Question about Indesit Washing Machines
Wiring diagram indesit widl126 s
Need to know which multi plugs go where in the pcb, need wiring diagram
  • 236 Answers
SOURCE: PCB replacement
it seems that you are talking about the two wires that fit onto the back of the board where there is a black component that is square on the right hand side when looking from the front the wires fit within the black unit. i cannot remember which way around though. i will post again when i next do a wma repair ,tony.
Posted on Jun 02, 2007
  • 1294 Answers
SOURCE: indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Posted on Jun 16, 2007
evanusa
  • 197 Answers
SOURCE: indesit widl126s humming noise on spin cycle and
Your drain filter is clogged with debris. Usually small items like dirt, paper, money, and much more. Clean the filter and you should be set to go.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 01, 2009
  • 82 Answers
SOURCE: My Indesit Washer dryer WIDL126 will not work all
My guess without seeing the machine is - The motor has gone / failed.
You could get someone to check the brushes on the motor, it's only a 30 minute job.
If the brushes are ok i.e more then 10mm long, I suspect the motor has burnt out if the machine is a number of years old.
Hope this helps
jb
Posted on Jun 25, 2009
SOURCE: indesit 1200 washing machine boils everything and
make sure you have connected the cold water feed and not a hot water supply, these machines need a cold water feed only
Posted on Jul 27, 2010
I need to know the wiring diagram for a fridge thermostat
There is a wiring diagram inside the lower part of the appliance
Feb 23, 2018 | Indesit Refrigerators
My Indesit Washer dryer WIDL126 will not work all the LED lights are flashing continually.I have tried turning off at the plug and then on again, but no good. Any answers please?
Hope this helps
jb
Jun 22, 2009 | Indesit W 123 Front Load Washer
INSTUCTION MANUAL REQUIRED
This online company list all Indesit WM manual:
http://www.unbeatable.co.uk/manuals/Indesit-Washing-Machines/27916330.html
From them:
Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
no_image_large.jpg Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
May 26, 2009 | Indesit Washing Machines
All the red & green led's are flashing very dull
The problem is in the power supply circuit of controller PCB. Replace C9 (680uF/10V) with a new one.
Mar 21, 2009 | Washing Machines
Ido not have a manual for this machine (WIDL126 ) and don't know
http://www.instructionsmanuals.com/u2/pdf/lavadora/Indesit-WIDL126-en.pdf
Nov 20, 2008 | Indesit Washing Machines
I've got an Indesit WIDL126S and it is leaking. The water escapes from behind a brass plate with wires on. The brass plate is held on by a 10mm nut. Do I need to buy a bearing and seal kit?
this sounds like the heater you are looking at. try tightening the 10mm nut a bit. if that doesn't work. loosen the nut, pull heater out and use some sealant. why do you think you need to replace bearings and seals?
Aug 23, 2008 | Indesit Washing Machines
WIDl126 - door lock and easy iron flash
worth trying this! make sure the drain hose is only down the waste pipe about 6 inchs, and up off ground level about 24 inchs ie. 2 feet.If that don't not work it could be faulty pcb board!let me know.bye,close,ire.
Dec 23, 2007 | Indesit W 123 Front Load Washer
Indesit widl126s
Jun 15, 2007 | Indesit WA 125 Front Load Washer
Washing Machines Logo
97 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
