Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv kv32fs120 has no power , 9 times blinks
Tried to resolder ZCD but still no power. do i need to replace the module parts # a-1415-722-a ?. thank you Roxel
  • fixmysony32 Dec 29, 2008
    sony tv kv32fs120 has no power , 9 times blinks problem. Where are D645 and D647? I have no schematic to work with.
Replace diodes D645, and D647 in standby power supply circuit.
Part# 6-500-567-01
Posted on Aug 07, 2008
    Problem Solver:
  • 19 Answers
Try replacing Q605, D690, D647 and Q690. These are all individual components that Sony techs have identified as being the source of the problem. You could try replacing one component at a time, but that would be time intensive. Its up to you! You could also become a premium member and request the "9 Blinks, ZCD/KV27FS320, KV32FS120, KV32FS320, KV36FS120, KV36FS320" information package, which was the source of this information.
Posted on Jun 16, 2010
It probably is not a fuse. If you can go into test mode it is not a fuse. I'm working on my daughter's tv 9 flashes. Purchased the manual so much for that it stops at 5 flashes. This is a zero crossing problem. I am digging and will come back when I find the fix. Many are stating replace the xxx diodes on the G board. Sorry guys no G board on this tv.
Posted on Sep 23, 2007
    Genius:
  • 1,153 Answers
Look for an open resistor or diode or zenerD. in pwr sup. blown fuse first
Posted on Aug 29, 2007
Stanby light blinks 9 times after powering on but no picture
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections.
Hope that helps.
Jan 17, 2011 | Sony KDL-46XBR2 Television
TV won't turn on, standby light just blinks 9 times
hello, Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
regards
shaun
Oct 19, 2010 | Sony KP-46WT520 46" Rear Projection...
Standby/light flashes 9 times, what does this means.
call pts electronics replace power board in you tv dont try to fix just replace board
Aug 10, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony Wega kp46wt520 no power up, 9 times it blinks red
You will need to replace the G board. You can try replacing the two diodes that usually fail, But because its a complex circuit with the zero cross detection the diode replacement never fixes the issue. Replacing or remanufacturing the G board is the only sure way to fix that issue.
Nov 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV blinks 9 times and wont turn on please help
Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive). hope it works
shaun
Aug 24, 2009 | Sony KP-46WT520 46" Rear Projection...
Won't turn on
Diagnostic code meaning;
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Hope it may help you;
    Regards,
    VOTIT
    Sep 15, 2008 | Sony KP-46WT520 46" Rear Projection...
    SONY KV32FS120
    There are many different causes for 9 blinks on your model the best solution that i have for someone in your shoes is to replace the A board in the set. PN A-1302-981-A http://www.partstore.com/Part/Sony/Sony/A1302981A/New.aspx You may be able to find this board cheaper elseware. Let me know if you need more help?
    Tim
    Experttv@comcast.net
    Sep 11, 2008 | Televison & Video
    Sonny 32" WEGA flatscreen.
    The set has a problem in the power supply, to be more specific it is the ZCD or zero cross detection circuit. The way you can tell is with the set off use the Sony remote and in sequence press the display then the 5 then the volume down then press the power button on the remote. The set should come on bypassing that circuit. The screen will come up with a diagnostic screen with abbreviations like HSTOP, VSTOP, LOW B+, etc. There will be one towards the bottom that says ZCD. The number to the right will be higher than zereo indicating the ZCD circuit at fault and yes a technician will have to repair that.
    Jan 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony FD Trinitron WEGA KV 32FS120
    This model does not have a G board. I will post when I have this solved.
    Jun 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
    1,025 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
