATA+RAID+Driver+Windows
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
pls let me know if i can help u more
Posted on Feb 23, 2009
Geekman
  • 32281 Answers
SOURCE: Setup does not detect any hard drives
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Posted on Apr 10, 2009
kamal1984
  • 1383 Answers
SOURCE: How to install Windows Xp on Compaq Presario CQ40 Notebooks ?
go to bios and go t o ide configuration advanced and disable sata.
Then u can start winxp setup.
Posted on Jun 11, 2009
I cannot get my 07 maserati to go from drive to neutral. The car is off I need some guidance
Exactly what type of Maserati do you have? Gran Sport, Gran Turismo, Quattroporte, etc. Do you have the F1 system or the regular automatic transmission?
Mar 09, 2016 | Maserati Cars & Trucks
How to hook up all the wires back onto the battery since I'd just bought a new battery and I'm trying to hook the battery back together
Keith, If you have the correct battery( size and correct cable terminals) you may have to give the wires a little tug to give a little more length, stretch so the wires are easier to put on. The wire with the red end goes to positive on battery. If battery in trunk the battery connections face out. I will put links below, hope they help.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Maserati Tutorial Accessing the Battery Quattroporte
Mar 02, 2016 | 2008 Maserati Quattroporte
How to clear engine codes on a 2007 maserati quattroporte
As most engine CPU need a scanner to clear codes and reset the CPU I would give that a try first.
Jul 24, 2014 | 2007 Maserati Quattroporte Executive GT...
I have my third Maserati Quattroporte(model 2013) They changed the cruise control system and you have to activate it with your left thumb on the steering wheel. It is ergonomic very bad and the switches...
most cruise controls in a vehicle with more combustion power are difficult to set, however, try to slightly lift foot off pedal when setting the switch it should actually activate much easier, second your like me, arthritis and need a doctor.
Jan 04, 2014 | Computer, Chip, Cruise Control for...
How to program 2007 maserati quattroporte after dead battery
how to progran the computer on the 2005 maserati quattroporte.
Oct 18, 2012 | 2007 Maserati Quattroporte Executive GT...
What type of transmission fluid do i need for 2005 maserati quattroporte?
LOOK IN YOUR OWNERS MANUAL IN GLOVE COMPARTMENT.IT WILL TELL YOU TYPE TRANSMISSION FLUID VECHICLE USES.
Oct 26, 2011 | 2005 Maserati Quattroporte
I need a new clutch for my maserati quattroporte 2005
i would order it from shucks ive allways had the best luck with them. order the kit with clutch disc pressure plate and throw out berring
Apr 03, 2010 | 2005 Maserati Quattroporte
Maserati navigation cd
Just Purchased a 2004 Maserati CambioCorsa Coupe with a Blaupunkt remote 5 disc CD Player in the trunk. The indash info center recognizes its existence but will not communicate. The Blaupunkt will accept a CD but will not play it or release it. I cannot see any model numbers Etc, any ideas anyone.
Mar 05, 2010 | 2005 Maserati Quattroporte
2007 Maserati Quattroporte - dead battery
stick a metter on it to determine the positive .
Dec 20, 2009 | 2007 Maserati Quattroporte Executive GT...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
