Kenmore washer type 580 110.27072603
My washer stopped worked and gave code ld.
  • 96 Answers
SOURCE: F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Posted on Mar 17, 2008
SOURCE: Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Posted on Jan 25, 2009
wheelshot
  • 102 Answers
SOURCE: what does LD and OB mean on my washer
LD means long drain and will require a pump replacement. The new pump is totally different from the old one so unless you are very crafty and good at figuring out puzzles, you may need to have a service company come out. I don't know what the other code means but most of the time the pump is the major problem with these units.
Posted on Apr 06, 2009
  • 1122 Answers
SOURCE: Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Posted on Apr 24, 2009
  • 151 Answers
SOURCE: Oasis washer has Ld CODE runs will not drain.
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
Posted on May 03, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
How do I unclog the long drain Kenmore elite oasis?
Honestly, we got rid of the machine and bought a Maytag Neptune. I was over trying to figure out all the codes the Oasis was flashing. We gave up on the first one that started having problems when a friend gave us one identical to ours and it has done a lot of the same things.
Apr 03, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Calypso top load Kenmore washer. I get an LD code displayed and the washeer stops Any ideas ?
Although I haven't 'LD' in my list, I suspect that it indicates there is a problem with the lid/door lock. Either the locking solenoid or the lid lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 20, 2011 | Kenmore 24032\24036 Top Load Washer
What does Code LD mean? When it is supposed to spin out, It stops and I get a code LD.
LD is a long drain code usually mean something is in the drain line or pump area. Check thes areas first. If nothing blocking them then the pump is going out.
Dec 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
The washer stops with the code LD
Call the recall # 1 800 659 7026 & see if your model is part of the recall. Mine was! I f yours is, they will ship the new control pane via UPS free of charge & schedule a technician to come out & repair the machine (also free of charge) in about 10 days! Good luck!
Dec 04, 2009 | Kenmore Oasis HE 27082 Top Load Washer
May 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Stops between rinse and spin cycles giving a ld code..
ld sure sounds like lid switch problems. Suprised to see this so soon, but I did see one come apart on a fairly new Whirlpool. Luckily, it should be easy to check. Unplug the machine first.
Apr 29, 2009 | Washing Machines
Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
