Question about Nikon COOLPIX L810
Lens stuck my camera does not turn on and the lens seems to be jammed or stuck
  • 3 Answers
Forget standard batteries in this camera. I tried a "new" set an inexpensive Eveready 1215, don't do it. Get a set of Duracell Alkaline. When I did that it powered right up. Go figure.
Posted on Aug 24, 2013
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at kiddo242@hotmail.com
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
Lens stuck out and need to go back in
internal lens mechanism is jammed. Have the camera repaired by a professional.
Jul 20, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Hi i turn the camera on and have a blurry screen
Zoom motor in lens assembly is jammed and you need to replace complete lens assembly. DSC-T1 is an old camera so oes not worth to repair.
Jun 04, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Lens Broken
the lens is what the camers sees somewhat like the human eyeball, you loose your eye you can't see, brake the lens the camera cant see
Jan 03, 2009 | Cameras
Canon 20d - lens stuck / jammed
HI BRIAN ,,I AM SAGHA CAMERA REPAIRER,I THINK UR PROBLEM OCCURS DUE TO JAMMING OF PLASTIC MOUNT ON THE METAL BODY OF 20D.TRY THIS
1} LUBRICATE THE JUNCTION WHERE LENS GET ATTACHED TO THE BODY WITH KEROSENE THEN TRY TO RELEASE THE LENS.REMOVE THE BATTERY FROM CAMERA ,TRY AND HEAT UP THE JUNCTION WITH HAIR DRYER A LITTLEBIT THEN TRY TO RELEASE THE LENS.
2}IF THIS THING ALSO DOESN'T WORK THEN YOU HAVE TO SACRIFICE THE LENS PLASTIC MOUNT PUT SOME SHARP KNIFE LIKE OBJECT IN THE JUNCTION OF LENS & CAMERA & THEN PUSH IT UPWARDS WHICH WILL BREAK ONE OF THE PLASTIC LENS MOUNT COLLOR AND LENS WILL COME OUT WITHOUT DAMAGING YOUR CAMERA .LATER YOU CAN GET REPLACED THE LENS MOUNT FROM SERVICE PERSON. BUT NOW ATLEAST YOU CAN USE CAMERA WITH OTHER LENSES.
Sep 29, 2008 | Canon EOS-20D Digital Camera
Lens error coolpix l6
The lens is probably stuck with a piece of dirt or something jamming it. You could gently try and pull on the lens with a slight turn in each direction to see if you can dislodge the particle.
Some individuals on the internet have felt comfortable enough to try and disassemble the camera to reveal the parts of the lens drive mechanism, clean it and put it back together and this sometimes will help (but that is beyond this response) because there are enough locations on the net that describe this.
Since it's 4 months old, you may want to return it for a replacement.
Other alternatives are:
  1. Carefully use some compressed air around the lens mechanism.
  2. Take the camera back and get a replacement, or
  3. Talk to Nikon and get it serviced.
Hope this helps, if it does, please choose FixYa!
ThankYa!
Nov 10, 2007 | Nikon Coolpix 5200 Digital Camera
Lens shutter stuck
If you're careful this problem is a relatively easy fix for many digital cameras. The design of the lens cover mechanism is usually simple and very similar throughout camera brands. Here's an example fix for a Canon A400 with similar problems:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jan 24, 2007 | Fuji FinePix A340 Digital Camera
Nikon COOLPIX L810 Logo
90 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
